Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#9961
Which Kyosho springs are guys running in stock buggy?
#9963
I drove a car with long front and rear links this weekend and it turned on a dime while on power. It also had the +2 trailing insert in also. But the suspension really leaned in the corners making the car turn hard. I run short links and I am undecided which I like better. I plani to do more testing indoors on medium bite since i have 2 b5. Run them both back to back with the same tires. One with shorter links and one with longer and +2 inserts. The car was also using the 30 deg kick
#9964
#9965
Yes you have to reverse or flip them so you can mount the shocks to them. On the rm the shocks mount to the front of the arms. They look identical to the eye but the geometry is different and doing this locks the rear end down better.
#9966
It pushes the rear wheels forward a mm or two, possibly more, this creates more rear grip
#9967
flipping b5r arm
what does it do ?
what does it do ?
#9968
READ!!! Or go talk to your "teammates" Your on this site all day I can't explain it any easier. It locks the rear end down when running on high to med grip. More rear traction. %25 more grip (sarcasm)
I hope people in this hobby can figure out what is upside down when installing the rm arms.
#9969
It is supposed to make more rear grip, or something to that nature
#9970
Ty dezert.....
#9971
its my birthday Monday time to build my mid kit
#9972
Happy BDay Vito! Save yourself some time and dremel out everything from previous posts and install rm front and rear Arms, front shock tower , locktite rear hub ball studs and front axel screw right away. Enjoy the build, one of my favorites to date.
#9973
Super Moderator
