    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-09-2014, 11:27 AM   #1816
tropmonky's Avatar
Originally Posted by Matt Trimmings View Post
For you 17.5 guys....Aluminum top shafts are in stock at AE.
http://www.teamassociated.com/parts/details/91427/
This needs to be added to the front page...vv
tropmonky is offline   Reply With Quote
Old 03-09-2014, 11:47 AM   #1817
kingy1's Avatar
Don't hold your breath
Associated [RC10B5M - RC10T4.1 FT - RC10B4.1 WORLD'S - RC10B44.2 - RC8T CE-E - RC8BE]
Durango [DESC210R] Ofna [NEXX10SC]
RC4WD [Bully] Gmade [Sawback] Axial [Scx10 - Wraith - Yeti] Eagle Racing [R31]
kingy1 is offline   Reply With Quote
Old 03-09-2014, 12:15 PM   #1818
Send a message via ICQ to JiuHaWong
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 03-09-2014, 12:17 PM   #1819
lbckevin's Avatar
Trader Rating: 91 (99%+)
Talked with the guys at MIP at the JBRL yesterday and the B5 pucks are in the prototype stage and only a short while away.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 03-09-2014, 01:23 PM   #1820
Originally Posted by DG Designs View Post
Same here.
How did you get it to fit in the end?
moch8 is offline   Reply With Quote
Old 03-09-2014, 01:25 PM   #1821
mugenhatchie's Avatar
Lay spur down on flat surface, place vts on top all lined up, push down on it really hard. Or pick up a Jconcepts 69t and not worry about it.
mugenhatchie is offline   Reply With Quote
Old 03-09-2014, 01:37 PM   #1822
Double Dee's Avatar
abc 123
Darin Duncan. @ TRCR/BRCR
Double Dee is offline   Reply With Quote
Old 03-09-2014, 02:10 PM   #1823
Mxer59's Avatar
Trader Rating: 114 (100%+)
Does the Avid slipper need a special top shaft? I just tried to fit one on my car and it won't allow spacer and nut to even mount and using the stock spring and spacer it won't tighten down
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 03-09-2014, 02:14 PM   #1824
Graham11's Avatar
Trader Rating: 21 (100%+)
Hey guys, does anyone have experience w an rb6 and the b5 platform? Very torn on what to buy, either the rb6 or both b5 r and m. Also important to note is I currently run a c4.2
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 03-09-2014, 02:21 PM   #1825
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Nope, works fine. I am using the triad spring, had to drill out the silver washer that goes between the nut and spring because of the 4mm threads. You could get by with just using the nut because it is wide and covers the spring.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-09-2014, 04:16 PM   #1826
predu's Avatar
So i went thru 8 front wheel bearings yesterday. Did some measuring found the front clamping hexes are 9.85 mm when clamped and stock front axles are 10.12. Basiclly associated f'ed up and made them too narrow and it destroys the. bearings.and no my stock axles dont have the too tight issue.
SC10.2 , LRP, SCHUURSPEED 17.5
B4.2, LRP, SCHUURSPEED 17.5
TC6.1, LRP, SCHUURSPEED17.5
TC7 , LRP, SCHUURSPEED 17.5
10R5.1, H/W, SCHUURSPEED 17.5
predu is offline   Reply With Quote
Old 03-09-2014, 04:24 PM   #1827
Trader Rating: 29 (100%+)
are you able to use the b4 avid traid slipper on b5m?
thanks
ronzo is offline   Reply With Quote
Old 03-09-2014, 04:25 PM   #1828
Super Moderator
thanks
There is only one triad slipper system. It fits the B4 series, B5 series, TLR 22 and RB6 with the avid top shaft.
Old 03-09-2014, 05:12 PM   #1829
tc1
Trader Rating: 15 (100%+)
Wired and ready, minus the slipper anyways. Assembly went great, no issues to speak of!!
Travis
tc1 is offline   Reply With Quote
Old 03-09-2014, 05:19 PM   #1830
moto44's Avatar
Trader Rating: 9 (91%+)
Any word on when the next batch of B5m will hit?
Barnstormers Raceway
Critters
________________________
moto44 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
rinferno
