    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree15Likes
Old 01-04-2016, 07:11 AM   #17596
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Mostly Motor Placement
Originally Posted by Slashn77 View Post
That makes sense but it seem like even though the spur gear doesn't effect the driving as much I find it hard to believe that all its for is a mm or 2mm of motor placement so can someone please elaborate more and the difference between a 69 tooth and a 72 tooth spur gear
As others have posted, in general a 1 tooth change on the spur is a much smaller change than a pinion gear and 3 teeth on the spur about equal a 1 tooth change on the pinion gear. If we had smaller increments in spur gears to choose from we could fine tune gearing even further.
In some cases you may have a gear ratio you can't get to with a specific size spur gear, for example the smallest pinion you can typically get on with a 69 tooth spur is a 29 tooth pinion, so you would need to go to a 72 with a 30 tooth pinion in order to get a similar gear ratio. If you wanted to run a 69/28 ratio because the 29 is too much gearů you would have to change spur gears in order to get the next step down in ratio.
I do personally use the size of the spur gear as a tuning aid, for example when I run on a low grip track I will run a 78/21 with my mod motor. This moves the motor back just a little bit giving me a little more rear weight bias. If I go to a higher grip track I will run a 81/22 moving the motor forward for more steering and less rear weight bias.
I understand this does not seem like a big change but the motor is the second heaviest component in your chassis so moving it just a few mm does have a change in handling of the chassis.
Hope this helps a little bit.
Good Luck!
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 01-04-2016, 07:25 AM   #17597
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by brian6674 View Post
There seems to be a lot of problems with tight ball cups. I have built a B5, B5M and a T5M. All had really tight ball cups. I put the ball in a dremel and put a dab of oil in it. Then spun the ball in the cup. Takes a few minutes to loosen. Messed a few up by using to fast of a speed, melted the cup.
What way do you use?
Snap the ballcup on backwards with the small opening towards the ball stud. This will stretch the cup slightly and will be perfect.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-04-2016, 07:44 AM   #17598
tc5 man's Avatar
Originally Posted by tc5 man View Post
I bought a Associated Aluminum ball stud Rear mount and it has a plus 2mm and - 2mm I know its for Rear roll center so for Meduim traction clay should I use plus 2mm or -2mm for that traction ?
Anybody know ?
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 01-04-2016, 07:50 AM   #17599
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Anybody know ?
Running it +2 will give you less rear traction in the corners than running it -2. So try one way, if you don't like it, flip the bar.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 01-04-2016, 07:53 AM   #17600
Trader Rating: 488 (100%+)
Anybody know ?
The book on the Lite says to run it -2 with 3mm of spacers on the inner ball stud. What I've seen a lot of people do is run it in the +2 position w/no spacer. I guess it depends on where you need your roll center.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 01-04-2016, 07:59 AM   #17601
Svendc's Avatar
Higher is lower rolcenter on the brace, so lowgrip general you want higher rolcenter. So lower on the brace.
Svendc is offline   Reply With Quote
Old 01-04-2016, 08:00 AM   #17602
Thanks! Will give that a shot next time! What about this reamer? I like that idea.
brian6674 is offline   Reply With Quote
Old 01-04-2016, 08:47 AM   #17603
Jmuck69's Avatar
Never tried the reamer. When you snap it on backwards to stretch, take back off and snap on correct way. forgot to mention that earlier.
B6D | B64D
Old 01-04-2016, 10:35 AM   #17604
Finally made it through the descision, lets go get a B5M
Is NOW a good time for a buy? Could wait 1-2 months if possibly anything cool is going to happen at AE
man1ac is offline   Reply With Quote
Old 01-04-2016, 10:42 AM   #17605
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
If 1-2 months, I would buy now. If 3+ months, maybe wait. AE normally does update on a 12 month cycle, "If they plan to do one". That would me an updated buggy "could" come out in 3-5 months. If they even update the Lite kit. IMO it would just be option parts, as I hear AE has no desire to make a lay down tranny.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-04-2016, 11:12 AM   #17606
Jmuck69's Avatar
I think a full FT version would be next with extra mounting holes for a possible lay-down transmission offered separately.
B6D | B64D
Old 01-04-2016, 11:14 AM   #17607
But that would cost a few extra bucks compared to the FL? I dont wanna spend as much as possible, just as much as I need to
Old 01-04-2016, 11:14 AM   #17608
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
While I would love to see an AE laydown (even though I just spent $$$ on one ), I have a friend who runs for AE that was told by an AE engineer that its "not gonna happen".
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-04-2016, 11:17 AM   #17609
Locally, many "fast" guys are going to the laydown tranny from Lind Andres (or something). When I asked around, I was told AE has NO current plans for a laydown tranny.
Old 01-04-2016, 11:18 AM   #17610
Super Moderator
Anders Lind on Facebook.
