    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-08-2016, 07:43 AM   #17671
thecman26's Avatar
Trader Rating: 99 (100%+)
Originally Posted by Matt Trimmings View Post
Maybe one that's actually available?
Really? Had no problem getting mine!
There's also this one.
http://www.smc-racing.net/index.php?...rice&order=ASC
Best bang for the buck batteries and are totally worth the wait!
Who else can even come close for the $?
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 01-08-2016, 07:47 AM   #17672
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Those are still pre-order only...same as the others. The one time I ordered a SMC shorty I got 2 of them. They both came with a bulge.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-08-2016, 07:50 AM   #17673
thecman26's Avatar
Never had that with any of my packs. They had a problem with a shipment of full sized packs back when but Danny took care of everybody and replaced the packs. Shorties I haven't had a single issue with so far and the new 100C packs have some pretty good IR's!
It's kinda hit or miss with Turnigy packs but they are pretty cheap though!
Old 01-08-2016, 08:28 AM   #17674
Super Moderator
This was a few years back. I am also looking for some new shorties and cant find anything good in stock.
Old 01-08-2016, 08:50 AM   #17675
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
I just can't get myself to "pre-order" batteries without knowing a ship date, I just can't.
I've seen way to many SMC packs puff. Maybe it was a bad batch and those days are gone, I don't know. But I just can't wrap my head around Danny's comments that "all lipos puff/swell when you run them. You just notice it with ours because our cases fit so tight." (not an exact quote but you the point)
I Danny's defense, tons of people swear by SMC. I'm just not one of them.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 01-08-2016, 08:53 AM   #17676
Super Moderator
That is exactly what I was told when my packs arrived in the 'pre-puffed' state. They stuff soo much pack into a super thin case that its going to puff. Nowadays with how the battery strap goes into the waterfall a puffed pack will create an issue...the strap needs to float in that region, not be jammed up in there. The chassis cant flex properly if the strap/pack wont let it.
Old 01-08-2016, 10:26 AM   #17677
Originally Posted by tsair View Post
Maybe your inner slipper plate is wrong? For the VTS, there are two different plates, the inner one has a small nub and there should not be much of a gap between the motor plate and the slipper plate. The outer one has a big nub for the spring to go around.
Here's the inner one, which is different:
http://www.amainhobbies.com/rc-cars-...sc7485/p176105
Another possibility is the spring, it looks a little weird, but hard to tell if it's the correct one or not from the picture. It should seat nicely up against the plate.
So I the nut wasnt perfect on the thread, now I changed it and I gained about 1mm...this shown setting would work perfect in slipper conditions...giving throttle and the B5 gets up about 2inch!
I also added a picture showing the distance between the spur and the motor plate!
If I leave the spring washer it looks perfect!
Team Associated RC10 B5m Mid-Motor Thread-2016-01-08.jpg   Team Associated RC10 B5m Mid-Motor Thread-2016-01-082jpg.jpg
man1ac is offline   Reply With Quote
Old 01-08-2016, 10:32 AM   #17678
mr240's Avatar
Trader Rating: 61 (100%+)
Still does not look right. Eventually that nut will come off.
mr240 is offline   Reply With Quote
Old 01-08-2016, 10:54 AM   #17679
Super Moderator
Take the spring washer off..you don't need it. If you aren't engaging the locking part of the thread its going to come off.
Old 01-08-2016, 11:05 AM   #17680
Suspended
I ordered one of SMC's best 2S shorties.
It arrived puffed, I cycled it easy at 15 amps up/down 6 times. Then I hit it with 40amps and it puffed hard and the IR numbers were garbage.
I'll never buy a SMC pack again.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 01-08-2016, 11:06 AM   #17681
Even if the nut hast 1mm free thread I think it would hold...I can feel the nut having grip.
Did so already
Problem solved, but the question remains: How did that happen? I tighten and fitted everythin as best as I could...there seems to be no mistake...could I use the wrong slipper hub (not the outer)?
Old 01-08-2016, 11:47 AM   #17682
Super Moderator
Trader Rating: 17 (100%+)
whats funny is I bought a new 4000 too and it's cycling at 1.5 IR with 30 amp discharge, 20 amp charge.
my old 4300 packs (Not the 4400's) are still pulling low 2's
I've only used SMC so I don't have anything to compare them to.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 01-08-2016, 11:57 AM   #17683
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I have not tried the new 4000s, but the packs from 18 months ago were puff monsters. And when I cycled them they are always about 400-500 mah short of the label. but for $35 what can you really expect
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-08-2016, 12:05 PM   #17684
tsair's Avatar
Your inner slipper plate/hub looks OK in the pic, the spring does tend to wear in a bit, it might just need to get broken in. Also after you scrub in the pads, you will probably have to tighten it a bit.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 01-08-2016, 12:10 PM   #17685
Did you compress that spring with pliers a few times to get it worked in? That spring does dot look compressed enough!
bshack is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
axoid
