Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Anyone using the 2.4" diameter wheel/tires nowadays?
Do they do any better than the 2.2" setups?
So I realized I might have had my setup off for a long time. A year ago when I got my B5 I messed around with setup to find what worked for me. Somehow i flip-flopped bumpsteer and ackerman shims. I had 2mm washer out on the spindle and zero washers on steering rack when I moved the trailing axle to 3mm trail. I switched them around tonight and gonna see what it's like for practice tomorrow.
Also going to add more limiters in the shocks...4 total in front and 3 total in rear.
Also found I was running zero washers on the rear inner link on the plastic bulkhead. Going to go back to 2mm there and hope for good results.
Sorry newish to rc, can someone give me a link to the k-springs that they are talking about here
Yea that's what I intend to do. I didn't describe that though. My bad
For a few more shots outside and in,
http://www.rctech.net/forum/members/...5-offroad.html
Im assuming that you are talking about getting the tape into the tiny areas..
oops rear motor internal photo is blurry. will try to fix that tonight.
