    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-09-2016, 08:28 PM   #18871
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Originally Posted by JC8390 View Post
Do they loose noticeable power? Maybe its just me, but I don't notice anything lol.
They do. I can feel the edge fall off after about 3-4 laps. Then it runs "normal" for the race and begins to fall off again towards the end of an 8 minute run. Not to the point where you can't clear jumps or anything but just kind of soft feeling.
On a similar note, I stepped down a tooth for our 8 minute main last week and pulled the car off the track at 190. I went from 33/68 to 32/68 and gained a ton of heat with my 17.5. Normally I finish the main at around 150. I noticed the mesh sounded a little noisy on my warm up laps but when I checked it after the race it was fine. At that point, I noticed some roughness on the face of the teeth of my aluminum 32 tooth pinion gear. That's the only thing I can think of that would have caused the temp increase. Crazy....
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 03-10-2016, 08:06 AM   #18872
Mason's Avatar
68?
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 03-10-2016, 08:55 AM   #18873
Moderator
bds81175's Avatar
Slipper eliminator kimbrough gear
Tekno RC
Old 03-10-2016, 08:56 AM   #18874
Moderator
bds81175's Avatar
It might be 69 but my old eyes can't see it.
Tekno RC
Old 03-10-2016, 08:59 AM   #18875
JC8390's Avatar
Maybe that's why all the other guys look at me like I'm crazy when they park their cars before the race and I'm out there running laps like Ricky Bobby LOL. I probably take the edge off my battery long before it starts lol.
8ight E 4.0
Orion| Hobby Wing| Savox| Turnigy| AKA
RC10 B5M CE
Fantom| HobbyWing| Savox| Turnigy| JConcepts
JC8390 is offline   Reply With Quote
Old 03-10-2016, 09:05 AM   #18876
frankiebones's Avatar
Trader Rating: 16 (100%+)
hey does anyone know if 4wd front wheels will fit on a b5m FL without any rubbing? I have 2wd wheels that fit fine, but i have a greater selection of tires for my b44.3 and it just gives me a bit more versatility
frankiebones is offline   Reply With Quote
Old 03-10-2016, 09:14 AM   #18877
Silverstonev8's Avatar
Stock 44.3 wheels have a 10mm hex vs. the 12mm on the b5
Silverstonev8 is offline   Reply With Quote
Old 03-10-2016, 09:17 AM   #18878
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Plus they are wider than 'legal'. If your track doesn't care then you could but its probably going to feel weird.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-10-2016, 10:02 AM   #18879
stock is 9.5mm but i use 12mm hexes on my 44.3
Old 03-10-2016, 10:13 AM   #18880
Are you confusing hex size and offset?
boucher is offline   Reply With Quote
Old 03-10-2016, 10:30 AM   #18881
No, I am not sure how or why hex size is an issue.
The offset it the same on the b5 wheels and b44.3 wheels, except the b44.3 are thicker hense why they are rubbing. My question was is anyone was using the front b44.3 12mm hex wheels on a b5 without rubbing issues.
Old 03-10-2016, 10:35 AM   #18882
Dang. I was close...
Old 03-10-2016, 10:41 AM   #18883
Suspended
False, the B5 wheels are concave, while the B44.3 are convex. Basically if you set a B44.3 wheel face up on a table it is a dome shape from the outer bead to the mounting hole. The B5 wheel is gonna be the opposite. This pushes the B44.3 wheels further in than a B5 wheel, which causes the rubbing. Use the right wheels. Just that simple.
hasntaclue is offline   Reply With Quote
Old 03-10-2016, 10:56 AM   #18884
thanks that was what i was looking for.
Old 03-10-2016, 01:01 PM   #18885
JC8390's Avatar
Whats the advantage if any to the aluminum rear hub? I Just picked them up because the LFS didn't have the standard in stock and.... A Main.... is taking their merry time on my order.
8ight E 4.0
RC10 B5M CE
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
axoid
