    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 01-04-2016, 11:39 AM   #17611
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Matt Trimmings View Post
Anders Lind on Facebook.
Yeah, that is the one... lol. Did you get yours yet?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-04-2016, 11:47 AM   #17612
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
It's in the mail.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-04-2016, 06:50 PM   #17613
Cridd's Avatar
Trader Rating: 16 (100%+)
It's in the mail.
can't wait to hear some feeback.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-04-2016, 11:25 PM   #17614
Originally Posted by kuruption View Post
Running it +2 will give you less rear traction in the corners than running it -2. So try one way, if you don't like it, flip the bar.
Originally Posted by Svendc View Post
Higher is lower rolcenter on the brace, so lowgrip general you want higher rolcenter. So lower on the brace.
Pretty sure that is backwards. A higher roll center is less chassis roll, so less grip in corners. Running the -2mm should lower grip.
The diagram here shows this well:
http://www.rccaraction.com/blog/2014...center-tuning/
Another way of thinking of it is; the farther away from CG the roll center is, the more the chassis will roll.
islandscott is offline   Reply With Quote
Old 01-04-2016, 11:55 PM   #17615
Cridd's Avatar
From what I been told, more grip - remove washers from shock tower ballstud, you want less grip add them in.
Chris
B6D / T5M / SC5M
Old 01-05-2016, 07:41 AM   #17616
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
"Grip" is too loose of a term. It's more about when the outside tire is planted in the corner. If the chassis is allowed to roll further, the grip will be made after the chassis is allowed to roll and starts to plant the outside tires. The overall amount of traction could actually be higher by allowing the chassis to roll further but it will occur at a slower rate. If you have a high grip condition, this slower rate is a good thing and gives a small amount of cushion before the traction starts to build. Of course, if you don't have a balanced shock package, you can pretty much flush roll center adjustments down the toilet.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 01-05-2016, 08:04 AM   #17617
Super Moderator
Trader Rating: 17 (100%+)
If 1-2 months, I would buy now. If 3+ months, maybe wait. AE normally does update on a 12 month cycle, "If they plan to do one". That would me an updated buggy "could" come out in 3-5 months. If they even update the Lite kit. IMO it would just be option parts, as I hear AE has no desire to make a lay down tranny.
the CRCRC curse is coming. It seems like every year, guys buy new kits for CRCRC's race in Jan and while we are at that race (or just before), they announce a new kit
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 01-05-2016, 11:51 AM   #17618
Trader Rating: 488 (100%+)
This true. Roll center is really is about the angle of the link relative to the ground. The longer your link, the lower your roll center should be as it will reduce the angle of the link. From what I understand the angle is inverted on the B5M so actually by lowering the inside I think you are raising the roll center. It seems a little counter intuitive but if you are using the stock hub in the book position I think roll center goes up when you lower the inner. Somebody else brought this to my attention and I believe its correct.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 01-05-2016, 12:06 PM   #17619
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
hope its just a new 4wd lol
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 01-05-2016, 12:10 PM   #17620
I can only hope. if they make a good one, I might get back into wheeler. I was just unhappy with the current offerings.
Old 01-05-2016, 12:15 PM   #17621
Svendc's Avatar
so camberlinks : on hub / shocktower \ hub gives lower rollcenter an less grip.
camberlinks on hub \ shocktower / hub gives higher rollcenter an more grip.
i was indeed wrong in rollcenter vs grip explenation., but wright about the camberlinks and grip.
correct me if i'm wrong
VBC Wildfire D08
AE B5M CE
Svendc is offline   Reply With Quote
Old 01-05-2016, 01:16 PM   #17622
BRSracing's Avatar
Trader Rating: 55 (100%+)
I do think something is on the way for 2 and 4 wheel drive. I think a new offering in 2wd is more likely first. The B5M CE is sold out most places and the FL edition seems to be in short supply. Neither are in stock at AE. I am hoping we see a little something at the Reedy race.
BRSracing is offline   Reply With Quote
Old 01-05-2016, 01:19 PM   #17623
Trader Rating: 18 (100%+)
Did some running at ocrc last night and played with camber links.I'm running the aluminum hubs and schelle rear camber link mount. Moved the links on the hub from the rear inner hole to the front outter and front inner. Moving the link to the outter hole definitely gave more roll. It did keep the rear from rolling in the corners. When I went to the inside hole, or shortest possible location, the rear was noticeably flatter and changed directions much quicker. I stayed with the shorter link because this is a high bite track (running electrons in mc sauced with wd40). With the longer link the car seemed lazy but easy to drive. I also had to use more brake to get it to turn, so I was able to get faster laps with a shorter link. That was what I noticed from running it.
In the front I'm running inner hole on both the tower and caster block. Didn't move the link but did take out the 2mm spacer. That tightened up the turning radius of the car and it helped the rear with changing direction faster. Just some observations. I think the best thing people can do is not be afraid to try different things. It's just one run: don't like it, change it back. Real world running does much more good than pages of talking about theory.....
Chris Brown is offline   Reply With Quote
Old 01-05-2016, 01:24 PM   #17624
What spring are you running in the front and rear and also what wt shock oil(and brand)?
Slashn77 is offline   Reply With Quote
Old 01-05-2016, 01:38 PM   #17625
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
It's only January 5th and that is the quote of the year!
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Krio
