    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree17Likes
Old 08-19-2015, 09:58 PM   #15181
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Wildcat1971 View Post
Is it still 4-40 screws?
The 3 screws that go into the exotek slipper elim? no, they are M3s.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-19-2015, 10:12 PM   #15182
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
ah, ok. Thought I read they were 4-40, cool
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-19-2015, 10:36 PM   #15183
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
On the 1st gen ones they were but when they went to the lighter 2nd gen they updated to M3
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-19-2015, 10:54 PM   #15184
RCBuddha's Avatar
Trader Rating: 35 (100%+)
I was about to say that the one I have uses 4/40
RCBuddha is offline   Reply With Quote
Old 08-20-2015, 12:24 PM   #15185
Default Xfactory carbon chassis
I know this might have been asked before, but has anyone run one on the b5m, because I had handling problems last weekend and I think I have tricked my normal chassis by over cleaning a jump. Used my metal ruler, and thought this might be a better way to go. I have my fox shocks on order after feeling someone's else's car, and felt so smooth. So anyone got any advise
tiny tom is offline   Reply With Quote
Old 08-20-2015, 03:31 PM   #15186
Krio's Avatar
Trader Rating: 150 (99%+)
If you are on a lower traction or rough surface, the X-Factory chassis is great. It's what I use as most tracks here are lacking traction. If you are on a higher traction track, pick up a lite chassis for $40 less.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 08-20-2015, 04:53 PM   #15187
Anyone try Yokomo X-Rings on there B5M shocks? They're about half the price of the ASC price gougers...
mgers75 is offline   Reply With Quote
Old 08-20-2015, 05:00 PM   #15188
Super Moderator
I love mine. I run my carbon B5m on a relatively high bite indoor clay that, that isn't all that bumpy, and the car is fantastic.
I run my car with a full sized pack at 1550 (obviously not pictured)
- RCSpecialties -
Old 08-20-2015, 05:05 PM   #15189
Super Moderator
Are they cheaper than the blue traxxas Xrings? I don't run anything else, and haven't seen anything cheaper.
- RCSpecialties -
Old 08-20-2015, 05:45 PM   #15190
$3.19 for an 8 pack @ amain.com. Not sure how much an 8 pack of traxxas runs. Only found a 4 pack with a bunch of spacers for $2.39.
The Yokomo's look just like AE's, going to pick up a pack with my next order and compare them
Old 08-20-2015, 08:09 PM   #15191
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
That is a great looking car! I thought my electronics looked clean!!!
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Old 08-20-2015, 08:48 PM   #15192
Thanks for the replies everyone
Originally Posted by Matt Trimmings View Post
That still shouldn't cause this...that's a tuning option and should not cause the wheels to rub.
Actually, I believe that is what's causing it, as I am using the 2mm option on the spindles. Not much you can do about it when running 2mm. It moves the wheel forward on the spindles. I just started running the b5ML and using a buddies setup since he's been running it for a while. His wheels rub too.
Sean B. is offline   Reply With Quote
Old 08-20-2015, 09:03 PM   #15193
RCBuddha's Avatar
http://www.redrc.net/2015/08/jconcep...nt-rear-wings/
JConcepts have a range of new front and rear wing for the Team Associated B5 series of buggies available. First up is the 6.5″ Finnisher rear wing for B5M buggies. The wing features a high-attack design with trimable rear gurney options and it offers a radical, edgy design which functions and compliments the Finnisher and Silencer body design. The wing mounts low on the vehicle allowing for a lower centre of gravity which is important in high-grip conditions. The lightweight wing features reinforcement ribs to increase lateral stiffness throughout the centre while the hi-clearance areas built into the side-dams allow for rear tyre movement and growth. Cut lines are included for easy trimming while wing mount dimples are included for a drop-fit onto the popular B5M vehicle.
As for the front wings, these are available narrow and wide versions for both the B5M and B5 kits. Mounted above the front shock tower, the wing mounts in “clean air” and is quite easy to trim, use and test without sacrificing all important track time. The lightweight design features reinforcement ribs to increase lateral stiffness throughout the centre. Cut lines are included for easy trimming while triple wing mount dimples are included for a bolt-on fit to the B5 buggy.
Old 08-20-2015, 09:05 PM   #15194
RCBuddha's Avatar
http://www.redrc.net/2015/08/schelle...shock-pistons/
With the release of the latest V2 “screw-on” style Team Associated 3mm shock shaft, Schelle Racing Innovations came up with some new 12mm shock pistons to fine-tune the shock setup. Available in the popular sizes 2×1.6, 2×1.7 and 3×1.4, each size is available in either a traditional flat piston or in a bevel design. The CNC precision machined Delrin pistons offer a precision cut outer diameter with smooth machined outer edge while the tight fit to the shock body reduces wasted blow by around piston edges. Each package contains two pistons, tuning guide, and bevel piston supplement.
Old 08-20-2015, 09:13 PM   #15195
RCBuddha's Avatar
Those front wings remind me of this:
Currently Active Users Viewing This Thread: 8 (3 members and 5 guests)
Crash217, Dmkiefer, MrLean
