    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-13-2015, 11:24 AM   #15046
carcrazy699's Avatar
Trader Rating: 48 (100%+)
Wow! Thanks so much for the explanation. Your track is exactly like my local one. Ours won't hold water during the day also and grooves really nice at night. I can't wait to try your setup on the track. I have been having issues with traction through corners but have tons of rear traction. I am going to switch to the proline holeshots for the front because I am using the ribbed and that could be one issue.
For the ones that are running 17.5 would there be any changes to your setup that we should do?
Losi Ten-T
Losi M8T
Lost M8DB
carcrazy699 is offline   Reply With Quote
Old 08-13-2015, 11:46 AM   #15047
Razathorn's Avatar
Anytime. I try to share when I can.
Where in the corner are you losing traction? Always good to understand what is happening to the car's attitude at that point and what items add or remove rear traction at that time.
Nope. If people run a 3 gear, they *might* want to try half degree inserts in the rear hubs or 21mm droop (SORRY sorry, I mean STROKE, sorry...) in the front for some more rear traction, but that's honestly just a guess, and those two things really change the car too.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 08-13-2015, 12:30 PM   #15048
Trader Rating: 486 (100%+)
Wayne
What we do when we run the track wet is run an 1mm HRC kit and drill a third, inside, shock mount hole, on the arm as well as a lot of droop in the front. Got the idea from some local AE drivers. I run long rear links all the time regardless but I would think that you'd want a shorter rear link for lower traction.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 08-13-2015, 12:41 PM   #15049
Wayne
I am losing traction through the whole corner if I try to keep it under power like a lot of the guys do at the track. I have to basically coast around the corner and right when I can start to straighten out I can get back on power again.
I am running the 3 gear that came with my car. Everything on my car is stock setup besides removing the brace behind the servo and the brace between battery strap. I was thinking of moving the esc forward along with the battery to help with the forward bite. Right now I am running the esc and rx inline.
Hoping I explained the issue decently. I am still learning
Losi Ten-T
Losi M8T
Lost M8DB
Old 08-13-2015, 12:48 PM   #15050
Razathorn's Avatar
I thought so too, but when I tried the shorter standard link, it added a ton of traction in the corner, like it was too stuck, and wouldn't rotate, and then it was more loose getting on power. It just made the car feel pushy and loose.
Old 08-13-2015, 01:10 PM   #15051
Razathorn's Avatar
What kind of corner? Large, small, fast, slow?
Well, obviously the first thing to check is ride height, tires, differential, and camber settings. Having a relatively tight differential is key on low traction.
Old 08-13-2015, 02:15 PM   #15052
Originally Posted by Fasttrak View Post
You can get some really good feedback from the folks in this forum, the trouble is they can only give you ballpark guesstimations on the size of your track, how rough the surface is and what would be "best".
Your best bet is asking folks that have their cars dialed in at the track you will be running at. They have done all the trial and error for you for the surface you will be running on, the gear ratio that works for them in 17.5 (this I found will still require some tweaking as everyone's driving style differs ever so slightly and how you want that power to hit is pretty important).
I would get the car ready and hit the track, pick the folks brain you see running good lines and their car seems dialed, rotates well, has good jumping manners and seems to be dialed in already. Most of these will be happy to share their setups, rarely do I find some one unwilling to help me out at the track I run at.
Thank you for the info! I am hitting the track as soon as I put all electronics together. I bought the car used and it did not come with pinion gear. Just kind of want to have a reasonable pinion gear to start up. Probably it's a better idea to buy from local track.
Again, Thank you very much. I will be looking for guys that run the best on the track. Will be an interesting experience to learn!
T4 '16 - TC 17.5
T4 '14 - USVTA
B5M - 2WD 17.5
yxiaocheng is offline   Reply With Quote
Old 08-13-2015, 02:17 PM   #15053
Depends on the type of 17.5. 69/31-32 is probably an ok place to start for almost any 17.5 but might not be ideal for your track. Crack open the manual. AEs manual setups are pretty good.
Thanks man. I appreciate it!
T4 '16 - TC 17.5
T4 '14 - USVTA
B5M - 2WD 17.5
Old 08-13-2015, 03:01 PM   #15054
Krio's Avatar
Trader Rating: 150 (99%+)
Took some video onboard my B5m this past weekend at Stateline RC and thought I'd share it here. This was Q3 of the handout stock buggy class.
+ YouTube Video
www.kriostasis.com
Krio is offline   Reply With Quote
Old 08-13-2015, 03:48 PM   #15055
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Nice. Love the overhead view coupled with the onboard view.
HB D815v2 (Nova Mito4) / HB D8TTE (Nova Mito7)
HB E817 (Hobbywing XR8 and 1900kv motor)
Associated B6D (Orion and Schuur Speed)
SEF is offline   Reply With Quote
Old 08-13-2015, 04:03 PM   #15056
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
(the length of your link, best adjusted at the hub to not mess with roll center.)
Adjusting your link at the hub certainly affects your roll center.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-13-2015, 06:27 PM   #15057
Razathorn's Avatar
Adjusting the link length wise at the hub does not affect roll center very much. Adjusting it up and down does, certainly.
Adjusting the link length or height at the inside brace affects both significantly. This is why I advocate changing length at the hub if you only want to change camber rise as it has very little affect on roll center.
I can explain why this is the case if you disagree after my clarification.
Old 08-13-2015, 06:57 PM   #15058
+ YouTube Video
That was awesome, front row view of the punts, baby head rocks on that track with the bonus of the over-view video for perspective. Curious what you used for the over-head view? Another person videoing or did you use that tracking gadget with the on board transponder?
Fasttrak is offline   Reply With Quote
Old 08-13-2015, 07:45 PM   #15059
You have this totally backwards. Adjusting the link height is a less drastic change than the link length. By making the link longer you are reducing its angle which lowers the roll center. The upper link is basically an upper arm like a real car would have. All of the the new AE manuals actually address this by saying:
"Changing the length of the camber link is considered a bigger step than adjusting
the ball end height on the rear chassis brace. Shortening the camber link
(or lowering the ball end) will give the rear end less roll and the car will tend to
accelerate or “square up” better. Lengthening the camber link (or raising the ball
end) will give the rear more roll and more cornering grip. Longer camber links are
typically used on high grip tracks, while shorter links tend to work better on
medium grip loose tracks. The kit setting is the best compromise of cornering grip
and acceleration.
AE keeps it basic and doesn't really address this as roll center but that's what they are talking about.
Old 08-13-2015, 08:02 PM   #15060
Krio's Avatar
Over head view was recorded with a gopro clipped to my hat. Had to make sure I turned my head to watch my car and didn't just follow it with my eyes. lol
www.kriostasis.com
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
