    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 10-04-2015, 12:27 PM   #15856
Trader Rating: 50 (100%+)
Originally Posted by DIRT DIGGER View Post
anyone know how to put the front axle height to up postion?
U need the schelle bushing pieces
http://www.schelleracing.com/Associa...ng-Set-SCH1087
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 10-04-2015, 12:37 PM   #15857
Originally Posted by Speedychris22 View Post
Thanks chris i couldnt figure out how that was done. Thank you
DIRT DIGGER is offline   Reply With Quote
Old 10-04-2015, 01:11 PM   #15858
or Associated Part #: 91403
will5879 is offline   Reply With Quote
Old 10-04-2015, 01:39 PM   #15859
Great thank you.
Old 10-04-2015, 03:03 PM   #15860
Originally Posted by tsair View Post
That's a B5 to B5M Heavy conversion though, right?
I just added up the parts. I think the conversion kit + chassis, 3 gear, motor plate is about $80, so you can get close for about $160. Still no titanium turnbuckles or HD axles that I forgot to include in the original list.
Seems like the cheapest option is to just sell the B5 for $100 or whatever and buy a new kit.
You never can upgrade a car it seems for a good value. Always best to sell it and upgrade the whole kit used or new.
Earlier this year I looked in a NIB RC8B I had to upgrade to RC8.2 and B44.2 to B44.3 and not worth it at all. Parts add up to usually about a new kit price.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 10-04-2015, 06:29 PM   #15861
Default stock buggy
What is the best batterey to use for 17.5 stock?
Jspires688 is offline   Reply With Quote
Old 10-04-2015, 06:38 PM   #15862
Gpeters66's Avatar
A guy that I race with has ALL the Integy stuff on his car....it is a tank
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 10-04-2015, 08:29 PM   #15863
Volition's Avatar
Anyone used a torque gauge to measure diff tightness. I know you can get screwdriver/wrench torque gauges. Seems like a reliable way to get the tightness right.
There are cheap ones out there.
http://m.supercheapauto.com.au/Product/SCA-Torque-Wrench-Gauge-Angular/214307
Just an idea. What do you think? Could you hold 1 wheel and twist the other with the gauge. To get a reading.
Volition is offline   Reply With Quote
Old 10-04-2015, 08:46 PM   #15864
Trader Rating: 138 (100%+)
Quick question, B5M lite, car is purpose built to run with my Yokomo isn't completely hooked up. Tried running a Nova slipper on it, and the back little plate is rubbing on the motor plate turns out I have about .05mm play on the top shaft that is causing it to rub, doesn't the top shaft on this car sit tight with no side to side play in the diff case? I remember my old B5M didn't have this problem, nowhere in the manual did I see to run a shim anywhere. And ideas would help.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-05-2015, 06:53 AM   #15865
Suspended
Trader Rating: 61 (100%+)
http://m.supercheapauto.com.au/Produ...Angular/214307
Or just go by feel, which works better.
That's a nylock on the diff, if the nylock is a little tight, or a little loose, your torque gauge won't be able to account for that.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 10-05-2015, 06:54 AM   #15866
Suspended
This is pretty easy - pull apart the transmission and see where the play is. You don't want it super tight in the cases, however just like anything, shim to perfection.
Old 10-05-2015, 08:32 AM   #15867
shadowracer24's Avatar
Had that same issue with my Sc5m but not the B5m lite. The tolerance from each kit always are a little off but a little shimming can cure a lot of ill's.
shadowracer24 is offline   Reply With Quote
Old 10-05-2015, 09:16 AM   #15868
kdub's Avatar
The topshaft has some play, so you can add a 3/16" axle shim to space out the slipper. Also you can pull the shaft out to make sure the bearing is completely seated into the case. If you don't have a shim email [email protected] and we'll mail you some shims.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 10-05-2015, 01:16 PM   #15869
Volition's Avatar
The Nylock can be solved for. Nut with no Nylock or have the nut flush against the wheel.
The problem with feel is it is so subjective. What is loose, what is medium what is tight. Let alone what is medium tight to me may be loose to you.
They are cheap enough that I might just give one a try. I'd love to be able to replicate diff tightness from diff build to diff build. Hopefully, get rid off the flick test. Which while adequate is too subjective.
Old 10-05-2015, 01:46 PM   #15870
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Volition,
A group of us tried using a torque wrench with mixed results. Let us know what you find. I personally go by feel.
RCBuddha is offline   Reply With Quote
