    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-31-2015, 10:27 AM   #17491
Trader Rating: 70 (100%+)
Originally Posted by QDRHRSE View Post
I use to do the same thing with multiple batteries but now that its pretty standard to charge at 20-40 amps you can charge a shorty pack in 5-10 minutes with no issues. I went from having 20 lipos a few years ago to only having 1 per car now. You just need to buy a good charger and then having 1 pack becomes a non-issue.
Which lipos are you charing at 20+ amps?
All that I have say a max charge rate of 2C. Which puts them 8-9 amps.
On another note, the rear sway bar. I tried the thinnest one and it made the car spin like a top on med-high traction carpet.
I tried adding the front brass bulkhead. That alone made the car push like a dump truck. Added the rear sway with it, thinking they might work together. Nope, spins like a top.
Without the brass or sway bars its good with a little under steer. That under steer is killing my corner speed.
Pinebox is offline   Reply With Quote
Old 12-31-2015, 10:53 AM   #17492
When you get done running and then charge that high. Do your batteries get hot? I am always worried about my batteries getting too hot.
fordohio is offline   Reply With Quote
Old 12-31-2015, 10:57 AM   #17493
I charge at 30 amps and batteries never get warm for the most part I have temped them with a gun and never more than a 10 to 15 degree difference from ambient
jslider is offline   Reply With Quote
Old 12-31-2015, 11:31 AM   #17494
Trader Rating: 486 (100%+)
Right now I'm really happy with the Protek 100c lipos with the 5mm bullets. Its kind of a bummer because I have a pile of good batteries with 4mm plugs. Anyway, I've been juicing batteries so long that it doesn't seem like a big deal. I did scale back to 30A from 40 simply because there's not a huge difference in time. Its really not a big deal. If you keep an eye on you're lipos its very safe. When I say keep an eye on your batteries....I mean the resistance, charge time, and the balance on the cells. If anything looks unusual its time for a new battery. If the batteries got unusually hot while charging I'd think there was a problem. Bateries are not as volatile as they were in the old days. I'm very strict about my lipos. There are other care items that help too such as never leaving batteries charged etc. It took me a while to learn how to take care of my lipos but now that I'm the program all of my B5Ms run great.
Edit: Just for the heck of it I'll pull a battery out of a B5M (notice the plugging of the B5M thread!) and I'll charge it and temp it before and after.....then I'll discharge it and do it again just for the fun of it.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 12-31-2015, 12:12 PM   #17495
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
For the guys running the Schelle hubs, which hole do you use?
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 12-31-2015, 02:07 PM   #17496
Trader Rating: 22 (100%+)
inside hole +1 mm spacer underneath (equal to stock setting per the slip of paper from schelle included with the hubs).
joncmack is offline   Reply With Quote
Old 12-31-2015, 02:26 PM   #17497
mick33b4's Avatar
Next time try stepping the rear spring rate down one (ie white to green) with the same front. The total roll stiffness is: springs + dampers + sway bar. Your rear roll rate may have been too high compared to the front. That's the beauty of adding a sway bar. Can lower the shock sping rate, but at the expense of wheel independence. Or, in different terms, you can put enough roll rate stiffness (with the sway bar) without using shock springs that make the car bounce down the straight.
mick33b4 is offline   Reply With Quote
Old 12-31-2015, 02:54 PM   #17498
Buggy new guy question of the day. I see a lot of people attach the body with velcro on the side of the chassis. Is there a kit someone makes for this or is it just velcro off of Amazon or what?
65BAJA is offline   Reply With Quote
Old 12-31-2015, 03:01 PM   #17499
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Amazon / Home Depot / Lowes / whatever...
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 12-31-2015, 03:06 PM   #17500
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Roll Resistance is springs + dampers + sway bar + roll center + center of gravity + total vehicle weight
All of these things have affect on the how much, how quickly, and when the car will roll in a corner.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-31-2015, 03:34 PM   #17501
Default New RC10b5m build (electronics questions)
I recently purchased a Team Associated SC10 RTR truck and have been racing it the past couple weeks at our local indoor clay track. Awesome fun!! and I have been learning a lot. Now I realized that I need a buggy!!! I purchased the RC10b5m kit (should be here Monday) and I need help picking out servo, ESC, and other electronics for it. Keep in mind I don't want to break the bank on my first build, however, I do want to race it. Any feedback and help, or opinions would be greatly appreciated.
Also, can I bind my current radio and just purchase another transmitter for my rc10 or should I get a different radio now?
Bukwha is offline   Reply With Quote
Old 12-31-2015, 05:00 PM   #17502
vr6cj's Avatar
Trader Rating: 124 (100%+)
My b5m. Favorite car of all time so far.
vr6cj is offline   Reply With Quote
Old 12-31-2015, 05:26 PM   #17503
[/QUOTE]Edit: Just for the heck of it I'll pull a battery out of a B5M (notice the plugging of the B5M thread!) and I'll charge it and temp it before and after.....then I'll discharge it and do it again just for the fun of it.[/QUOTE]
Its pretty cold here. I cycled a 4250 100c Protek battery a few times and the battery went from a low of 60 to a high of 72. I have pics but its pretty unexciting. I set the charger to 30A but it never went to 30 and moved down to 20 so quick I missed it with the camera. It took almost 9 minutes to charge the first time which is a lot.
Old 12-31-2015, 08:25 PM   #17504
Its pretty cold here. I cycled a 4250 100c Protek battery a few times and the battery went from a low of 60 to a high of 72. I have pics but its pretty unexciting. I set the charger to 30A but it never went to 30 and moved down to 20 so quick I missed it with the camera. It took almost 9 minutes to charge the first time which is a lot.[/QUOTE]
what chargers are you guys using that will let you charge at that high of current
Tim
timrc is offline   Reply With Quote
Old 12-31-2015, 08:46 PM   #17505
iCharger 408 and iCharger 4010.
