    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-07-2016, 10:14 PM   #17656
This thread seems to be way more frequented:
Can anyone give me some help. I'd lilke to have my slipper issue solved before going to track tomorrow
thanks!
man1ac is offline   Reply With Quote
Old 01-07-2016, 10:17 PM   #17657
tsair's Avatar
thanks!
Something's not right there, the nut should be flush with the end of the topshaft. You should be able to hold down the rear tires, give the car a burst of full thottle and lift the front wheels a couple of inches.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 01-08-2016, 12:28 AM   #17658
I totally agree.
I bought the B5 pre-build from Thuntertiger (the german AE distributor). I was not completly satiesfied with the Slipper, so I bought the VTS Conversion Kit (FT VTS Slipper Conversion Part #: 91175) and installed it like it is ony the SC5M (see picture for building style in general).
What did I do wrong? It seems as if I need a longer Shaft/Thread
Team Associated RC10 B5m Mid-Motor Thread-testbericht-associated-sc10-4x4-ft-2.jpg
Old 01-08-2016, 01:05 AM   #17659
aeRayls's Avatar
I totally agree.
For one, the B5 kit comes with the vts slipper to begin with, since someone built it and it didn't come with it, they obviously put something else on there.
For two, just use some pliers to compress the slipper spring then reinstall everything and see if that solves your issue.
aeRayls is offline   Reply With Quote
Old 01-08-2016, 02:06 AM   #17660
Thats what I've been told by a collague, so I kind of got the wrong slipper.
There is no option part I am pissing or something? Maybe they added a wrong spring, too?
Old 01-08-2016, 02:22 AM   #17661
tsair's Avatar
Maybe your inner slipper plate is wrong? For the VTS, there are two different plates, the inner one has a small nub and there should not be much of a gap between the motor plate and the slipper plate. The outer one has a big nub for the spring to go around.
Here's the inner one, which is different:
http://www.amainhobbies.com/rc-cars-...sc7485/p176105
Another possibility is the spring, it looks a little weird, but hard to tell if it's the correct one or not from the picture. It should seat nicely up against the plate.
Razor RC blog:
Old 01-08-2016, 02:30 AM   #17662
Okay thanks! Will check it out when I am home again...
Old 01-08-2016, 06:30 AM   #17663
Svendc's Avatar
anyone who tried this motorplate?
saving some weight in the the rear of the car gives more steering...
http://www.amainhobbies.com/rc-cars-...mp2406/p479303
VBC Wildfire D08
AE B5M CE
Svendc is offline   Reply With Quote
Old 01-08-2016, 06:39 AM   #17664
DennisNyholm's Avatar
It seems the protek 2s 4250 mah shorty packs are sold out everywhere. Can anyone recommend a good battery in the $60 range? I placed a back order through amain but wondering if they are ever coming back in Stock!
DennisNyholm is offline   Reply With Quote
Old 01-08-2016, 06:41 AM   #17665
thecman26's Avatar
Trader Rating: 99 (100%+)
SMC 4000mah 100C shorty: $39.95
http://www.smc-racing.net/index.php?...product_id=338
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 01-08-2016, 06:55 AM   #17666
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Originally Posted by thecman26 View Post
Maybe one that's actually available?
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-08-2016, 07:08 AM   #17667
Svendc's Avatar
http://www.hobbyking.com/hobbyking/s...Approved_.html
I use them in my 2wd, and normal size in my touring car, very common used in my regon and very good comments for the price.
VBC Wildfire D08
AE B5M CE
Old 01-08-2016, 07:12 AM   #17668
Yeah, I looked at the turnigy packs as well but coming from China they won't get here for 3 weeks I assume?
Old 01-08-2016, 07:26 AM   #17669
Finalist's Avatar
I got through the first couple parts of the Champions Edition build last night.
Why do the CE supplement instructions call for 6mm ball studs on the steering rack with NO 2mm washers when the standard issue instructions call for 8mm ball studs with 2mm washers? Why did they change the stock Ackerman by taking away 2mm? That makes the steering less aggressive, but they don't give a reason.
Finalist is offline   Reply With Quote
Old 01-08-2016, 07:38 AM   #17670
thecman26's Avatar
They actually have 2 American warehouses. Ship almost anywhere in the US in 3-4 days.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
