    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-08-2014, 07:41 AM   #1756
Originally Posted by mugenhatchie View Post
The MIP B4 Shaft will not work.
Right, totally forgot this car is metric.
iVoid is offline   Reply With Quote
Old 03-08-2014, 08:02 AM   #1757
Originally Posted by Wild Cherry View Post
very common mistake is to overtighten the diff & dent a ring or flat spot a carbide diff ball. Also common to loose a bearing for the thurst bearing.
Disassemble and have someone with experience help.
The gear diff is the best choice if running on extreme high traction or carpet.
On clay the ball diff's performance is better by offering more traction.
BTW
No need for ceramic thrust , steel performs the same and has the same durability.
But you will need ceramic diff balls for their performance & extra durability.
I took it apart several times, flipped the rings, no dice. Notchy. I've built ball diff's many times. Never had this problem. I'm guessing one or more of the balls are defective.
B5M & Stock Spec Slash.
The Certainty Principal - "Only the person who doesn't fully understand the problem has complete certainty about the best solution and its consequences. Certainty is proportional to the square of Ignorance (C≈IČ)"
Corners is offline   Reply With Quote
Old 03-08-2014, 08:09 AM   #1758
Mxer59's Avatar
Trader Rating: 114 (100%+)
Originally Posted by ntJeff View Post
Depends on the size track you have, for a smaller track an 8.5 should be more than enough. I know most of the team drivers run 8.0 pretty much everywhere it seems.
What's possibly a good gearing for a 8.5?
In my 17.5 I run a 72-32-33
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 03-08-2014, 08:13 AM   #1759
Has anybody had issues with their motor shaft hitting the gear cover? I have a Murf Dog synergy and the shaft will not allow the cover to go on. It has worked fine in anything else I have tried. Just curious if others are experiencing the same.
mx836 is offline   Reply With Quote
Old 03-08-2014, 08:21 AM   #1760
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
According to the manual......22/81
It is known that some motors with longer shafts hit the gear cover. I've heard of some issues with novaks as well. You could dremel the cover a little or heat it up and push it out a bit, i think some have dremeled the shaft down as well but i wouldnt want to do that.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-08-2014, 08:32 AM   #1761
celt's Avatar
Default finished the roller...
No issues whatsoever and no missing parts. Good luck maybe. $250.00? Buy two at that price.
Our local track is going to get a new layout soon, with the point being the traction isn't as high as it can be.
I witnessed Chad Due, break the track record after running his second pack through the car. Strange thing is, he didn't appear to be driving on edge at all. I suspect that there is a ton left in the car yet.
I'm thinking the car works.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 03-08-2014, 08:56 AM   #1762
jaracer's Avatar
Thumbs up
Ran my B5M Wednsday night at IERC and it works well right out of the box. Only made minor changes to ride hight and camber and it just got better. So far I love the car.
jaracer is offline   Reply With Quote
Old 03-08-2014, 09:30 AM   #1763
kingy1's Avatar
Pin wheels will fit over the drive pins but you would have to also use the axle spacer that goes behind the pin from the B4.
Cheers, good to know. I'll pinch the spacers from my b4.1, save wasting rubber or acetone-ing them off
Associated [RC10B5M - RC10T4.1 FT - RC10B4.1 WORLD'S - RC10B44.2 - RC8T CE-E - RC8BE]
Durango [DESC210R] Ofna [NEXX10SC]
RC4WD [Bully] Gmade [Sawback] Axial [Scx10 - Wraith - Yeti] Eagle Racing [R31]
kingy1 is offline   Reply With Quote
Old 03-08-2014, 09:50 AM   #1764
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Silly question, but does the reedy motor fit inside the gear cover without modding? I would assume yes, because I am sure AE did their testing with the reedy, lol. but thought I would ask
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-08-2014, 10:01 AM   #1765
Super Moderator
Yes the reedy fits. Most motors fit fine, but there are a few that have a longer shaft.
Old 03-08-2014, 10:07 AM   #1766
cool. Now I just need HT to get some inventory.....
Old 03-08-2014, 10:29 AM   #1767
kingy1's Avatar
I sure hope it fits, I've got a sonic 9.5t to put in mine
Old 03-08-2014, 10:48 AM   #1768
thecman26's Avatar
Trader Rating: 99 (100%+)
I put a Reedy Sonic Mach 2 10.5t in mine, fit perfectly!
This kit was a DREAM to build! Dare I say "Kyosho" quality!
Diff is beautiful and smooth (but I did use ceramic balls and Avid caged cermaic thrust). Shocks are perfect! Thanks AE for a QUALITY kit that was cheap as well!
Granted it was a RM kit I buit. Cant get a MM kit...
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 03-08-2014, 10:50 AM   #1769
gticlay's Avatar
Then you suck at building diffs because something like 10,000 B4 and B5 diffs haven't had your issue. Sheesh.
gticlay is offline   Reply With Quote
Old 03-08-2014, 11:03 AM   #1770
rigor's Avatar
Trader Rating: 38 (100%+)
I used loctite on the front axle screws and the ballstud that goes into the rear hubs. Some are using a longer ballstud and backing it with a nut. Use loctite sparingly, dont coat the threads...a little will do it.
I used a very small amount of loctite on these 2 areas as well, and have had zero issues of anything coming loose, let alone off. I hadn't driven RC in nearly a year, so my car got some durability testing during my first handful of packs through it
Driving skills came back pretty quickly though. I was really having a good time by about my 4th or 5th pack.
* Jesse H. *
rigor is offline   Reply With Quote
