    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-23-2016, 05:49 PM   #19186
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by RCFAN 78 View Post
I purchased the "ProTek RC Aluminum Servo Horn (25T-Futaba/Orion/Savox/ProTek". Should I purchase the clamping one?
The exotek horn for the AE car is a perfect fit.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-23-2016, 06:07 PM   #19187
Silverstonev8's Avatar
I have the exotek on my b5m and b44.3. No complaints. Perfect fit and good quality.
Silverstonev8 is offline   Reply With Quote
Old 03-23-2016, 06:37 PM   #19188
Thanks. I think the servo horn I bought does not align the steering correctly. It seems to push everything left which may account for why the turnbuckles are uneven.
RCFAN 78 is offline   Reply With Quote
Old 03-23-2016, 06:49 PM   #19189
I've had the exotek one for on my new airtronics low profile servo but had a clamping racers edge also fit perfectly when I had my Savox 1256tg
So I think other brands fit but I guess to be safe call AE up and get an AE one directly from them or an AE from your LHS like said above if u are having trouble still
Slashn77 is offline   Reply With Quote
Old 03-23-2016, 06:50 PM   #19190
If you center everything prior to installing the horn on the servo. Zero the tx trims. Put the horn on the servo closest to center and then use the tx trim to adjust it should be fine...
Old 03-23-2016, 06:53 PM   #19191
Trader Rating: 16 (100%+)
AE just put this up on their Instagram feed.
MX304 is offline   Reply With Quote
Old 03-23-2016, 07:43 PM   #19192
I use the Racers Edge blue aluminum horn for my Savix. Very good quality.
MikeTheGreek is offline   Reply With Quote
Old 03-23-2016, 08:23 PM   #19193
Looks like I had that Jconcepts rear tower setup I've seen photos of.
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
Old 03-23-2016, 08:34 PM   #19194
has anyone managed to score a j concepts wing mount set lately its been out of stock for like a month on every major retailers. any reasonable alternates?
http://www3.towerhobbies.com/cgi-bin...bd3hoCHK3w_wcB
caffeine357 is offline   Reply With Quote
Old 03-23-2016, 08:46 PM   #19195
todb's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to todb
Talk to Zeke Ballinger. He is an AE driver that races at MHOR.
OVA Neo. HW, Motiv.
Orange is faster.
todb is offline   Reply With Quote
Old 03-23-2016, 10:54 PM   #19196
RAP66's Avatar
Default Difference between 91528 and 91412 rear arms
I searched the thread and can only find a post as to "how they feel" when driving.
I have both sets here and physically they look very similar, they are stamped differently. The 91412 (lite & B5)arm does not have the cut out that the 91528 (Team & CE) arm has, aside from that they appear to be the same
What is the difference???
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 03-24-2016, 04:49 AM   #19197
thecman26's Avatar
Trader Rating: 99 (100%+)
VERY little difference, the B5 arm moves the hub forward either 1 or 2 mm. Not much but it does give a lil bit more rear traction. That's why most ppl were putting them on early on. I did on both of my B5M's.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 03-24-2016, 07:55 AM   #19198
You probably want the "lite" version. New vs used? depends on the used car? And if you want to build it. There is not much you need to do to upgrade the B5m lite out of the box. So buying used with upgrades might be a bit useless. Most of the crap people put on the car is exactly that....crap. New vs used? Do you need to save a couple dollars? Honesly with the coupon codes on tower/amain, buying used seems fruitless, unless you pick up a cherry used car for a steal.
Old 03-24-2016, 07:55 AM   #19199
Originally Posted by rctrains View Post
Currently have a 22 1.0 wanting to make the upgrade to b5m, what version should I get, and new or used?. Thanks!
get a champions edition that launched last year. the shocks alone justify the extra 80 bucks and it has alot of extras. I couldnt be happier with it.
Old 03-24-2016, 07:55 AM   #19200
Yeah I couldnt agree with this more, the coupons now that they all have makes getting a new one the way to go
