    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 03-01-2016, 12:08 PM   #18631
snwchris's Avatar
^^^ sounds like tire and throttle issue.
Most tracks I've been to, as you progress thru the day or night the track conditions do and can change. Like mentioned what worked earlier in the first round might not later. I usually have 2 or 3 sets of tires.
I just recently got into the 2w buggy class and one thing a lot of the guys at track told me was if your going to you your brakes a lot to turn them down so you don't lock up and spin out. The most I use my brakes for is mainly if it's a big double or step down to drop the nose a little.
snwchris is offline   Reply With Quote
Old 03-01-2016, 12:33 PM   #18632
Trader Rating: 25 (100%+)
Originally Posted by JC8390 View Post
This is a small handling issue... so I haven't mentioned it. I can easily drive around this, but it will also kick out a little if you get into the brakes hard at high speeds. I'm seeing this at the end of the straight away. You're steering right and in the brakes hard and its kicking the rear to the left then over steering into the right pipe. BUT this is if I drive it hard hard. I've been able to get around this by doing some braking with the wheels straight and by turning the brakes down some.. although between that and coming onto the straight away I know I'm loosing some time to everyone else. Other guys are able to get into power faster and on the brakes later. Then I'm running a cheapo 17.5 turn motor so Im getting burnt down this straight away lol.
I look at a result sheet... and guys 3-4 even 5 spots below me are running a faster fast lap than I am. So I know I'm leaving a lot on the table.
Tighten your diff a little.
joncmack is offline   Reply With Quote
Old 03-01-2016, 12:34 PM   #18633
JC8390's Avatar
Originally Posted by Wildcat1971 View Post
I use DR on my brake changes. And I check the breaks during the practice laps and adjust as needed if the track is changing. It sounds like you need to make a tire change in the 3rd qual and the mains, "if" the car is good in the first 2 quals. It is a common thing to change tires as the night goes on tracks with change traction levels. Some guys have a second set of tires ready. they run a practice lap, if the tires are wrong, their pit buddy does a quick tire change to get the on the right tires. you can make this as complicated as you like. But it sounds like a tire issue to me.
Well I put the hubs back.. and fixed the issue on my radio and calibrated my ESC. I actually had not done it yet LOL. I haven't ran a ton of electric lol. I just totally forgot to calibrate. I noticed it didn't feel right when I was adjusting it a few min ago.
JC bar flys seem to be the tire choice at this track.. should I find something with a larger pin or maybe just run a newer set of the same tire?? These are probably 40% pin. Which like I said... most of the time you couldn't ask for more out of the car. So maybe switch over to a newer set late in the day?
8ight E 4.0
Orion| Hobby Wing| Savox| Turnigy| AKA
RC10 B5M CE
Fantom| HobbyWing| Savox| Turnigy| JConcepts
JC8390 is offline   Reply With Quote
Old 03-01-2016, 12:49 PM   #18634
aeRayls's Avatar
40% pin on a bar fly is pretty much slicks haha. Yes switch to a newer set. Indoor racing is a huge tire game of pin height, inserts and tire sauce. Like I said before, tires are EVERYTHING!
Even a newer set of Barflys can only run in very little dust. I would have a set of well broken in (50%-ish) dirtwebs.
I don't go indoor racing without an entire bag of tires around here.
aeRayls is offline   Reply With Quote
Old 03-01-2016, 01:33 PM   #18635
What is the best thing to do on this car to pickup some easy rear grip?? My local track is clay and I notice sometimes towards the end of the day the high traffic areas of the track will get dusty and the car starts to kick out suddenly if you aren't really careful. I moved the rear camber link out on the hub which seemed to help...but it still breaks loose at times. And when it goes...it goes quick and stuff the nose right into a pipe before you can do a thing..no talking her out of it.
Running 17.5 turn motor, stock setup except for the rear link and I'm running the 3 gear transmission included in the champions edition. Running the same tires 90% of the guys at this track run...
Otherwise I've been really happy with the car.
i think the biggest thing to take from all the answers is.... go to your local track and talk with fellow track mates. Doesn't hurt to copy setups because when it comes down to it, whoever the better racer is going to win!
