    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-16-2016, 08:30 AM   #19036
What racing wing do you guys prefer in regards to bang for the buck? ive heard a few guys at my track recommend the serpent buggy wing.
caffeine357 is offline   Reply With Quote
Old 03-16-2016, 08:40 AM   #19037
jmcelroy42's Avatar
The ProLine Trifecta is pretty durable. However I like the design of the Upgrade RC Vortex wing.
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 03-16-2016, 08:45 AM   #19038
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Honestly, the stock wing is the best. It's strong, great down force and inexpensive.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 03-16-2016, 10:35 AM   #19039
Originally Posted by tc5 man View Post
With it that dry a B5 would do better .
Originally Posted by nmdesertracer View Post
I would say the b5 would be better!
Thanks for your replies Even though I'd like to hear different. On thought I had:
The B5R has more weight on the rear axle (RA), the B5M FL should have nearly the same (or most likely) a little more weight. So the added weight would be partially at the RA. So if a (just a example) B5R weighs 1500 and the B5M FL 1650 it could be possible that both share (nearly) the same load on the rear axle. So the difference would be the longer distance between the wheels (dont know the english term) and that most of the mass (motor) is nearer to the center of rotation (which I think is good).
Are my thoughts wrong? What do I miss (as you can see I am looking for reasons that are pro B5M )
And ragarding the track: It's my first year there and I cant tell if the track is most likely to be that dry (like dusty dry) ore more likely wet sticky clay.
man1ac is offline   Reply With Quote
Old 03-16-2016, 12:16 PM   #19040
yeah The stock wings are rather cheap for a 2 packs on tower hobbies, maybe ill just stock up on those.
Old 03-16-2016, 01:26 PM   #19041
I was faced with a hard time cutting those curves with the one included
Team NovakŪ (1-touch programming)
Team Orion
ProLine
Dialed-RC Hobbies
TEN-SCTE 3.0/22SCT 3.0
Keith B is offline   Reply With Quote
Old 03-16-2016, 01:44 PM   #19042
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
dremel
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-16-2016, 02:03 PM   #19043
Kalio's Avatar
The stock wing never lasts very long for me. The sides of the wing seem to break the most easily. The Proline Trifecta wing lasts a long time though. What I started doing was use the Proline wing most of the time and use the stock wing only for racing (due to slight weight savings).
(Jason Shank)
Current: RC10B5m CE, RC10B44.3
Retired: RC10B4.2 RS
Tracks: Pitstop Hobbies, Bumps & Jumps
Kalio is offline   Reply With Quote
Old 03-16-2016, 02:05 PM   #19044
Flip boy's Avatar
The kit wing is awesome, if your somewhat wealthy then i like the jconcepts precut
Flip boy is offline   Reply With Quote
Old 03-16-2016, 02:17 PM   #19045
DennisNyholm's Avatar
I've been using my stock wing since I built the car and it is hanging in there. I spend a lot of time on my lid too. My finnisher body came with a 2 pack of wings so I think I am good for a little while.
DennisNyholm is offline   Reply With Quote
Old 03-16-2016, 04:07 PM   #19046
Originally Posted by Matt Trimmings View Post
dremel
Rotary tool you can guess where my first one is
Team Orion
ProLine
Dialed-RC Hobbies
Old 03-16-2016, 04:13 PM   #19047
+1 on the pre-trimmed b5m j concepts wing. I was going to order one from my local hobby store. I'll most likely buy that one at rc planet
Team Orion
ProLine
Dialed-RC Hobbies
Old 03-16-2016, 08:47 PM   #19048
just put together my b5m factory lite! been out of the hobby for some time now and decided to learn to solder. I think I'm pretty happy with the results! body painting still in progress though.
dcho87 is offline   Reply With Quote
Old 03-16-2016, 09:14 PM   #19049
TravisS27's Avatar
Trader Rating: 25 (100%+)
I had pretty good luck with my kit wing from last June til now. I just finally replaced it with a JC Finnisher wing to match my front wing.
AKA Tires
BOOMrc Graphics
Exotek Racing
RickyRacer Lidz
Jake's RC Topeka KS
TravisS27 is offline   Reply With Quote
Old 03-16-2016, 10:21 PM   #19050
Looking good and welcome back to the hobby! Great job soldering, the more you do it the better and easier it gets. Nice job bundling up the wires and keeping it clean too.
Body painting is something that I used to do but I just don't have the patience anymore for it. I found Diggity Designs and he does an awesome job for $35, worth every penny!! I just keep the single paint color body for messing around.
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
