    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree17Likes
Old 03-29-2016, 07:52 AM   #19306
Thanks for the help
braderb is offline   Reply With Quote
Old 03-29-2016, 08:16 AM   #19307
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by braderb View Post
Clarify
I need the shock tools that tighten the caps on.
My TLR ones don't work - TLR5099
I've always used the cheap tools that come in the kit, and I almost never need those. No need to tighten more than "hand tight", IMO.
I'm not even sure anyone makes a tool or tools (aftermarket) specifically to fit the top and bottom caps on the current AE shocks? If they do I wouldn't waste my money on them.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 03-29-2016, 09:34 AM   #19308
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Yup, I use the schelle wrench to hold the bottom of the shock body and hand tighten the cap on. There are no / you don't need any special tools for tightening the cap.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-29-2016, 11:03 AM   #19309
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Same. the silver steel tool that comes with the kit works as well. but I always just finger tighten the shock caps. no need to hulk them on.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-29-2016, 07:36 PM   #19310
Originally Posted by NielsVV View Post
I made yesterday my maiden ride with the b5m on our local track. After the first jump I crashed and broke the rear shock mount! Spare parts were on order, so after only maybe 5min driving I went back home and ordered a couple more.
So far, I'm having some mixed feelings about the b5m.
Only thing I have broken is an A - ARm because an 8th scale ran my ass over on an outdoor track. if you get the aluminum bulkhead, im pretty sure its damn near close to indestructible.
caffeine357 is offline   Reply With Quote
Old 03-29-2016, 07:39 PM   #19311
Trader Rating: 16 (100%+)
Same here. We run on a carpet track that lets you carry a LOT of speed. I can't count how many times I've tried to knock the walls down and so far I bent a rear hinge pin and broke the plastic bulkhead.
MX304 is offline   Reply With Quote
Old 03-29-2016, 08:29 PM   #19312
Originally Posted by Gearhead82 View Post
I'm a beginner and I've been amazed at how durable the car has been through lots of crashes in my first couple months of racing. I haven't broken anything major. Just a couple odds and ends:
2 - bent rear shock shafts (at least one was from getting t-boned by another driver while I was flipped upside down)
1 - broken ball cup (pretty sure I cracked it while squeezing it with pliers to loosen it up during assembly and it later broke at the track)
2 - broken shock eyelets (from screwing them too far onto the shock shaft during assembly, I think)
1 - plastic rear camber insert block (shouldn't happen again now that I added a washer to the assembly, as suggested on this thread)
and of course I've destroyed a couple rear wings as well. . .
nothing is going to stop anyone from destroying the rear wings. i suggested the associated branded wings for replacements. they are dirt cheap
Old 03-30-2016, 07:41 AM   #19313
I forgot about the Schelle tool, I love that thing!
I agree, you should t need to tighten more than hand tight. Let the o ring do its job.
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
Old 03-30-2016, 07:43 AM   #19314
Hahaha I have done the same thing on our carpet track. Maybe I just forget to turn
The aluminum/brass bulkhead is a great buy/upgrade in my opinion.
B4.1
SC10
Losi SCB
Old 03-30-2016, 08:35 AM   #19315
Run this wing and you will never hurt it I have been running mine about a year, its a little heavy but it is bulletproof.
http://www.amainhobbies.com/rc-cars-...800abk/p267310
jslider is offline   Reply With Quote
Old 03-30-2016, 08:44 AM   #19316
That looks interesting. I'd be worried about adding that much weight so high on the chassis but it might be good for practice days.
Gearhead82 is offline   Reply With Quote
Old 03-30-2016, 09:51 AM   #19317
Any hints on how to fit a Reedy Blkbx 800Z ESC and a Futaba R614 in with a shorty pack? Seems it's all a bit too cramped. Unless I remove the bulkhead and fasten the battery another way(I don't want to tape the battery in, needs to be removable.
Hauptmann6 is offline   Reply With Quote
Old 03-30-2016, 10:19 AM   #19318
The esc is not very large. I assume the issue is the receiver. I would use a schelle battery strap to eliminate the front foams, then put the cap in the battery tray to give a little more space
Old 03-30-2016, 10:29 AM   #19319
It's the ESC. It just barely fits. and with the cap it takes up all the room. Just surprised it's so hard to layout decently using all their products.
That might be the ticket, remove the bulkhead between the screwdowns. I could slide everything back a touch.
Thanks for the info on that. I was thinking of cutting the foam and having a gap, but that's an easier way to do it.
Old 03-30-2016, 10:45 AM   #19320
Silverstonev8's Avatar
It looks like a decent amount of room in this pic. Not sure how big it is compared to the 410r but I got it all in mine without cutting..
Silverstonev8 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (3 members and 5 guests)
Crash217, Dmkiefer, MrLean
