    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 02-19-2016, 12:24 PM   #18451
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Originally Posted by Greenbandit View Post
Do the cut gears require anything to spin free? Deburring, ect?
Depending on who it was that cut them, maybe.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 02-19-2016, 01:56 PM   #18452
I used the CB gears and they didn't require anything to fit and spin freely. Great quality! I am not sure if anyone else that sells them.
http://www.cbscustomrc.com/products.html
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
Old 02-19-2016, 02:03 PM   #18453
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
it depends, but. in any case, you need to break the transmission in. some guys use a wire brush on all of the diff gears to clean them up and smooth them out. essentially, helping the gear box break in faster.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-19-2016, 04:06 PM   #18454
What are you guys using as a scale to weight your cars? I just got the Sky RC corner weight system to check not only total weight but balance front to rear and side to side. I haven't used it yet on my CE but I did use it on my truggy. I'm going to race on carpet so balance is very important, at least it was in my sedan days. Any recomendations on front to rear balance (%)? I got the brass bulkhead (45g) and a Ti screw kit. I will post what I find out regarding weight. I have attached a pic of what I found on my truggy.
Anither question is regarding the Ti screw kit. It's a Protek kit but it says not to use it in high stress areas, shock mounts or places where locktite is required. So with that where do you guys don't recommend I use the Ti screws.
Also I just got the C and D mounts, the thing is the arms seem to have a lot of toe in. I installed the 2.5-1 inserts in the D block and arrows out in the C block. Any thoughts or suggestions?
jneg is offline   Reply With Quote
Old 02-19-2016, 04:37 PM   #18455
Silverstonev8's Avatar
Arrows should point in...
Silverstonev8 is offline   Reply With Quote
Old 02-19-2016, 05:39 PM   #18456
LOL I knew something was of...
Old 02-19-2016, 09:34 PM   #18457
Kalio's Avatar
I use the Sky RC corner weight system too. It's a really neat device. I wondered about weight distribution too, but for now my priority is just bringing the overall weight down. Once I get it closer to 1500 I'll start playing more with weight distribution.
As for titanium screws, a lot of people highly recommend the screws from Lunsford. I myself have bought a few Protek ti screws and they seem to strip a bit easily, so I would be hesitant about replacing all of my screws with them (right now I'm just using them for my button wing mounts and slipper eliminator). The Lunsford set is roughly twice as expensive but people say it's worth the price and I think they can be used anywhere.
(Jason Shank)
Current: RC10B5m CE, RC10B44.3
Retired: RC10B4.2 RS
Tracks: Pitstop Hobbies, Bumps & Jumps
Kalio is offline   Reply With Quote
Old 02-19-2016, 10:39 PM   #18458
Thanks for the reply. I will run mod with a 8.5 motor so the total weight is not such a big issue. I still want to get it down a bit. I used to race the B4 with a 13 turn double or a 11 turn single brushed motors in my outdoor track. I almost stripped one of the D mount screws so I they are not indestructible. But I did replace most of them without any issues. I didn't do the shock mounts on top or bottom. I'm waiting for confirmation on where not to use them Ti screws. Lunsford products are the best but $$$. Since I'm trying to be on a budget I couldn't get myself to spend more. Not right now anyway. I still have more cars to do so I will need more screws.
Old 02-19-2016, 11:23 PM   #18459
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Just2much19 View Post
I have along with many others on the forum, if you go back about 10 or so pages you'll see photos of mine.
Which lay down conversion? 3 or 4 gear? I used the lay down conversion from Shapeways 3D printing in 3 gear. I did not drill the two additional holes for the waterfall and I know of others who did not also. You have to trim pieces off of the side rails.
While I was in there I added cut down gears, carbide and tungsten balls and thrust cage as well as ceramic bearings.
If you are using the S2 body you will need to do additional cutting to the top of the motor plate.
Feel free to PM me if you have any specific questions.
thank you sir!! I have the Shapeways 3 gear and I wasn't planning on drilling either.
If you can send me more pics that would be great. I have my old aluminum chassis but I wanted to use this with my carbon fiber chassis.
i think this will turn out awesome.
XRAY T4 17' //CRC Gen X SE- 17.5 GT//Xray X12-17' GT12//Xray X12-18' 17.5
check out the new 12th scale GT class!
https://www.facebook.com/groups/148391312353349/
JEFFs SC10 is offline   Reply With Quote
Old 02-19-2016, 11:49 PM   #18460
JEFFs SC10's Avatar
Originally Posted by JC8390 View Post
I thought about the CF, just wondered if that or any aftermarket chassis had any adverse affects on the car. We all know the JConcepts name, Im not sure about the others that make the CF... which is why I was leaning that way. JC claims that chassis to be just as stiff and strong, just lighter.
You will notice a slight change, the JC chassis is nice but for only a measely 23 grams it's not worth it.
Now if you want a NOTICEABLE difference go with a carbon fiber chassis, that's what I run. Super light and just as strong yet has flex which creates more traction. The flex can be tuned with the side posts and loosening screws around the chassis.
I run X Factory but others run Plan B and are equally as happy. Both high quality kits.
Old 02-20-2016, 07:45 AM   #18461
For the slipper eliminator what spur gears are u guys using
ErikTheRcGuy is offline   Reply With Quote
Old 02-20-2016, 09:44 AM   #18462
Kimbrough
Old 02-20-2016, 01:49 PM   #18463
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
does the V2 top shaft work with 3 and 4 gear trannys?
RC*PHREAK is offline   Reply With Quote
Old 02-20-2016, 02:07 PM   #18464
Super Moderator
If it's the original 4 gear, no. If it's the new 4 gear case then yes, they are the same internals.
Old 02-20-2016, 02:09 PM   #18465
RC*PHREAK's Avatar
thought so. thanks matt.
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Dmkiefer
