    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 10-24-2015, 08:58 PM   #16276
Trader Rating: 486 (100%+)
I don't want to argue about who said what and when but all the chassis sponsored guys I know say that they have to run the OE stuff. Only the privateer types can run the aftermarket stuff. I know Joe Pillars, the Kyosho team manager, is very strict about his guys using OE stuff. Anywho, the slipper that comes with the B5M Lite is more than adequate, especially for stock racing. I think people feel that if they get the "best" of everything that its going to make them faster. Subconsciously, I probably fall into that category myself. I don't practice enough and don't have enough natural ability to ever really be fast but I've accepted it. The guys that are always talking about how you gotta try this setup or that new part are B main heroes. Case and point, George Cherry.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 10-24-2015, 09:22 PM   #16277
Super Moderator
Guys, run whatever slipper suits your fancy, and express your opinion.
But stop bickering over it. Past time to move on.
Dave H is offline   Reply With Quote
Old 10-24-2015, 10:07 PM   #16278
Trader Rating: 22 (100%+)
with all the lightweight drivetrain parts now available and the power i'm seeing from today's 17.5's, there is no reason not to run a slipper. We're on high traction carpet and I finally had to resort to running the slipper. Cars much more consistent and its easy to control the front tires rising....
Changing the subject anyone tried to achieve less then 2.5 degrees of rear toe? besides reversing 0.5 hubs?
noproblems209 is offline   Reply With Quote
Old 10-25-2015, 05:08 AM   #16279
Krio's Avatar
Trader Rating: 150 (99%+)
You can use the inserts meant for the rear motor B5 to remove toe on the B5m.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 10-25-2015, 11:38 AM   #16280
should i run the 3 or 4 gear transmission for a small indoor med bite hard packed dusty track? thank u
DIRT DIGGER is offline   Reply With Quote
Old 10-25-2015, 11:51 AM   #16281
Krio's Avatar
Unless you are running stock, on medium bite you will probably benefit slightly from the 4 gear. However, it is a fairly small difference in handling that other tuning options can take care of. If you have one gearbox already, just run it and tune around it.
www.kriostasis.com
Old 10-25-2015, 02:23 PM   #16282
Gpeters66's Avatar
+++++1
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 10-25-2015, 02:33 PM   #16283
Trader Rating: 81 (100%+)
Thank God. That went on a lot longer than than I'd expect from grown adults.
dpcardoza is offline   Reply With Quote
Old 10-25-2015, 02:40 PM   #16284
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
These are toy cars...you could say its pretty serious...
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-25-2015, 03:30 PM   #16285
tomdav's Avatar
Trader Rating: 42 (100%+)
So how long until the laydown transmission comes out? I would think there is enough demand to warrant it or at least someone like Jconcepts/Avid/Schelle to make one.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 10-25-2015, 04:06 PM   #16286
You said the T word
BrandonBreh is offline   Reply With Quote
Old 10-25-2015, 05:23 PM   #16287
BLKXJ96's Avatar
I would be curious to see how this trans works on med to high grip clay.
Jeff
RC10 Team Car, Gold Pan, RC10 B5m B5mCE, Sc5m, Rc8B3e, B6
BLKXJ96 is offline   Reply With Quote
Old 10-25-2015, 05:39 PM   #16288
J2O
Does any body have some time to chat about servos? My son and I both have b5m's, both with Spektrum DX4C's. His runs the savox 1258tg and I run the spektrum 6040, fairly identical servos or so I thought.
His savox installed nearly straight up, needs very little subtrim adjustment, runs toe links at kit instruction lengths and gets nearly full throw in both directions. One side turns a little further but the travel is so good that one side is 90% and the other is 85%.
My 6040 on the other hand has been such a headache. After exhausting every solution I can think of, my horn has been installed off center with toe links adjusted so that one is shorter and the other is longer than kit instructions, subtrim is L15. While the throw is close to even left to right, the steering blocks come nowhere near to hugging the caster blocks. It also seems that increasing travel on the radio past 100% gains nothing in throw.
Is everybody getting full throw left and right? Is anybody else running the 6040 with similar or better results?
Any help or info would be appreciated.
J2O is offline   Reply With Quote
Old 10-25-2015, 05:48 PM   #16289
can someone recommend a good setup for a small indoor hardpacked dusty bumpy/smooth med bite track?thanks
Old 10-25-2015, 05:52 PM   #16290
a1
Tires , Im sure you know , are very important.
a1 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
