    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-31-2016, 12:15 AM   #18076
aeRayls's Avatar
Originally Posted by the big rc View Post
Question, does the championship edition come with a gear or ball diff?
Ball
aeRayls is offline   Reply With Quote
Old 01-31-2016, 12:31 AM   #18077
Quad_Addict's Avatar
can i ask what the typical or ideal weight of a b5m lite or reg factory team buggy should weigh for 17.5 spec class? ( minus battery)
im only asking because my son drives a b5m lite with LRP Gear and im running Blackbox 410r and mach3 both 17.5, my factory team with 410/M3 is much heavier but still faster, which ever of us is driving either or. the esc def outweighs his LRP, i dont want to add a bunch of more aluminum to these cars and make them heavier if it hurts us in times.
appreciate any insight.
Quad_Addict is offline   Reply With Quote
Old 01-31-2016, 05:02 AM   #18078
I believe it comes with both.
Gearhead82 is offline   Reply With Quote
Old 01-31-2016, 05:25 AM   #18079
Originally Posted by aeRayls View Post
Ball
X2 mine came only with a ball diff.
Ghk700 is offline   Reply With Quote
Old 01-31-2016, 06:02 AM   #18080
Huh that's strange. Their website shows a "gear diff supplement" manual for the CE so I assumed it came with both but I guess not.
Old 01-31-2016, 06:51 AM   #18081
I'm building my CE now and see now parts or instructions for a gear diff.
This is my first AE kit and I have to say that the quality is awesome and I'm really enjoying this kit. May end up on a shelf..lol
RcJunky76 is offline   Reply With Quote
Old 01-31-2016, 06:52 AM   #18082
Weight might not be the problem. I've run a stock car anywhere from 165ish to 1510 and I personally couldn't tell if it had more rip or not. Gearing and timing on the end bell can make a huge difference, and every motor is slightly different and could need different things to get the best performance
Hyperhobbies.ca
Rcbatterydepot.com
lee111m is offline   Reply With Quote
Old 01-31-2016, 08:03 AM   #18083
Mine is being delivered tomorrow and I'm excited! My first kit and first R/C in about 10 years. Glad to hear it's a quality kit.
Old 01-31-2016, 09:03 AM   #18084
1/4milecrazy's Avatar
ROAR minimum weight for 17.5 buggy is 1499 grams. In a spec class where power is limited you want to be as light as possible to take advantage of the available power. Some people might like a little more weight depending on conditions. My B5M weighs 1520 as it hits the track. The little extra weight just makes sure that an inaccurate scale at another facility doesnt force me to add weight.
I would shoot for that 1499 limit, or get as close as possible with either lightweight parts or add weight where needed. The nice thing about adding weight to a light car is that the weight can be added where it could be beneficial. Taking away weight in the drivetrain and adding it to the chassis where you need it can beneficial in both speed and handling.
Apparently "equal" and "partners" means different things to different people.
1/4milecrazy is offline   Reply With Quote
Old 01-31-2016, 01:29 PM   #18085
Trader Rating: 485 (100%+)
All of my stock B5Ms felt best between 1530 - 1550 grams. I was able to get one down to 1411 grams with a chassis liner and it never felt quite right but I was the only stock car that could hit our triple for an entire 5-7 minute race. One of the key tuning items I use is the battery. You can cut a load of weight just by using a light pack.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 01-31-2016, 05:01 PM   #18086
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
What gearing is better for 17.5 69/31 or 78/23? Im running Tekin RS and Tekin gen 3 motor. Tekin motor is at 30 degree timing and 10 boost in ESC. 10 boost felt faster then 30 timing in the esc.
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 01-31-2016, 05:05 PM   #18087
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
69/31 is ticket depending on track size.
You can't run boost in stock 17.5 classes fyi.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 01-31-2016, 05:06 PM   #18088
JEFFs SC10's Avatar
My buggy is now around 1480-1500 . I put a carbon fiber chassis on it. The lightweight helps acceleration when you have a small run up to clear a set of jumps and it helps corner speed in my opinion.
Heavier will be easier to drive but won't have that get up n go.
XRAY 2017 T4
Xray X12-17' GT12
Old 01-31-2016, 05:10 PM   #18089
thanks small to med carpet track we are working on.
Old 01-31-2016, 05:19 PM   #18090
JEFFs SC10's Avatar
try it that's the best way to know for sure.
get the setup right for carpet that'll be the ticket.
XRAY 2017 T4
Xray X12-17' GT12
