    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 11-10-2015, 06:11 AM   #16636
Suspended
Trader Rating: 61 (100%+)
Originally Posted by rob martin View Post
What advantage are you guys seeing from not running a battery strap? More flex? Better handling?
Consistency.
QDRHRSE didn't notice a difference because he's not a noob that cranks the battery down as hard as possible.
Not running the strap allows you to get rid of a binding point. I noticed with a strap and gorilla locking the battery down, you can bind the chassis up pretty bad. When doing certain mods that allow flex, you can also lead to the strap popping out.
You also lose the strap when you run certain fan setups.
There's a few reasons why certain people don't run it. It still hasn't been talked about, I think, but the world champ does not use a battery strap.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 11-10-2015, 06:41 AM   #16637
Trader Rating: 486 (100%+)
That's very true. I run the battery strap pretty loose. Still, making sure the cradle is completely separated and not too tight either will allow for a lot of flex even with a strap. I'm really consistent but not so fast. I'm definitely not pushing my cars to the limit.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 11-10-2015, 06:59 AM   #16638
rob martin's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to rob martin
Thumbs up
Interesting. Thanks for the input and MAYBE ill give it a try!!!!
Rob Martin~
~Ridgeway bodies~B-Fast Performance Diffs~Flying Farmer Traction Sauce
rob martin is offline   Reply With Quote
Old 11-10-2015, 07:50 AM   #16639
Super Moderator
Trader Rating: 17 (100%+)
just when I thought I was out.... they sucked me back in.....
B5M FL has been built
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 11-10-2015, 08:10 AM   #16640
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Hahaha....the car is too good to stay away!
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 11-10-2015, 10:16 AM   #16641
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Being a touring car guy, I am one of the only guys I know of at my track that run my battery strap as loose as possible. I like it to be there "just in case" so I can't actually loose it in a bigger crash, but I don't want the battery to be held down tight enough to actually inhibit the chassis from flexing across the center.
Now, if you like LESS chassis flex, considering the battery is down the middle of the chassis and not down one side like a TC... clamping it down tighter will certainly accomplish that. In that case, what matters isn't the fact that you are clamping down the chassis, but that it is down the middle and not down one side affecting chassis flex differently left than right.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-10-2015, 10:25 AM   #16642
Suspended
The problem is when it's overly tight, is it binds the chassis. It'd be great if it made the chassis possibly more rigid, but it doesn't because it isn't linked on the backside. However, when overly tight, it bows, and then binds the chassis.
Old 11-10-2015, 10:38 AM   #16643
beidle99's Avatar
With all the talk of battery straps wouldn't the old style/system similar to the original Rc10 using a cap head screw with a hole through the head for a body pin be the best and most consistent way to strap in a battery? I think I just aged myself. lol
For carpet off-road whats the best lay out, shorty stock or shorty inline?
Mugen MBX7R, Fusion X5 Race "FM", Houston's Engine Service, 2096/41021, Buku Komp
Mugen MBX7 Eco, Hobbywing XR8, SMC 1900, BCE X3.
Team Driver for FusionX Engines & BCE (RIP Bill)
beidle99 is offline   Reply With Quote
Old 11-10-2015, 10:46 AM   #16644
Suspended
The best method is what works for you, but doesn't bind the chassis.
As for layouts, this isn't video games, there isn't one answer that is the end-all be-all.
I recommend you try both, and then make the choice based on lap times. You'll get 100 different answers here. Only you know what feel you want, on the internet we can only guess.
Old 11-10-2015, 11:13 AM   #16645
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Anyone have a good method for taking the packs into the Lite Chassis. The extra milling seems to effect contact patch a bit.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-10-2015, 11:30 AM   #16646
Where do u cut the cradle? Is there any other spots u are cutting also? Thanks
DIRT DIGGER is offline   Reply With Quote
Old 11-10-2015, 11:42 AM   #16647
Super Moderator
my next project is figuring out how to shoehorn my Pulse V2 in there.....
Nevermind...think I just did. Ordered an Impact LOL.
Old 11-10-2015, 11:44 AM   #16648
tony montana's Avatar
Trader Rating: 65 (100%+)
Question, the v2 shock pistons, I see they will not work with the 5m lite's shock shafts, I guess you need the v2 shafts as well. But has anyone of you just drilled the center hole out of the v2 pistons to fit the old shafts?
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 11-10-2015, 12:00 PM   #16649
I would not trust my drill skills to get it perfectly centered. Just get the v2 shafts
Old 11-10-2015, 12:35 PM   #16650
wittyname's Avatar
Ha ... I have a pulse esc as well . My Rx is on top of the servo , with the esc and transponder side by side . ITs not pretty , but it works.
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
