    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 02-13-2016, 05:22 PM   #18346
Silverstonev8's Avatar
End to end the chassis is 11.25"
Silverstonev8 is offline   Reply With Quote
Old 02-13-2016, 05:33 PM   #18347
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
Getting the wrong stuff in a kit or defective parts.... yep...typical AE.
Probably a T5M chassis.
Dan is offline   Reply With Quote
Old 02-13-2016, 06:07 PM   #18348
eper's Avatar
Trader Rating: 14 (100%+)
hey eric i think he is running the ae aluminum c block but its possible its brass
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 02-13-2016, 06:29 PM   #18349
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
yep wrong chassis it seems.
I'd move on to building shocks and the gear box and maybe they can reimburse you for a chassis if you get it locally.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 02-14-2016, 07:40 AM   #18350
Default Gear Diff for Associated B5 / B5M - Part difficult to find
Hi - I am looking for a gear diff for B5 / B5M.
The part is ASC91461
At most online shop, it is in back-ordered status. Do you know if this part is discontinued ?
Julien
julieng is offline   Reply With Quote
Old 02-14-2016, 07:55 AM   #18351
suzukipro's Avatar
Trader Rating: 22 (100%+)
I just bought one, but had to buy the gear-set, outdrives and housing separately.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 02-14-2016, 08:42 AM   #18352
Just bought on in St Louis at mark twain Hobbies.Was a complete kit.They have a online store so try there
Astro is offline   Reply With Quote
Old 02-14-2016, 08:58 AM   #18353
Suspended
Trader Rating: 61 (100%+)
Originally Posted by nbartlet1 View Post
Hi,
I am building a champions edition kit.
I got to the third step, to secure the 'chassis cradle 91514' to the chassis '91510' (aluminum). Where the chassis cradle notches into the front chassis plate is fine, but the 6 m3x8mm bolts which are supposed to go from underneath the chassis into the chassis cradle, these simply do not line up. I see later on in the manual that the Chassis brace '91521' is secured also to the chassis, but those holes don't line up.
Did I get the wrong chassis brace? I checked the supplements to no avail. Thanks.
T5m chassis
Which is fine - throw it in the forsale forums and buy the SLRC chassis for your b5m.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 02-14-2016, 10:27 AM   #18354
This is great, thanks.
Does anyone know if I call AE customer support, would they send the correct parts? I'll try during the week.
nbartlet1 is offline   Reply With Quote
Old 02-14-2016, 10:44 AM   #18355
They will, I was missing a servo mount for my 44.3 and they sent me one. Just need to send them an email with copy (picture) of receipt or fax it.
Old 02-14-2016, 11:22 AM   #18356
Trader Rating: 5 (86%+)
I need some setup help please I'm running on medium to medium high grip clay. I have a real bad on power push 0ff power is perfect my setup is 4 degrees for the front axles. Outside on front arms middle shock Tower . rear is all the way in .on the arm its out. 3 and 1 on anti squat rear hubs in the middle white springs front and rear 1.6 front piston 32.5 oil rear is 1.7 piston 32.5 oil. On the rear hub and camber links has three millimeters on the inside 1 on the hub and all the way on the outside rear hubs ft alloy hubs
From a 210 to a b5m.I got the win
catfat is offline   Reply With Quote
Old 02-14-2016, 12:11 PM   #18357
Trader Rating: 33 (100%+)
Originally Posted by eper View Post
sorry for the delay i been busy at work. 1st of he runs the new mach 3 with a 7.5. new motors seem to have tons of bottom punch. also he runs a higher c rating battery. not sure which as i run for a different company. team scream and i run a 100c pack. again more throttle punch. and last hes running a shorter gear. he has a 78 and i believe about a 19. that will put the motor closer to axles. little farther back which may help. i run orion motors which are super smooth so my car doesnt do wheelies like his its more of a gradual power wheelie. also u may want to go on the web site for whatever esc your running and check where the pro guys are running setting. most importantly just cause your car isnt doing wheelies like that doesnt mean its not wrking well. i think he just likes to play before his run. hes keeping it fun which is what we should all do. and he wont think your creepy if u friend him hes a great kid killer personality and like to help out so check him out. if you want ill pass your name along to him so he can keep an eye out for u..good luck and keep it fun. and if u have anymore questions ill do my best to help u out anytime
Thanks a ton for replying to me. I contacted him and he said he'd send me his setup, he seems like a pretty awesome dude. Thanks again for taking the time to help me out.
FISHER_71 is offline   Reply With Quote
Old 02-14-2016, 02:15 PM   #18358
Jerm13's Avatar
Trader Rating: 36 (100%+)
My daughters car had the same issue when out track starts to get blown out and broken up. We put the other caster inserts in and it made a world of difference.
You can also add a couple weight chunks under the servo arm ( 2 chunks should be enough)
Good luck
Serpent Cobra-TE RCR Nova P5 / Serpent SRX8 Werks B7ProKE
AE SC10.2/////AE B5M CE/////AKA/////Serpent America/////Desoto Racing
Spektrum Radios and Servos, Tekin Speedo's and Motors, SMC Batteries
RC Pro Racing VA, Awesome Hobbies(RIP), Debbies RC World VA, Thunder Alley Raceway NC
Jerm13 is offline   Reply With Quote
Old 02-14-2016, 03:11 PM   #18359
Would 1.7 piston in rear cause push
Old 02-14-2016, 04:06 PM   #18360
ray_munday's Avatar
If you are running a super long rear camber link and low rear roll centre this may be hurting your on power steering. Normally we are running 3mm spacer on the hub, and on the inside rear hole of the hub (#2 hole as per this sheet: https://www.teamassociated.com/pdf/c...for-B5-B5M.pdf)
As mentioned below moving weight to the front (moving battery forward or adding weight at the front) will help on power steering, but can also hurt forward traction.
The 1.7mm rear pistons generally give more rear traction if its a little bumpy, but shouldn't be the difference between having on power push or not. Weight distribution and rear roll centre play a much bigger role.
Ray
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
