    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 10-25-2015, 05:57 PM   #16291
BLKXJ96's Avatar
Originally Posted by a1 View Post
Tires , Im sure you know , are very important.
Yep, and the rest is just minor adjustments. Tires seem to be about 80% to 90%.
Jeff
RC10 Team Car, Gold Pan, RC10 B5m B5mCE, Sc5m, Rc8B3e, B6
BLKXJ96 is offline   Reply With Quote
Old 10-25-2015, 07:02 PM   #16292
Jpdanger's Avatar
Originally Posted by DIRT DIGGER View Post
can someone recommend a good setup for a small indoor hardpacked dusty bumpy/smooth med bite track?thanks
Go to petitrc.com and sort through the set ups regarding tracks that are similar to what you're seeking. You can use those as a starting point.
I buy RC cars for my kids like a man buys a bowling ball with his name on it for his wife.
"What I say makes sense in my head. Once it comes out of my mouth it's for you to figure out." -me
Jpdanger is offline   Reply With Quote
Old 10-25-2015, 07:05 PM   #16293
Thomas PA's Avatar
Originally Posted by BLKXJ96 View Post
I would be curious to see how this trans works on med to high grip clay.
I love it on flowing layouts in 17.5. Tremendous corner speed. Its a little slow out of tighter corners in mod. I do run brass mounts with it.
Thomas PA is offline   Reply With Quote
Old 10-25-2015, 08:59 PM   #16294
Trader Rating: 22 (100%+)
Originally Posted by Krio View Post
You can use the inserts meant for the rear motor B5 to remove toe on the B5m.
is this what i'm lookin for inserts for the d block, ASC91389?
noproblems209 is offline   Reply With Quote
Old 10-25-2015, 10:23 PM   #16295
mike nelson's Avatar
Yep.
TEAM ASSOCIATED--NOVAK--J-CONCEPTS--REEDY--LEISURE HOURS HOBBIES--FUTABA--COMPETITION ELECTRONICS--UP-GRADE RC--TRAKPOWER--
mike nelson is offline   Reply With Quote
Old 10-25-2015, 11:58 PM   #16296
It's quite offtopic, but I think its the fastest way to a good answer:
I a running a Sonic M2 8.5T and an GM Genius Race II 80R. My programming card says the motor is 2 pole (i can switch to 4 pole).
Do I have to swtich to 4pole?
man1ac is offline   Reply With Quote
Old 10-26-2015, 06:18 AM   #16297
Without any knowledge on that speed control, i would say no since you aren't using a 4 pole motor...
BrandonBreh is offline   Reply With Quote
Old 10-26-2015, 06:24 AM   #16298
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
no. the inserts come wit h the rear hubs
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-26-2015, 10:02 AM   #16299
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Couple of kool-aid drinkers here:
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-26-2015, 10:33 AM   #16300
AccessRacer's Avatar
Trader Rating: 20 (100%+)
Default Loose
If I want to tighten my b5m up, what is the best way to do that? Do I shorten or lengthen the rear ball link and or raise or lower the inner ballstud? Thanks
AE B5M
AE RC10T5M
AE SC5M
AE B44.3
AE RC8B3E TEKNO SCT410.3 JRC JET EDM & LATEMODEL
AccessRacer is offline   Reply With Quote
Old 10-26-2015, 10:56 AM   #16301
http://www.rctech.net/forum/electric-off-road/519561-tune-camber-links.html
This should answer everything
Old 10-26-2015, 12:41 PM   #16302
beidle99's Avatar
after years of not racing 2wd, I have ditched all my old stuff, looking for some clarification on front rims. I bought a set of Proline velocity 2.2's to mount my shumacher low profiles on. The rims seem way to wide, almost 4wd front width. Can someone measure their 2wd fronts and post the width of them?
Mugen MBX7R, Fusion X5 Race "FM", Houston's Engine Service, 2096/41021, Buku Komp
Mugen MBX7 Eco, Hobbywing XR8, SMC 1900, BCE X3.
Team Driver for FusionX Engines & BCE (RIP Bill)
beidle99 is offline   Reply With Quote
Old 10-26-2015, 12:45 PM   #16303
I thought you guys are maybe interested in the lowrider gearbox I've designed for some of my club colleagues:
The first prototype has already been printed and will be tested at a indoor race in czech republic this weekend.
Greetings
Stephan
Flyinggekko is offline   Reply With Quote
Old 10-26-2015, 01:39 PM   #16304
Trader Rating: 47 (100%+)
When running said tires, it is required to cut the inside rib off the wheel and glue the tire to the existing rib...
Have a look here
http://www.rcten.com/threads/mountin...t-tires.14100/
porter is offline   Reply With Quote
Old 10-26-2015, 01:52 PM   #16305
Jconcepts had some narrow wheels for the world's event so drivers didn't have to go through the hassle of cutting them down. Not sure if they are planning to produce those or not
