    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree11Likes
Old 10-18-2015, 08:35 PM   #16141
Nat Maniac's Avatar
Hi all,
Just a few questions I'm hoping someone can answer,
V2 Shock Shaft Pistons
1. Will the plastic pistons (e-clipped) work with the V2 screw in shock shafts? On occasion I have been known to hit a chicane at very high speed which smashes the lower e-clip so the screw in fronts will definitely help. Not as much as avoiding the chicane would be hey.
Gear Diff Cover
2. Has anyone tried the new metal gear diff cover and is it noticeably more effective and reducing leakage?
Bleeder Screw Gasket
3. What are everyone's thoughts on the shock bleeder screw gasket design. I cant help but think it doesn't seal properly, its very hard compared to the b4.2 and 44.2 rubber o-ring. Are people using any aftermarket alternatives with much success?
Cheers!
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 10-18-2015, 08:58 PM   #16142
3srcracing's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Nat Maniac View Post
Hi all,
V2 Pistons will only work w/ Version 2 pistons. They top is narrower (if I remember correctly) to account for the piston to "sit" on the shaft rather then be held between two eclips. So short answer is no.
Gear Diff Cover
Egh, tough call here. My original didn't leak that bad as long as I got the 4 screws tight. It helped, but not a ton.
There's not really any aftermarket options right now. Nor really another design to base it off of besides the Kyosho shocks.
Cheers!
Answers above.
3srcracing is offline   Reply With Quote
Old 10-18-2015, 09:05 PM   #16143
can anyone tell me what "hard" arms and towers will do over the stock parts? Is it worth getting them? thanks alo
DIRT DIGGER is offline   Reply With Quote
Old 10-18-2015, 09:06 PM   #16144
Nat Maniac's Avatar
Thanks 3Srcracing
Old 10-18-2015, 09:22 PM   #16145
1/4milecrazy's Avatar
Reduce flex. More brittle compared to regular plastic. Only worth it if you are trying top reduce flex. Usually more desired in high bite situations. Mix and match between hard and soft parts for chassis tuning.
Apparently "equal" and "partners" means different things to different people.
1/4milecrazy is offline   Reply With Quote
Old 10-19-2015, 04:16 AM   #16146
Has anyone experience with a combo of Sonic Mach 2 8.5T and GM-GENIUS Race II 80R? A local shop owner told me that, if you arent into pro-racing, you dont need a ESC like the Nosram HD. Would save me up do 100$ and the Graupner ESC seems to be pretty good for the Sonic
The other thing: Can anyone give some information on how long my runtime will be on a standard track? It's hard for me to choose the ideal motor. Sonic Mhac 2 with 7.5T?8.5T?10.5T
man1ac is offline   Reply With Quote
Old 10-19-2015, 06:56 AM   #16147
I've been running this same 17.5 motor along with the X-Car 120A ESC in both my (new) B5M Lite and my son's (my old B4.2FT) car for over a year now. Both are set up in blinky mode with conservative (per the book) gearing and zero end bell timing. Obviously we're not the fastest cars on the track, but our goal is to simply stay ON the track! Upside down doesn't win races, nor do broken cars. Set up like this we can run and run, working on lap consistency, and never worry about overheating anything.
Granted, I'll admit my experience with other brushless hardware is zip. Last time I ran RC was 1988 with brushed mod motors and a Victor Engineering VIC-4 ESC. Still have it, too, and it still works!
Chris
Originally Posted by Fasttrak View Post
Here is a ESC and motor combo for a great price, good one to start off on in stock racing or just playing around.
http://www.hobbyking.com/hobbyking/s...bo_17_5T_.html
"Great drivers have dead flies on the side windows." - Walter Rohrl
N9ZES is offline   Reply With Quote
Old 10-19-2015, 09:09 AM   #16148
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Originally Posted by 3srcracing View Post
For those of you running the +4mm mount, what o rings come in the kit thats "required" to run them?
Can you just run the generic orings, or did they get thinner ones?
They aren't O-rings...they are shims.
https://www.teamassociated.com/parts/details/91605/
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-19-2015, 11:05 AM   #16149
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by SCTDan View Post
Where the contact between the metal pieces is solid the grease is pushed out and does not add any resistance. In the loose areas it remains and helps prevent arcing and corrosion. I've done resistance tests and have not seen any difference in the same connection with and without the grease. However with it the connection does go together and come apart easier.
So you've done nothing but "lube" your connectors then...?
If that's the case then..."user results may vary"
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 10-19-2015, 12:37 PM   #16150
Razathorn's Avatar
I had a peak battery bullet sorta melt the case a little bit, and when that happens, I just re-tension my bullets. I'd rather have them hard to pull out than melt a battery down. Remember how hard deans plugs used to be some times. Yeah, that.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-19-2015, 01:53 PM   #16151
Super Moderator
racer1812's Avatar
No astroglide in the lipo sack for me
Old 10-19-2015, 05:55 PM   #16152
Super Moderator
At first i was just thinking of the electrical contact. But I agree with Racer and Raz. I want my connectors to be secure, I don't mind them being a slight pain. I used to use Sermos/PowerPoles but when I started running on carpet and hard pack tracks I started having disconnect issues. I also want the install to take some effort and thus hopefully some thought to avoid errors.
But hey, if it works for you that's fine, just my thoughts. Thanks for the reply.
Dave H is offline   Reply With Quote
Old 10-19-2015, 06:26 PM   #16153
Originally Posted by Stampy79 View Post
What is involved and what parts do I need to change my 4 gear trans to a new 3 gear ? And will a Schelle clutch work on it afterwards
https://www.teamassociated.com/news/...on_for_the_B5M
Yes all this is doing is flipping around your motor and taking a a gear out. Any slipper is fine.
BrandonBreh is offline   Reply With Quote
Old 10-19-2015, 07:02 PM   #16154
Gpeters66's Avatar
You will also need diff shims for the 3 gear
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 10-19-2015, 07:34 PM   #16155
This is probably a dumb question, but how do you get the top shaft bearing out on the closed side? I remember it was a snug fit when I built it, now I just can't seem to get it out.
dway100 is offline   Reply With Quote