Electric---Team Associated B5M-Reedy 17.5-Team Scream-HobbyWing-Savox-Spektrum-ProLine-Jconcepts-Schelle Racing Nitro---Team Tekno NB48- Alpha Engines-NovaRossi-Proline-Savox-Spektrum
Wolcott Hobby,CT
itsdavedubail is offline   Reply With Quote
Old 03-01-2016, 02:02 PM   #18636
JC8390's Avatar
Im going to try a set of dirt webs I think!
8ight E 4.0
RC10 B5M CE
Old 03-01-2016, 03:20 PM   #18637
JC8390's Avatar
8ight E 4.0
RC10 B5M CE
Old 03-01-2016, 06:10 PM   #18638
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
When Dirt webs are worn in the middle they are perfect. Use a good tire sauce , personally I love love love SXT 3.0
Bar Flys, Type O's when brand new are great tires for high bite, compacted clay. Sauce em up and run 2 or 3 laps and they should ready to go. We run those, ghost slick Dirt Webs or slicks at our track.
Run some new Dirt Webs that extra bite will most likely solve 90 pct of your problems. They should last a good amount of time, but you'll need to get them scrubbed in before they really start gripping good.
Like everything track time and experimenting there and talking to the local fast guys to see the setups and tires they run, will yield the best results.
Try a change run a few laps and make notes before making another change.
What track do you run?
XRAY T4 17' //CRC Gen X SE- 17.5 GT//Xray X12-17' GT12//Xray X12-18' 17.5
check out the new 12th scale GT class!
https://www.facebook.com/groups/148391312353349/
JEFFs SC10 is offline   Reply With Quote
Old 03-01-2016, 06:25 PM   #18639
JC8390's Avatar
Sparks Park in Columbus Oh
8ight E 4.0
RC10 B5M CE
Old 03-01-2016, 06:46 PM   #18640
aeRayls's Avatar
Ok! Just go visit Jeff and Nathan Clark Brandon Marsh. They run for AE and JC and will get exactly where you need to be!
Old 03-01-2016, 06:49 PM   #18641
JC8390's Avatar
awesome, ill look em up
8ight E 4.0
RC10 B5M CE
Old 03-01-2016, 07:08 PM   #18642
I thought your description of the track sounded familiar! I'm just getting started there. Inching my way up the novice class.
I'm hijacking this info too. Thanks!
Gearhead82 is offline   Reply With Quote
Old 03-01-2016, 07:22 PM   #18643
Deaner's Avatar
Hey guys, just getting back into RC and have been eyeing the B5M, without pouring through this massive thread I just have a few quick questions.
I run on a backyard track, pretty good size (yes, my neighbors hate me) and have a FT B4.1 that I love. It works great, basically stock setup outside of stiffer suspension. I'm toying with the idea of moving to a new 2wd buggy, but am wondering in the mid motor buggy's would be the best choice for an outdoor track? My B4.1 has been so good to me I almost feel bad considering a different brand. And since it has been so good, I wonder if upgrading is even needed. My B4.1 is using a lrp ESC with 9.5 turn motor, and it's perfect for my track. Not too much, but just enough oomph to clear the bigger jumps. The larger jumps being a 18' long triple, and a 14' double. The B4.1 has been amazing as far as reliability goes, all I have ever broken was a shock tower and front arm when I clipped a pipe wide open. It's wore like iron.
So yeah, long story short. Is a mid motor buggy a good idea for outdoors? For those running on larger tracks, have you seen an improvement over the B4.1, .2, worlds, ect? Or should I quit worrying about it and enjoy my B4.1?
Thanks!
Tron funkin blow
Deaner is offline   Reply With Quote
Old 03-01-2016, 07:58 PM   #18644
Trader Rating: 20 (100%+)
Dirt Webs are usually the tire of choice there for the fast guys.
Randy
RandyJones is offline   Reply With Quote
Old 03-01-2016, 08:08 PM   #18645
Silverstonev8's Avatar
Originally Posted by BRSracing View Post
I cut the back brace . Cuthings the brace behind the servo is still a tight fit with that board on the esc.
Thanks for the input. I think if it's okay to cut a brace out completely I'll just notch mine a bit to make it fit. I'm assuming that's what people are doing since most pics I see with a 410 installed still have both braces.
Silverstonev8 is offline   Reply With Quote
