    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-14-2015, 06:52 AM   #17236
Trader Rating: 70 (100%+)
Originally Posted by Bob Barry View Post
I'm thinking about building a second car specifically for turf tracks. I saw the red workshops lowrider setup, but it's rather pricey for me to do. Just curious, what are the other options out there? Or is that my best bet for this car?
Check a few pages back. I'm working on one.
I'll post more info soon.
-Dave
Race: B64D / B6D / B6
Coming Soon: Tekno EB410?
Pinebox is offline   Reply With Quote
Old 12-14-2015, 07:05 AM   #17237
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Torvald View Post
Got a B5M FL and my rear hubs plays a hole lot and the rear arms to.
It feels like the plastic washers on the hinge pin is getting worn out.
Does anybody uses aluminium washers instead of plastics?
Iīve tried to search this thread but didnīt find any solution.
You can, or get a real thin shim and add it in. you can reshim to tighten up.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-14-2015, 07:08 AM   #17238
Cridd's Avatar
Originally Posted by Wildcat1971 View Post
Humpty just won the 17.5 class at the SDRC Topgun race and many other locals seem to be giving the "low rider" transmission a go locally. But like you said, pricey.
Don't love the 3D printing composite. Would be cool if AE came out with a kit or somebody like Jconcepts, MIP or Exotek.
Chris
B6D / T5M / SC5M
Old 12-14-2015, 07:12 AM   #17239
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Kalio View Post
Has anyone else tried running a 34t pinion (B5m CE)? It seems the pinion is very slightly too big for the gear cover and is grinding against it. If I don't screw down the lower portion of the gear cover (which is where the pinion is) it seems fine, but that's not really ideal. I suppose I could grind off a bit of the inside gear cover if I have to but I didn't think a 34 pinion would be uncommon.
What are you running for a spur gear?
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 12-14-2015, 07:23 AM   #17240
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Of those....I would think MIP maybe. Because they have already made one gear box and they have made chassis in the past, as the chassis will need new holes for the mounting. I dont love the 3d printing either. If AE released one, I would pick it up to try at srs for sure.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-14-2015, 07:26 AM   #17241
Mason's Avatar
I run 34 and 35 on my B5M (original 4 gear). While it's possible they have altered the gear cover from 4 to 3 gear, it's unlikely that area would have been touched. Have you checked for a bent motor plate? Can you move the pinion down the shaft a little more? You could shim the cover out a smidge but unless you switch over to the fuel tube mounting method, the removal of the gear cover will get annoying.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 12-14-2015, 07:37 AM   #17242
Super Moderator
Trader Rating: 17 (100%+)
we had an SRS local show up at our track in PA and told us that this was the first time he had to actually tune his B5M. At SRS it's all about just slam the car, dope your tires and put as much power into it as possible. You could run any setup and still wheel it fast. Hearing these stories always makes me chuckle
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 12-14-2015, 07:44 AM   #17243
Super Moderator
racer1812's Avatar
You running a 66t spur to get pinions that big to fit?
IF you're running a 69t spur with those big pinions (not even sure they'll fit) why not drop down to a 66t spur and drop pinion size to match??
Old 12-14-2015, 10:28 AM   #17244
Mason's Avatar
Nope. Just had 35/75 on there saturday. That was close to needing to move sensor wire but it was fine. Went to 34/72. For the rest of the day. Probably a sleepy batter problem and time for new batts. I have not messed with tuning the motor. It's still sealed from our region race back in june.
Old 12-14-2015, 10:52 AM   #17245
3D printing isn't as bad a you think. No, it sure isn't injection molded plastic like AE kit parts. But it's a great alternative for new ideas.
I've been running a 3D printed lay down trans since July. First the original 4gear on shapeways, then the 3gear I designed. No issues with either of them.
My 3gear has been awesome the past few weeks. My son will be getting it this week for more testing.
Old 12-14-2015, 11:31 AM   #17246
Super Moderator
I have no issues with running 3d printed stuff. my issue is that I can't justify spending 170 Euros for a conversion when I may run turf 3-4 times a year.
Old 12-14-2015, 11:40 AM   #17247
34-35 pinions fit no problem with the 69 spur. I haven't had trouble with gear cover.
Sean B. is offline   Reply With Quote
Old 12-14-2015, 11:49 AM   #17248
tc5 man's Avatar
Joining the club and getting the B5M not the champ Ed coming very soon . I had a chance to race 2 B5M as mod motor.
And felt instantly competitive can't say the same for the Dex210V2 i been driving on clay on carpet it's great though .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 12-14-2015, 11:52 AM   #17249
onefast8's Avatar
Trader Rating: 41 (100%+)
Jake R.
onefast8 is offline   Reply With Quote
Old 12-14-2015, 11:54 AM   #17250
Mason's Avatar
not sure if those were shots fired. perhaps more along the lines of there are racers who aren't taking more advantage of the adjustability of their cars
Mason McCombs
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
frankf
