    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 02-04-2016, 09:53 PM   #18211
Originally Posted by duckhead View Post
Silly question, but what are you guys using to clean your FT blue seal bearings to get the grit out? Curious if old faithful motor cleaner was still applicable or if folks were maybe using crazy ultrasonic cleaners now I just want to make sure I am not eating up the seals before their time is due.
Also what kind of oil/lube are you using after cleaning them?
Thanks!
I would use would be motor spray and lubricate with a synthetic oil. I've purchase this lubricant pen that I can add any lubricant to. It works great for items like this and fits right in my RC box.
To be honest bearings are relatively cheap to replace and I would recommend that. Avid sells bearings with the rubber seals for a buck a piece. Take you old ones to clean and use as backups.
Just2much19 is offline   Reply With Quote
Old 02-05-2016, 03:56 AM   #18212
Do you have the name or a link for the lubricant pen you're talking about? Sounds like a good idea.
Gearhead82 is offline   Reply With Quote
Old 02-05-2016, 07:05 AM   #18213
thecman26's Avatar
Trader Rating: 99 (100%+)
Honestly if you know a diabetic person who uses insulin.
You could just borrow a syringe, would work perfectly!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 02-05-2016, 07:14 AM   #18214
Mason's Avatar
I'm not sure "borrow" is the proper term here. I have a feeling no diabetic really wants it back after you have used it.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 02-05-2016, 07:26 AM   #18215
Lol...
youngrigo is offline   Reply With Quote
Old 02-05-2016, 07:53 AM   #18216
thecman26's Avatar
Bunch of smart A's in here isn't there?
Old 02-05-2016, 08:08 AM   #18217
Darkstarr's Avatar
Default Need a Bit of Info
Hello fellas , I'm doing the Championship Edition upgrade on my . 5M ! My question is ? Do I need to get a different Top Shaft ? Because the one out of the 4 gear trans won't fit , the Bearing. Any help would sure be Appreciated ! Thank You Lorne M Slan
Aaron Pearsons Paint Shack !!!! !! Jakes RC Pro Am . S&S Pettyjohn Motorsports BIG midget Racing Ent!!
Darkstarr is offline   Reply With Quote
Old 02-05-2016, 08:43 AM   #18218
it would appear that the proper bearings are included in the CE kit.
bshack is offline   Reply With Quote
Old 02-05-2016, 09:05 AM   #18219
CCristo's Avatar
Trader Rating: 55 (100%+)
Search eBay for pen oiler. There are several variations.
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 02-05-2016, 09:12 AM   #18220
MiCk B's Avatar
Hi,
Avid to empty pen oilers:
http://www.avidrc.com/product/5/acce...cessories.html
MiCk B. :-)
http://www.dublinmodelracing.com
http://www.p-dubracing.co.uk
http://www.msdmodels.ie
MiCk B is offline   Reply With Quote
Old 02-05-2016, 09:36 AM   #18221
https://www.amazon.com/dp/B000KKHNU0..._V5mTwb7KHNEKE
This is the one I used. Won't get banged up and crack in your tool box and it is refillable. The others would work well if you are just keeping it home or in a safer place.
As for a syringe, if you are not used to working with them then stay away from them.
No need to go crazy with the oil though, just enough in there to coat everything.
Old 02-05-2016, 12:46 PM   #18222
You need the new top shaft part # 91606. It uses the same bearings as the idler gear shaft.
islandscott is offline   Reply With Quote
Old 02-05-2016, 12:54 PM   #18223
Just received my SMC 4400mah packs and I have to say I'm digging the shorty packs..lol
I guess it just didn't sink in how much smaller they are till I got one in my hand next to a 5000 standard..
Tires and wheels should be here tomorrow and then I just need to settle on what electronics I want to order. Then the rewiring..
RcJunky76 is offline   Reply With Quote
Old 02-05-2016, 02:06 PM   #18224
I just ordered two of the same packs, can't wait to get them. I have to do a re-wire too, I'll save that for last.
Old 02-05-2016, 02:28 PM   #18225
There nice packs and only took 3 days to get to me so am very happy.
I'm waiting to get everything together before I even attempt at wiring. Being my first buggy this is very tight and I want everything figured and in place before I tackle what at this point is looking like a cluster..lol
Oh and if you have the side foam in battery tray you will need to remove. The packs are tight side to side..
