    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 12-18-2015, 07:44 AM   #17311
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Bob Barry View Post
Have any of you tried running the GHEA +2 pills with Pucks? I had them in the car and the drive pin on the dog bone was right up to the edge of the out drive. I ran it for a pack or two that way and really liked the way it handled but I pulled the +2's out just because I didn't want to risk breaking an out drive.
I'm thinking try shimming the entire axle / bone in more, but there's not much play there now...
Pick up the axle shims from AE.
http://www.amainhobbies.com/rc-cars-...c91605/p462723
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-18-2015, 07:47 AM   #17312
Mason's Avatar
Originally Posted by walter white View Post
how often do you guys replace plastic suspension parts. im finding that after 4 or 5 runs there is a ton of slop in the suspension. mainly in the front. rear takes about twice as long to get sloppy. gets kind of old replacing all the plastics in the front after everyday of racing. I run 17.5 on medium bite indoor clay. my t5m is even worse.
I'm about at 1.5 years on some of the arms... or its been so long since i broke one that I don't remember. Though they probably need to be replaced. What I find wears out often are the oem plastic shock bushings. I probably should replace those every other month if not every month (i usually race twice a week)
You mentioned that it's the front end that's an issue. Sounds to me like your local tracks have some hellacious jump faces or you're trying to knock down the walls/pipes a bit much.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 12-18-2015, 08:03 AM   #17313
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by Jmuck69 View Post
well damn....
thanks. I feel like a dummy now.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 12-18-2015, 08:42 AM   #17314
Greenbandit's Avatar
Originally Posted by Tdub77 View Post
just pick up the whole set and then your covered
Soft, medium, or hards? Do they have all in one set?
Todd Daly
Greenbandit is offline   Reply With Quote
Old 12-18-2015, 10:01 AM   #17315
aeRayls's Avatar
For the conditions you stated, green, white, gray fronts and green and white rear is all you'll ever need. No sense in buying the entire spring collection.
aeRayls is offline   Reply With Quote
Old 12-18-2015, 10:50 AM   #17316
Thank you. I have whites front and rear, so I will pick up the others
Todd Daly
Old 12-19-2015, 10:04 AM   #17317
Svendc's Avatar
Let the built begin of my BM5 CE, only gonne run it on carpet and astroturf, so 3gear all the way.
VBC Wildfire D08
AE B5M CE
Svendc is offline   Reply With Quote
Old 12-19-2015, 04:16 PM   #17318
Just ordered a Factory Lite kit. Going to be racing stock beginner class.
So for I have a Tekin RS GenII and a GenIII 17.5 motor. The steering servo I have is a Futaba S9570SV. For batteries I'm looking at either the Vant 4600 shorty or the Turing Ultimate 4600 shorty. Haven't bought the battery yet though.
Any recommendations for set up on a tight indoor clay track? I ordered the grey and green springs front and rear for some tuning options.
65BAJA is offline   Reply With Quote
Old 12-20-2015, 09:30 AM   #17319
Figure out what kind of grip you have and get the right tires. Then you can look on team associated website and get a good setup to start from there. Clay tracks can very alot in grip so make sure you pick one that's closest to your track
Hyperhobbies.ca
Rcbatterydepot.com
lee111m is offline   Reply With Quote
Old 12-20-2015, 08:50 PM   #17320
monty c's Avatar
Location: Dont get any more northwest than me..........
don't know if this has been asked but quick question, building the new CE kit, they say run the rear motor rear arms on the setup sheet but they arent included in the kit? is this correct?? the kits only comes with the regular MM arms, both sets of front arms are included but not the RM rear arms.
Maclan Racing // Garcia Graphix // FactoryRC.com
Team Associated T5M // B6 // B5MCE
monty c is offline   Reply With Quote
Old 12-20-2015, 09:20 PM   #17321
does cutting the cradle do anything? curious what effects it will have if any?
DIRT DIGGER is offline   Reply With Quote
Old 12-20-2015, 10:30 PM   #17322
Cridd's Avatar
Trader Rating: 16 (100%+)
Pretty sure they are the real motor arms In the kit.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-20-2015, 10:31 PM   #17323
Cridd's Avatar
I don't see any change.
Chris
B6D / T5M / SC5M
Old 12-21-2015, 12:46 AM   #17324
I recently bought B5m conversion kit and converted B5RM to B5M.
Now I'd like to try 3 gear tranny.
Do I need to buy 3gear top shaft or the one included with new conversion kits is universal?
Toyman is offline   Reply With Quote
Old 12-21-2015, 08:07 AM   #17325
WonTonsChicken's Avatar
Trader Rating: 42 (100%+)
You actually have a couple options. Depending on weather you go with the kit 3 gear, or MIP for example.
The kit top shaft will work for either, but if you go with a light weight, then you will have to use shims/different bearings.
(see attached pic for example)
Hope this helps
--Special Thanks to--
Tekno RC - Pro-Line - Boca Bearings - Team Tekin - FTM Grip - G's RC Raceway - CowRC!
Tekno ET48.3 | NB48 | EB48.25 | SCT410 | EB410 | Pro-2 SC
WonTonsChicken is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (3 members and 5 guests)
blankenj99, Dmkiefer, Fran
