    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 03-08-2014, 06:54 PM   #1786
the stock setup is a general idea for what might work at various places and drivers.. where you need to go from here is find what you want more or less from in your car and adjust to your liking.. piston and oils will vary depending on tracks and jumps..
I am running a 4mm spacer behind battery for stock and a shorty if the track is looser... if a little more traction I run 2 spacers behind it... in mod I run a square pack .
I think the rear hub forward makes a big difference in traction.. am also using 2 deg. neg camber in back and 1 neg in front.. 0 toe in front.
driving style also comes into play.. I let a friend of mine drive my car and he races for another brands team.. I laughed as he said my car had to much traction and to much steering everywhere for him.. he likes to have his car whip in the corners . funny thing is when he had good laps he was 2-3 seconds a lap faster with my car then his...lol
rickster is offline   Reply With Quote
Old 03-08-2014, 08:11 PM   #1787
Originally Posted by Wild Cherry View Post
personally just spin a wheel at slow speed for a minute and readjust.
check right after first pack to see if it needs to be tighten.
Adjust so you cannot spin wheel with out turning the pinion & motor or kinda tight ..
Yeah, that's what I normally do. I leave it a little lose, spin one wheel for about 30 seconds, then adjust the tightness.
This one just wasn't all perfectly smooth like I'm used to. I'll be working on it tonight. We'll see.
Thanks for the tips.
B5M & Stock Spec Slash.
The Certainty Principal - "Only the person who doesn't fully understand the problem has complete certainty about the best solution and its consequences. Certainty is proportional to the square of Ignorance (C≈IČ)"
Corners is offline   Reply With Quote
Old 03-08-2014, 08:35 PM   #1788
Well here is my almost finished wiring, I just need to get rid of the dean connectors and solder the wires to the motor. It came out cleaner then I thought but Im still not sure about it.
chancejeff is offline   Reply With Quote
Old 03-08-2014, 08:46 PM   #1789
Trader Rating: 488 (100%+)
Stupid question. Will a Centro body fit on it?
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 03-08-2014, 09:00 PM   #1790
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Some of the guys that have been running the JConcepts finisher on the B5m... but it is really flared out on the sides.... it fits but does not look like it's meant to be on there
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ”
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 03-08-2014, 09:03 PM   #1791
Tradin Paint's Avatar
Not a stupid question. Yes, I know the JC Finisher for the Centro will fit
Happy with: Team Associated, Team Tekin, Airtronics, Avid, JConcepts, Fantom motors and Aero Model batteries.
Proud Supporter of Warehouse 3 RC Hobby Shop, that just happens to have an indoor track
"Because Size Does Matter"
Ryan H.
Tradin Paint is offline   Reply With Quote
Old 03-08-2014, 10:27 PM   #1792
harold56's Avatar
Have any of you had your kits come with silver shocks. I thought they were going to be green like all of the FT shocks for the last 20+ years.
The hardest part of finding a solution is finding the REAL problem.
harold56 is offline   Reply With Quote
Old 03-08-2014, 11:55 PM   #1793
Tech Legend
Wild Cherry's Avatar
Be on the look out for the alloy rear hub sets ...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 03-09-2014, 12:02 AM   #1794
Trader Rating: 26 (96%+)
Coming soon I hope? My RM kit was missing some hub inserts.
Hope the production alloy rear hubs have the option for the set screw to eliminate slop.. didn't look like Thielke's had them
ntJeff is offline   Reply With Quote
Old 03-09-2014, 04:05 AM   #1795
Trader Rating: 8 (90%+)
Just to add to the list of QC issues, I saw a B5M today with one drive shaft too big to go the diff slot. Then again, it could be the diff being too small for the drive shaft. I sure hope AE is going to ensure better QC for the 2nd batch.
juicy74 is offline   Reply With Quote
Old 03-09-2014, 06:58 AM   #1796
anyone else have trouble fitting the slipper housing onto the 72T spur gear? Mine just doesn't want to squeeze in though it sits fine in the 81T spur
moch8 is offline   Reply With Quote
Old 03-09-2014, 07:41 AM   #1797
TonyWest's Avatar
Trader Rating: 50 (100%+)
Default wild cat
Do you have the inserts for the alum toe blocks. They did not come in my kit.
WALDORFRC.com
301-932-9193
Team Associated / AKA / Byrons Fuel / Futaba
TonyWest is offline   Reply With Quote
Old 03-09-2014, 07:41 AM   #1798
Same issue, had to get a different spur.
John C is offline   Reply With Quote
Old 03-09-2014, 07:48 AM   #1799
Yes. I fought with it for a while and finally got it to go. I was about to put some heat on the spur, but the brute force method finally worked. They need to fix that in the next batch.
Old 03-09-2014, 08:03 AM   #1800
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
Yes sir I had the same thing with the 72 spur
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
