    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree17Likes
Old 04-02-2016, 08:37 PM   #19381
JAE
Trader Rating: 28 (100%+)
Default Oil
Glad someone mentioned it. Am always buying new oil because of this. Anyone.
Originally Posted by caffeine357 View Post
every single bottle of AE shock oil no matter how much i seal it leaks the oil out eventually and the bottle is covered when i pick it up. does this seep through the plastic eventually? I cant seem to figure it out anyone have any suggestions?
JAE
JAE is offline   Reply With Quote
Old 04-03-2016, 05:35 AM   #19382
Originally Posted by Silverstonev8 View Post
So it came early. Servo fits well with no cutting. Car weighs in at 1585g
Nice! I would cut the nubs off the wing mount and screw the wing into the mount. You will need either wing buttons or small washers. Also make sure you have the set screws in the bottoms of the hubs and front bulkhead if aluminum to remove any slop.
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
Old 04-03-2016, 05:58 AM   #19383
Silverstonev8's Avatar
I have the avid wing buttons but haven't had a chance to pop them on yet. I have them on my B44 and love them.
I have the set screws in the rear hubs and front bulkhead since I did the hinge pin mod...
Silverstonev8 is offline   Reply With Quote
Old 04-03-2016, 07:29 AM   #19384
Keep the blue cap that comes with the bottle.
R/C Rich is offline   Reply With Quote
Old 04-03-2016, 07:42 AM   #19385
You got me curious so I just looked and saw that the front hubs take set screws also... I'm on it! Thanks
Old 04-03-2016, 09:09 AM   #19386
Johnn27's Avatar
Trader Rating: 72 (100%+)
Questions?? Front Suspension
I appreciate all the responses regarding hard vs. stock suspension arms. One more question because unfortunately since I did not build this car and I bought it as a new slightly used roller I am working out the bugs from the previous owner.
Regarding the front suspension block? I used to run an aluminum block in other cars and trucks I ran one but I prefer to run the stock one to keep the car light weight.
So the Question becomes that while replacing the front arm I noticed the hinge pins are kind of tight and need to be pressed into the suspension block? Is this normal? Should I ream it out so they move freely and no the pins aren't tweak I checked that too! So do I ream it ? leave it alone and let them be snug/tight or go to an aluminum front block running 17.5???
Johnn27 is offline   Reply With Quote
Old 04-03-2016, 09:49 AM   #19387
Suspended
Trader Rating: 61 (100%+)
I only have a horrible answer to this...
Buy Losi oil
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-03-2016, 09:50 AM   #19388
Suspended
Check the hinge pins aren't bent first. (roll them on a piece of glass)
Then yes, I'd ream the block and arms. Unfortunately this is part of owning a B5M.
Old 04-03-2016, 12:05 PM   #19389
Right, I didn't see them at first either but it takes some slop out. The part number is 4670.
There is a mod that includes this on the bulkhead so you can take off the front pin holder and give a better approach angle so it doesn't hit on steeper take offs when the suspension gives and also nose diving landings. Typically not needed for us carpet guys. But you need the aluminum or brass bulkhead that has the option for the grubs.
http://site.petitrc.com/setup/associ...i_FrontEndTip/
B4.1
SC10
Losi SCB
Old 04-03-2016, 12:07 PM   #19390
Originally Posted by Bob Barry View Post
Ready for Turf... Trying the new Trinity Fan mount
What is the feedback ?
julieng is offline   Reply With Quote
Old 04-03-2016, 12:08 PM   #19391
Definitely keep the blue thing. If you already threw it out cut a piece of Saran Wrap and screw the top on with it in between. Some bottles I came with the screw cap some didn't. It would be better with the screw cap but then again, you wouldn't need to buy oil as often.
B4.1
SC10
Losi SCB
Old 04-03-2016, 12:13 PM   #19392
I have already done that mod and also cut the front pins down so there was no extra hanging out the back of the arm.
Old 04-04-2016, 04:57 AM   #19393
Hasi's Avatar
Why cut the nubs off? You can screw the wing down with using the nubs. I used the hole in the middle of the wing mount:
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage
Hasi is offline   Reply With Quote
Old 04-04-2016, 05:07 AM   #19394
It smoothes it out...
Old 04-04-2016, 05:41 AM   #19395
thecman26's Avatar
Trader Rating: 99 (100%+)
Plus it removes all the wobble inherent in the stock mount.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
