    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 10-19-2015, 07:50 PM   #16156
Trader Rating: 18 (100%+)
Originally Posted by dway100 View Post
This is probably a dumb question, but how do you get the top shaft bearing out on the closed side? I remember it was a snug fit when I built it, now I just can't seem to get it out.
I use a curved tip dentist pick. Can get a 4 pack of picks from Harbor Freight for $3.
Awesomatix A800XA - Xray XB2 2018
iTz Nicholas72 is offline   Reply With Quote
Old 10-19-2015, 08:36 PM   #16157
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
You can also ask your hygenist for picks. They throw them away after they come out of the autoclave after a certain number of times.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 10-19-2015, 08:48 PM   #16158
the incubus's Avatar
Trader Rating: 17 (100%+)
Your local Pharmacy (CVS or Walgreens) usually sell pocket Dental picks for a couple bucks.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 10-19-2015, 10:49 PM   #16159
Default Converting B5M to 3 gear trans with Schelle
I have the Schelle clutch and I am wondering if I will need anything but the cases, cover and motor plate to convert this buggy from a 4 gear trans to a 3 gear ? Thanks for any help
Stampy79 is offline   Reply With Quote
Old 10-20-2015, 04:07 AM   #16160
thecman26's Avatar
Trader Rating: 99 (100%+)
You could also use the redneck tool: any flat surface such as a table. Slam the gearbox half on the surface a couple times and usually it pops right out.
Another option is just to leave it in there and get a few more bearings so someday down the road you can build a complete 4 gear to have as a quick swap unit? That's what I am gonna do as 5X10 bearings are as plentiful as water, thanks AE engineers!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-20-2015, 05:34 AM   #16161
Volition's Avatar
Originally Posted by Gpeters66 View Post
You will also need diff shims for the 3 gear
Hang on what shims for 3-gear transmission from a 4-gear. I've bought the motor plate shaft and case. I don't remember seeing shims were required?
What part number please?
Volition is offline   Reply With Quote
Old 10-20-2015, 06:15 AM   #16162
The redneck tool worked great. Three smacks on the table and it was out. Thanks!
dway100 is offline   Reply With Quote
Old 10-20-2015, 06:46 AM   #16163
For the record i never heard of needing any extra shims for it.
BrandonBreh is offline   Reply With Quote
Old 10-20-2015, 07:49 AM   #16164
Hello Guys!
Going to make the move from a RC10 B5 to B5M. So was wondering if any set up will translate from the B5 to the B5M. Like shock oil weight? I run 30WF, 25WR at the track I run on. Should I just go with that? Or, is the MM car a totally different animal and start from stock. In all my old RM cars/trucks I have always liked zero anti squat. Would that translate to MM as well?
Anyhow, I am sure a lot have made the switch from a B5 to B5M and would like to learn from others on their experience. Hope to reduce the learning curve a bit!
Thanks!
brian6674 is offline   Reply With Quote
Old 10-20-2015, 07:52 AM   #16165
Default B5m vs. b5m Lite
Hey guys, I currently have the b5m and I was just wondering what is your guys thoughts on the b5m Lite, should I get it? Or do I just upgrade my b5m now? Let me know if the Lite is worth it or not? Thanks!
Wyattander is offline   Reply With Quote
Old 10-20-2015, 08:00 AM   #16166
Trader Rating: 488 (100%+)
The cars feel different. You might have a hard time getting use to the MM car, at least at first. Although the set up for the front of both cars may be similar I'd just go with the book set up and adjust as needed. Also, as if you hadn't heard, it makes little sense to not buy a B5M Lite.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 10-20-2015, 08:32 AM   #16167
Trader Rating: 55 (100%+)
Yes depending on the condition of ur kit. If u run on low traction the chassis def helps. If u run on super high traction the 3 gear helps. It's all preference
Speedychris22 is offline   Reply With Quote
Old 10-20-2015, 09:09 AM   #16168
From my experience of building three different 3 gear transmissions, I have never needed to shim the diff.
islandscott is offline   Reply With Quote
Old 10-20-2015, 09:32 AM   #16169
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
on some I needed to shim and others I didnt. Case by case basis. But it is always a good idea to have various shims around. The top shaft sometimes needs a shim as well if you are OCD
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-20-2015, 09:47 AM   #16170
Gpeters66's Avatar
Go to rc10.com and look up the manual for the B5M Factory lite and go to the section about building the transmission and it will show the diff spacers. Part # ASC1733
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
