Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
I need more steering with my B5 mid to exit on indoor clay. What kind of chances would you start with?
I just went on the pre-order list at Amain for a factory lite B5M...Now, I wonder just how long it will take.
anyone hearing anything about a FT edition ever coming out?
I just have such massive grip on the rear (17.5 motor) and so much weight back there, that I don't think I can tune it out without adding weight in the front
I too do not want to be anywhere near anybody charging at crazy high amps. too much risk of fire to gain a tenth of a second
Thinking of getting MIP pucks for Mod running. Pros/cons? Running a 7.5/8.5 for various tracks and getting pin wear faster than I'd like. Wondering if pucks are easy to maintain and last or are there issues?
I am currently fighting a on power steering issue (or lack of) that I just have not had time to figure out. Its driving me a little nuts. I think if I drop down in the shock oil, it will help over all. The rebound seems slow and I am thinking that it is causing some issues... I need some time on the track. lol
air8, you may be over-doing it with your ball diffs. All that's necessary is build to the instructions and a small break-in after installing (one wheel on the table, one in the air, 1/4 throttle for 30-60 seconds, do once on each side if you want to be really thorough). As long as the slipper breaks loose before the diff, then the diff should last as long as the lube in it is good, which can be a long time. I don't work on my cars at home, ever.
Idk. Tomorrow I will give a refresh a go. Been several months since the last rebuild.
Thanx guys.
Just saw this too..
http://www.teamassociated.com/cars_a.../Factory_Lite/
Just looked on their page...didn't see any info about anything except the new LITE..
Just saw this too..
Recently began using the MIP Pucks in Mod Buggy. So far they seem to have great wear and durability characteristics. It's simple to replace the plastic pucks vs getting outdrive wear, but I don't think they are a must have for modified racing.
Being new to the hobby and just getting one of these , do you guys have any preference or guidance on what gear set up I run or any other new guy advice.
Hudy Off-road Set-up Book
http://www.hudy.net/xhudy/showfile.p...2bef0706315e0c
