    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 03-08-2016, 06:15 PM   #18841
Originally Posted by Matt Trimmings View Post
I'm not a huge fan (lol) of the waterfall mounts available...You pretty much have to run the Finnisher body, they dont work well with the silencer bodies. So I made my own, I hollowed out the stock waterfall and picked up the Schumacher KF2 fan mount. Mounted it to the cradle and attached a 25mm fan. When i initially started running with a fan it dropped temps roughly 25º.
That came out great, nice work!
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
Old 03-08-2016, 06:49 PM   #18842
JAE
Trader Rating: 28 (100%+)
Hx - I'm a noob, so anything to lower temps serves a dual function of allowing more runtime when practicing turning laps. Did you just dremel it out? Any issues with durability?
JAE is online now   Reply With Quote
Old 03-08-2016, 07:01 PM   #18843
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Yes. Dremeled out the stock waterfall and mounted the fan mount with a pair of xrings in between the cradle and mount so it has a little shock protection.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-08-2016, 08:16 PM   #18844
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
nice! can we see a pic of the wiring for the fan please?
TRCR, ARC r11 TC, hobbywing V3.1, TLR 22SCT™ 2.0, Team associated b6 buggy, futaba 4PX, Axial Wraith, Glamis Uno, Icharger 308, Simple Green, USMC
kjohnsiii is offline   Reply With Quote
Old 03-08-2016, 08:55 PM   #18845
Super Moderator
It just runs along the cradle and plugs into the spare channel on the rx.
Old 03-08-2016, 09:22 PM   #18846
kjohnsiii's Avatar
looking good! thanks
Old 03-08-2016, 09:41 PM   #18847
DennisNyholm's Avatar
Waterfall fan mount question: Anyone use these? Prime or Shapeways? Also, there are different sizes? Any tips on how much temps are down and weight addition much appreciated. Thanks!
I got a waterfall mount and use a finisher body. Just installed it recently and was bashing around in the street in 45 degree weather. Motor never got hotter than 75 degrees. I will be bringing it to the track in a few days to see how it works indoor and putting some actual stress on the motor.
I'm way under weight so it didn't bother me adding it as I would think the benefits outweigh the weight penalty. Planning on jumping up a gear or two on the pinion as well to see how it handles it.
DennisNyholm is offline   Reply With Quote
Old 03-08-2016, 11:44 PM   #18848
JAE
Default Waterfall
You should sell these. I would buy one from you. Imagine a lot of people out there that don't get the waterfall mount because they don't want to deal with either a new body or they like the AE body....
JAE
Old 03-09-2016, 12:23 AM   #18849
Super Moderator
All you need to do is Dremel the waterfall and solder the plug onto a fan. Amain sells everything you need.
Old 03-09-2016, 01:32 AM   #18850
Send a message via ICQ to intercede007 Send a message via AIM to intercede007 Send a message via Yahoo to intercede007
Thanks for all the tips fellas!
Just getting back into the hobby in a serious way. I've always previously built kits with allen keys. Picked up a 1.5MM and 2MM hex driver from the hobby shop. Couldn't believe the difference in how my hands feel after a few steps, as well as how tight I can get things. I thought that the chassis plates just wouldn't sit perfectly flush with the chassis when screwed together. I went back over them with the hex driver and it's mint.
Good tools make a difference, whodathink it
intercede007 is offline   Reply With Quote
Old 03-09-2016, 01:42 AM   #18851
JAE
Default waterfall
I didn't see a carbon fiber battery strap. I'm assuming you have a battery strap of some sort that fits under the mount, correct? and not taping in? thx again
JAE
Old 03-09-2016, 03:37 AM   #18852
Volition's Avatar
Running the soft prime waterfall with WTF windy fan, fan requires some modding, shaved top & notch for battery brace. Prime comes in 1 size but a hard and soft. This refers to how it connects, the soft has rubber o-rings on connection to transmission. This is for extra flex, hard is more like the AE firmness I would say. I don't use it.
Adds 20g in total. I'm getting 15°c cooler after 5 mins. Only a finnisher will fit, not a problem to me. I run 17.5t stock.
I'm really happy with it, great insurance for my motor with minimal to no performance loss.
Volition is offline   Reply With Quote
Old 03-09-2016, 07:05 AM   #18853
Quick question: What size turnbuckle wrench do I need for the B5M? I'm about to order a few parts and wanted to get a decent one to replace the cheap stamped one that came with the kit. Don't have the car with me to check the size.
Gearhead82 is offline   Reply With Quote
Old 03-09-2016, 07:20 AM   #18854
Super Moderator
I just tape the pack in. I was worried about it coming loose at first but I have to work it pretty good to get it out.
Old 03-09-2016, 07:23 AM   #18855
Super Moderator
Pretty sure it's 3mm
Ae sells one: http://www.amainhobbies.com/rc-cars-...-asc1111/p7958
Schelle has one that does all major sizes: http://www.amainhobbies.com/rc-cars-...10-blk/p300378
