    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-02-2015, 04:29 AM   #17011
Sorry Guys, I looked but did not see anything in the last few pages. Gull wing arms vs. straight. Pro/Cons each?
brian6674 is offline   Reply With Quote
Old 12-02-2015, 05:10 AM   #17012
Originally Posted by Cridd View Post
Is the metal that soft? Would think I would end up with a jagged mess. I might try it on an extra piece.
Some people can be as clean with a Dremel as a lathe. Just takes skill and a bit of craftsmanship. Sure a lathe would be the best way to do it but a dremel will do it in less than 5 minutes for sure and leave a pretty clean cut if you're good with one.
www.apexattitude.blogspot.com.au
Silberpfeil is offline   Reply With Quote
Old 12-02-2015, 05:12 AM   #17013
Gull wing give you more steering. More suitable for high grip. Flat will calm your steering down.
BrandonBreh is offline   Reply With Quote
Old 12-02-2015, 05:49 AM   #17014
Suspended
Trader Rating: 61 (100%+)
Upper right hand corner, "Search this thread".
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 12-02-2015, 06:15 AM   #17015
gabc's Avatar
Originally Posted by larsif View Post
Yes I have. It works well. The thrust washer setup is much smoother than the stock AE unit as it has smaller balls and more of them than stock.
You will need to look at the MIP site for assembly info as instructions are not provided.
Thanks for the heads up larsif!
gabc is offline   Reply With Quote
Old 12-02-2015, 07:18 AM   #17016
Did that! But if you do it now only my post comes up. Thanks for the help!
Old 12-02-2015, 07:40 AM   #17017
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Don't be specific when searching. I typed in "gull" and got like 4 pages of results. Don't type in "Gull wing arms vs. straight. Pro/Cons each?" The search looks for exactly what is typed.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-02-2015, 10:12 AM   #17018
jmcelroy42's Avatar
Question, if they give too much steering and high bite in general has awesome response and steering why go gull wings and produce even more steering. Wouldn't you want gull wings on a low bite?
Interested in this as well. I was considering trying them. trying to get a little more steering on low-mid traction packed dirt. Running stock FL setup now.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 12-02-2015, 10:46 AM   #17019
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
It is $10 in parts. It is worth it to try them and decide for yourself.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-02-2015, 11:04 AM   #17020
Thomas PA's Avatar
Originally Posted by Volition View Post
Have I missed something? What's this issue with the front pin you guys are having.
Its not a problem, its an upgrade. By eliminating the front hinge pin brace, you can land more nose down and not scrape.
Thomas PA is offline   Reply With Quote
Old 12-02-2015, 11:17 AM   #17021
Suspended
Upgrade huh?
Interesting...
Old 12-02-2015, 11:24 AM   #17022
Jmuck69's Avatar
It was actually done to eliminate the front from dragging on the upside of jumps which scrubs speed.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-02-2015, 12:00 PM   #17023
Kalio's Avatar
Man, I wish the CE version included the lighter chasis. I wonder why they didn't? I'm building the CE right now which is probably a huge upgrade from my old B4.2 but I run in stock so that lighter chasis would have been nice, especially for the larger price tag.
Kalio is offline   Reply With Quote
Old 12-02-2015, 12:08 PM   #17024
Thomas PA's Avatar
Upgrade huh?
Interesting...
I suppose improvement would have been a better word.
Old 12-02-2015, 12:10 PM   #17025
Thomas PA's Avatar
That makes sense too. But wouldn't you want to scrub speed on the upside so you can carry more speed up to the jump?
