    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-07-2014, 02:35 PM   #1726
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Matt Trimmings View Post
Once will suffice
its like 2 condoms. It cant hurt
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-07-2014, 02:36 PM   #1727
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
It's nothing like that
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-07-2014, 02:37 PM   #1728
lol, When I had issues with my 22 nuts falling off, this worked for me. To each their own. I like a little build up on the treads.
Old 03-07-2014, 02:39 PM   #1729
Super Moderator
That was something you were constantly taking on/off. This is something you screw in and leave it unless your making a tuning change. Just use good loctite and dont smother the screw in it and you will be fine.
Old 03-07-2014, 02:44 PM   #1730
Good point Matt. They did get removed a lot more. Honestly, aside from those 22 nuts, I probably only use one coat and then reapply a dab if i need to remove and reinsert the screw. I.e. replacing bearings. I think those tlr nut just have me paranoid, lol. I hate loosing races to my wheels falling off
Old 03-07-2014, 03:55 PM   #1731
mugenhatchie's Avatar
Couple other tips for you. These are just from my build experience:
1. The gear box screws that fasten the halves together are a very tight and I am in no way complaining about that lol. I took a spare screw and ran it through several times on each hole and then used the kit screw to bolt it all up. Allowed me to tighten them down and get a good feel of when they bottom out. To tight and it will get the gearbox to bind up a smidge
2. Shim the top shaft. Putting it all together I had quite a bit of side play once the halves were together.
3. I used Losi 22 12mm shock bladders in my shock build instead of going with the kit emulsion build. Shocks are suuuppper smooth and do not "aerate" at all. Plus side is you can tune rebound by installing the shock cap plug screw. Pull the shaft out all the way and install the screw= high rebound. Push it in half way and install the screw= less rebound.
4. Put X-rings in the shocks. Built them with and without. I definitely like them with.
5. Polish the shock shafts. I used blue magic and chucked them in a dremel.
6. The FT B4 Ti Turbuckles actually threaded easier into the ball cups than the stock steel ones. Not as fancy as the JC ones or the Lunsford but they get the job done.
7. Shim the rear arms. They will have a bit of front to back play.
8. Install the "optional setscrews" in the front caster block and the rear hubs. only took a few days for them to loosen up a but.
As far as changes for me to the setup this is all I have done and love the way it is working:
1. Removed the shims under the rear inner camber ballstuds
2. Moved the shocks all the way to the inside hole on the tops (f&r)
3. Still running 1.6 front & 1.7 rear but changed the rear oil to 27.5
4. Battery all the way to the rear (shorty)
Anywho here she is all painted up and ready for track duty. WOOT!
mugenhatchie is offline   Reply With Quote
Old 03-07-2014, 04:13 PM   #1732
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Wild Cherry View Post
Hey !
I got .5 m ceramic balls that clank when ever I walk onto the drivers stand.
Need um to post here.
no typo lol
this is top quote for this thread right now!. hard to beat this.
ryanpatrickgore is offline   Reply With Quote
Old 03-07-2014, 04:55 PM   #1733
Graham11's Avatar
Trader Rating: 21 (100%+)
Hey guys, b5m order placed, I have been traveling and haven't been able to follow the threads, what are the must have and recommended parts/upgrades I should order immediately?
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 03-07-2014, 05:36 PM   #1734
I would say get the X-rings, aluminum top shaft, a Ti turnbuckles. You don't need these parts to have a good car but if your going to do them anyways, you might as well get them now and use them during the build rather then going back and taking stuff apart.
Old 03-07-2014, 05:43 PM   #1735
What up?'s Avatar
Trader Rating: 14 (100%+)
What's a good starting gearing for a 13.5 with this car? 72/30?
Josh Mitchell
Speedtechrc.com / Team Orion USA / Airtronics / Proline / Bartalone Racing / rcinsider.com / 818Designs
What up? is offline   Reply With Quote
Old 03-07-2014, 05:57 PM   #1736
Yeah that ratio is fine
Old 03-07-2014, 06:15 PM   #1737
VegasHB's Avatar
Originally Posted by Pellefa View Post
For a neater wiring job, did anyone consider to route the motor wires under the battery where the sensor wire should go…? Obviously some modding required incl the chassis, and possibly limited to 14G wire… any purists out there?
Comes in 12, 14 or 18ga
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 03-07-2014, 06:41 PM   #1738
Where is that available? Or what do I even search? I would totally try that!
Also, does anybody know if the MIP B4 aluminum top shaft will work? I've been trying to compare mine with the pictures of the new Associated aluminum top shaft and I see a couple differences that look like integrated spacers, but I'm not really sure.
iVoid is offline   Reply With Quote
Old 03-07-2014, 06:53 PM   #1739
Flatwireready.com. Its used for hiding speaker wire in walls.
The MIP B4 Shaft will not work. This is a metric car and the b4 used the 3/16x3/8 bearings. You'd have better luck fitting a Kyosho RB6 top shaft with 5x12x4 bearings (which I am just speculating at, so no factual evidence this will actually work) or better yet, just get the AE B5 top shaft.
Old 03-07-2014, 07:54 PM   #1740
Xrings? You guys using kyosho?
Anyone been using the gear diff? If you are what diff oil?
Sponsers: Schumacher, Santiam Hobbies, Fantom Racing, Racing-cars.com, Flawless RC, Discountrcstore.com
Theroc is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
