    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 10-26-2015, 02:20 PM   #16306
thecman26's Avatar
Trader Rating: 99 (100%+)
Originally Posted by porter View Post
Jconcepts had some narrow wheels for the world's event so drivers didn't have to go through the hassle of cutting them down. Not sure if they are planning to produce those or not
^ This guy is reliable! Sup Jason?
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-26-2015, 03:11 PM   #16307
beidle99's Avatar
When running said tires, it is required to cut the inside rib off the wheel and glue the tire to the existing rib...
Have a look here
http://www.rcten.com/threads/mountin...t-tires.14100/
Thanks. That's what I thought but it didn't seem right. Not a problem to do the cutting.
beidle99 is offline   Reply With Quote
Old 10-26-2015, 04:12 PM   #16308
Trader Rating: 47 (100%+)
No problem beidle99
Not much going on around here Chris. Been messing about at the carpet track in Manhattan. Got one more event there then I'll be switching all my AE cars back to dirt setups for Jakes
porter is offline   Reply With Quote
Old 10-26-2015, 05:01 PM   #16309
dirtdog's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Flyinggekko View Post
I thought you guys are maybe interested in the lowrider gearbox I've designed for some of my club colleagues:
The first prototype has already been printed and will be tested at a indoor race in czech republic this weekend.
Greetings
Stephan
3D Printed?
dirtdog is offline   Reply With Quote
Old 10-26-2015, 06:19 PM   #16310
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
Who do you contact for a defective kit part? On my newest B5M lite one of the stub axles isn't machined deep enough for the cv shaft to go in far enough to push the pin though the barrel.
pink_sleeve is offline   Reply With Quote
Old 10-26-2015, 07:04 PM   #16311
does anyone know where i can get a "c" brass arm mount? cant find one anywhere
DIRT DIGGER is offline   Reply With Quote
Old 10-26-2015, 07:39 PM   #16312
I normally just call the associated phone number and get on with support, tell them whats wrong. They usually take down your info and then send you a new one.
BrandonBreh is offline   Reply With Quote
Old 10-26-2015, 11:31 PM   #16313
Originally Posted by dirtdog View Post
3D Printed?
Yes, a 2d print would not be satisfying
Flyinggekko is offline   Reply With Quote
Old 10-27-2015, 12:38 AM   #16314
aeRayls's Avatar
In stock right now at team associated.
aeRayls is offline   Reply With Quote
Old 10-27-2015, 02:48 AM   #16315
Volition's Avatar
Hi guys.
What's the go on venting 1/10 2wd tyres. Yes or no. Or in particular conditions.
Volition is offline   Reply With Quote
Old 10-27-2015, 04:51 AM   #16316
Potoczak's Avatar
Trader Rating: 112 (100%+)
Just picked a set of black hex's for the front and rear of my b5. For some reason the rear hex's are to small to go over the axles. Seems like they would fit the old b4 axles. Has there been any issues with these.. Ordered a new set from my local hobby shop to see if it was just that pack..
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 10-27-2015, 07:14 AM   #16317
Trader Rating: 31 (100%+)
I am guessing if you have Black hexes, they are Jconcepts. The original B5M had a smaller diameter rear axle. The Factory Lite kit comes with the HD rear axles and are larger diameter. You would need to purchase the new Jconcepts HD hex that is coming with their new rear assembly, or drill out your current hex with a 5mm bit/reamer like I did to make it work.
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 10-27-2015, 07:20 AM   #16318
Trader Rating: 81 (100%+)
And 4D would be ideal. That's scratch and sniff right?
dpcardoza is offline   Reply With Quote
Old 10-27-2015, 08:01 AM   #16319
Razathorn's Avatar
Originally Posted by Volition View Post
Hi guys.
I always ensure my wheels have two holes (which most do by default) and then I either cut 4 small holes on the inside sidewall/edge of the tires or two larger ones, evenly distributed around the tire obviously. I tend to prefer 4 small holes with a smaller punch. Just don't get so close to the wheel that it's hard to glue without getting glue in the holes.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-27-2015, 08:48 AM   #16320
Mason's Avatar
Hi guys.
You will get all sorts of answers. What we can all hopefully agree on is that you will need holes some where in your wheel/tire and that depends on your track conditions. Standard hole locations are in wheels, tire sidewall or tire tread.
So tell us your expected track conditions and many will make recommendations from their experience.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
