    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-15-2016, 06:50 AM   #19681
SamuraiJack's Avatar
Trader Rating: 38 (100%+)
Hello! Could someone do me a huge favor and measure the exact distance between the holes (center to center) on one B5M wing mount? Thanks
(Between the two vertical holes on one mount for mounting on the shock tower)
❂ 8IGHT-E 3.0 ❂ 8IGHT 2.5 ❂ XXX-4 ❂ SRX4 ❂ SRX2 MM
SamuraiJack is offline   Reply With Quote
Old 04-15-2016, 07:15 AM   #19682
JC8390's Avatar
Originally Posted by Kalio View Post
I've been wondering about batteries too. I thought about getting the ProTek RC 2S 100C X-Light Shorty LiPo because the weight is only 147g (vs ~210g for most shorties), but the capacity is only 2800 mah and one reviewer commented on relatively high IR. I'm not sure if the big loss in capacity is worth it the weight savings. I presume a lower capacity battery will loose more punch quicker then a higher capacity (4000-4500 mah) battery, especially in a 10 minute main.
I've been eye balling that battery for a while. I think it would be a good way to go because if you wanted to put weight back in for whatever reason swap the battery to a heavier one and done.
I could see it being close in a 10min main but it should be ok. I'm sure it would loose some kick towards the end.
8ight E 4.0
Orion| Hobby Wing| Savox| Turnigy| AKA
RC10 B5M CE
Fantom| HobbyWing| Savox| Turnigy| JConcepts
JC8390 is offline   Reply With Quote
Old 04-15-2016, 07:17 AM   #19683
Originally Posted by SamuraiJack View Post
Hello! Could someone do me a huge favor and measure the exact distance between the holes (center to center) on one B5M wing mount? Thanks!
I'm getting 23mm.
Gearhead82 is offline   Reply With Quote
Old 04-15-2016, 07:21 AM   #19684
DennisNyholm's Avatar
10 min main? That sounds like fun. I'm getting about 15 minutes on a 4200 pack, don't know if I would make it with that battery myself. Luckily I'm good on weight so a shorty is perfect for me.
DennisNyholm is offline   Reply With Quote
Old 04-15-2016, 08:11 AM   #19685
JC8390's Avatar
I don't see 2800mah being a problem at all for 10min. I generally use about 1000mah in 5min.
8ight E 4.0
RC10 B5M CE
Old 04-15-2016, 08:21 AM   #19686
Suspended
Trader Rating: 61 (100%+)
I don't like the idea of making the battery lighter. This is your heaviest part of the car, and is a well used part for weight bias. Lose weight there, you also lose your ability to balance the handling.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-15-2016, 11:31 AM   #19687
has anyone treid the reedy lipo 5300?
eddie7978 is offline   Reply With Quote
Old 04-15-2016, 12:05 PM   #19688
OriginalDonk's Avatar
Trader Rating: 41 (100%+)
Eddie, love the enthusiasm you're showing. Good stuff and no doubt you'll get quicker in the short term.
I'd suggest you ask a few of your battery and motor questions in the radio and electronics forum and keep this thread as B5M-specific as possible. Use the forum search option as much as possible.
http://www.rctech.net/forum/radio-electronics-137/
Having said that, Reedy makes nice stuff but no specific piece of gear will beat track time and good set up. Look at your budget and make sure you have money to cover your track practice fees so you can be a track rat. Good luck man.
OriginalDonk is offline   Reply With Quote
Old 04-15-2016, 02:33 PM   #19689
Send a message via ICQ to intercede007 Send a message via AIM to intercede007 Send a message via Yahoo to intercede007
Any tips to servo horn attachment? Just did it for a 3rd time, still ended up having to trim to the right. I'm as close to 90* as the horn and servo gear will let me get when I attach it.
Are you guys going 1 tooth to either side?
intercede007 is offline   Reply With Quote
Old 04-15-2016, 02:39 PM   #19690
JC8390's Avatar
Had the same problem. I found that if you pull the 4 bolts out of the bulkhead and the 2 from the top plate and sort of lift the plate up so you can see then adjust the horn you can get it right that way.
Old 04-15-2016, 04:54 PM   #19691
soniccj5's Avatar
I am running that in my B5M FL and it would make a 10 minute main. I had to add weight to it though to get traction. 35 grams.
My plan is to buy the AE lipo weight set.
https://www.teamassociated.com/parts...ry_weight_set/
With the battery and added 35grams it comes in at 1496.
RC-10/ B4(+8mm)/
B5M FactoryLite|GTB3|Vulcan 17.5|MIP Pucks|Proline Primes|
B64D|510R|6.5 Vulcan
B6D|510R|7.5 Reedy
soniccj5 is offline   Reply With Quote
Old 04-16-2016, 04:25 AM   #19692
thecman26's Avatar
Trader Rating: 99 (100%+)
Due to low turnouts the last few weeks we have been doing three 8 min quals and a 10 minute main and it is a BLAST! In a 10 min main you don't have to stress out about a crummy start or 1st turn pileup!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 04-16-2016, 06:08 AM   #19693
For mod racers is it better to run a square Lipo that weighs about 300gm or go to a shorty or even a slim shorty that weighs around 145gm? Does weight reduction make a difference in mod racing?
tekin112000 is online now   Reply With Quote
Old 04-16-2016, 06:25 AM   #19694
Suspended
Weight always has an impact. Whether it's positive or negative is up to you. Some people LOVE a heavy car, IE Maifield, some really like a lighter car, IE Tessmann.
You'll only know when you try it.
Old 04-16-2016, 07:52 AM   #19695
I ran my B5m lite in 17.5 Stock for the first time last night, holy balls this is an awesome car. Coming from 2WD Short Course (10.5t motor) the buggy feels so freakin' nimble and so much turn in compared to the truck.
So far the only things I've done to setup and lowered the top hole of the rear shocks inward, using a slipper eliminator and gone up 4 teeth on the pinion. Still yet to to change the rear springs to the Greens. 2WD Stock Buggy at my local track is all B5m's except for one Tamiya and already up there with the fast guys.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
