    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 09-09-2015, 11:52 AM   #15466
Razathorn's Avatar
Originally Posted by BIGSKI15 View Post
The grey spring will add more push to the car. A stiffer spring will give more initial response but will push mid turn. I usually use a grey sprin on higher traction tracks.
For what its worth, I run the grays on loose tracks too.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 09-09-2015, 12:07 PM   #15467
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
Raz,
I do too at times toe prevent the car from hooking if that is a problem with white springs.
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Old 09-09-2015, 01:08 PM   #15468
Razathorn's Avatar
The faster you drive, the stiffer front spring you want! Go fast guys!!!
Old 09-09-2015, 04:44 PM   #15469
VegasHB's Avatar
I've got my B5m balanced out really well and handling great but I was planning on running on a sugared track this coming week. To start I plan on raising my roll center for the higher grip, is it fair to say removing 2mm ballstud spacers up front and 2mm ballstud spacers in the rear will maintain that balance? I assume the geometry front and rear is close enough to make this assumption?
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 09-09-2015, 07:18 PM   #15470
Anybody try the new reedy mach 3 17.5 short stack or even the regular one? How do you like it compared to other ones?
I have a trinity d4 17.5 maxzilla and i overheated it too many times. Time for a new one.
I run a reedy 8.5 mach 2 when i run modified and it's super smooth. I've heard that trinity is the way to go in stock and reedy in modified.
Not sure if i should get a trinity ss or the reedy ss.
BrandonBreh is offline   Reply With Quote
Old 09-09-2015, 09:01 PM   #15471
So far I have only had the chance to run a Team Powers Actinium, the Trinity D4S Short Stack I bought had issues out of the box.
The Team Powers I love for it's massive torque, geared two teeth low with timing turned almost down to zero, which I think on the TP is still like 30 degrees at zero. Running it at 33\69 this last weekend gave it great corner-to-corner pull, fairly short track with short approaches to two fairly good sized jumps and the torque is useful more than an RPM type motor.
I will say I was not happy to have the Trinity come out of the box with issues but just heard back from Jim Dieter and he confirmed that the motor had issues on one of the poles and is turning the motor around ASAP, nice customer service I must say!
I am dying to get the motor back from Jim and put it through it's paces, I have a feeling it will be good since Jim will be setting it up himself and he tested each phase to see how much timing it was pulling and making the motor right with his own hands. Truly hard to beat that kind of customer service in this day and age of disposable products.
Using the Team Powers motor setup the way the instructions from my B5M and even the TP setup sheet, it was not well matched for the track I run on. They had the motor shifted to spin it up but did not leverage the massive torque it produces. Once I played with the gear ratio, started at 30\69 and worked my way up to 33\69 reducing timing to manage heat. I went from struggling to have enough pop out of the corners to clear the two big jumps to easily having the torque to pop over them with very little effort which made picking lines and driving the buggy much easier and less stressful.
If the track I was running on was a more open and longer style setup, the rpm oriented setup would be preferable, for now I am enjoying having the grunt to get around the corners and drive the torque curve. it was almost pulling a wheely coming down the straight, it had just enough to get the wheels just barely touching the ground.
Fasttrak is offline   Reply With Quote
Old 09-09-2015, 09:37 PM   #15472
Trader Rating: 488 (100%+)
Here's a typical setup for sugared blue groove in 90-105 degree heat:
I run a pretty much book set up in the front other than 0mm on the rack, 2mm under the ballstud. In the rear my set up is pretty basic too. You need to run a long link, I run the aluminum hub w/ball stud in the second longest hole with 1mm under the ball on the hub and 1mm under the inside ball with the ballstud holder flipped in the -2 position. I run a 3 hole 1.4 piston in the front with 32.5-35 and run .75-1mm of extra droop over the box set up w/ white spring but I've been considering grey. The rear I run a 2 hole 1.6 piston 32.5 w/white spring and around .5 - .75 extra droop over the book setting. The proline X2 is the best blue groove tire there is (suburb rears/scrubs up front). If you can't get x2s then orange barcodes are the next best. Regardless of anything else, if you run the oil any thicker the car will feel funny. Even when its 100 plus degrees out the car feels weird with more than 35/32.5. Max the droop out till the car starts to roll over and then reduce a hair.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 09-09-2015, 09:37 PM   #15473
Razathorn's Avatar
No... Probably not. I'd start with 1mm front and low+2mm in the rear. Anything more than that and you're getting out of the range of normal setups.
Old 09-09-2015, 10:10 PM   #15474
Team Powers seems to be a hot motor in Cali. Never saw one here in Michigan. Everyone at my track seems to be running short stacks.
We are allowed to run timing on our speed controls. Our track is a small indoor, rubber surface track. Traction is always through the roof. We run slicks all winter and summer.
My #1 concern with my motors is heat. I'm always squeezing every last bit out of my D4 to get it through 7 minutes. I need a motor that runs cool. I hear the short stacks generate less heat.
I've only ever run a D4 Maxzilla 17.5 as far as 17.5 motors go. I wasn't ecstatic about the performance but i wasn't pissed. Would like to try something this time, but don't mind staying with trinity.
So I guess I will do some more research on the TP motor
Old 09-09-2015, 10:22 PM   #15475
JDe
JDe's Avatar
"Thats not a knife"
Come race in Aus if you want a 'loose' track :P
Green spring ftw.
My Signature > Your Signature
JDe is offline   Reply With Quote
Old 09-09-2015, 11:05 PM   #15476
With our 17.5 class we get endbell timing and blinky mode on the ESC. Heat is always an issue when you are trying to squeeze amps through a motor to get power out of it, higher the traction the more managing it matters. I used to run indoor carpet and it was pretty much the same thing twelve years ago with 27 turn brushed motors, not much has changed in that regard. With the 30\69 suggested gearing I was getting the motor warm but never once did I get the Orion 4500 shorty even mildly warm, with this last setup, 33\69, the battery was coming off pretty warm and the motor was running in the 140's.
What impressed me on our short course layout is the guys running mod motors, most in the 7.5-10.5, had a hard time even pulling me on the infield and got questioned on what motor I was running more than once. The straight, not very long one and ends in an abrupt ninety and an immediate jump into a bowl and that is where I lost ground the most. Actually, my bobbles is where I lost ground the most
Old 09-10-2015, 01:42 AM   #15477
gabc's Avatar
Default B4 compatible parts
Anyone knows if these b4 parts will fit the b5m?
1. Front arms, c blocks n steering knuckles
2. Rear arms n hubs
And is there any other part that will fit? Thanks!
gabc is offline   Reply With Quote
Old 09-10-2015, 03:55 AM   #15478
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
2. Rear arms n hubs
None of the parts fit. It is a completely new car.
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 09-10-2015, 04:05 AM   #15479
gabc's Avatar
Oh shoot. At least the arms look like they'll fit!
Old 09-10-2015, 07:02 AM   #15480
Mason's Avatar
2. Rear arms n hubs
Upper links are the only shared part on the cars.
Mason is offline   Reply With Quote
