Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree139Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 03-30-2015, 05:35 AM
  #19741
WonTonsChicken's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Mantis Toboggan
Setup advice straight out of the F main
I found the most success with making adjustments to the front end. I started with everything completely box stock, and made my adjustments from there. I did my absolute best to stay as close to stock as I could, or just use options that came in the box. My reasoning for that, is that I wanted to say "the car is stock" if I happen to be doing well.
I drive on either 1 of 2 tracks/conditions. Both are super smooth, and med-somewhat high traction.
The changes I finally did go with were;
Green springs in Front
White springs in Rear
3x1.4 flat pistons up front
Lower the front roll center 2.5mm
I can put a setup sheet up later if you would like, but I know a few other guys that had the same mindset that I do, and they were kickin ACE! Granted, they were had tons more natural talent, or hand-eye coordination, but it is possible to do well with a stock setup. I was also running a 10.5 with timing.
Granted, I would sometimes come off the track with some spicy temps, but I just chalked that up to having a heavier car, and running a square pack.. (spicy temps = 165°F)
Hope this helps ya out some
WonTonsChicken is offline
Old 03-30-2015, 03:46 PM
  #19742
Cpt.America's Avatar
Trader Rating: 52 (100%+)
How in the world are you making changes where you can measure how high or low you are setting your roll center? How do you lower your roll center exactly 2.5mm?
Cpt.America is offline
Old 03-30-2015, 04:27 PM
  #19743
tsair's Avatar
I don't know why, but this is post is f****** hilarious!
tsair is offline
Old 03-30-2015, 04:36 PM
  #19744
HBRob's Avatar
Trader Rating: 61 (100%+)
Perhaps adding 2.5mm to ball studs?
HBRob is offline
Old 03-30-2015, 04:41 PM
  #19745
That doesn't lower the roll center 2.5mm.
Old 03-30-2015, 05:00 PM
  #19746
R/C Tech Elite Member
Jordan Anderson's Avatar
When using the AE aluminum rear hubs, what's the trick positioning or tool for snapping the outer camber link ball cup onto the ball stud?
It was very difficult with needle nose pliers...
Jordan Anderson is offline
Old 03-30-2015, 05:24 PM
  #19747
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Use the built tools on you hand...fingers. Just snap it on.
Jmuck69 is offline
Old 03-30-2015, 05:25 PM
  #19748
Suspended
Take a 5.5mm driver and put it on the ball cup. Then push.
Socket is offline
  #19749
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
sockets idea is better and the way I actually do mine
Wildcat1971 is offline
Old 03-30-2015, 05:41 PM
  #19750
vr6cj's Avatar
Trader Rating: 124 (100%+)
I use my "Man" hands. lol
vr6cj is offline
Old 03-30-2015, 06:28 PM
  #19751
shannow's Avatar
I use a plumbing pliers. Open it to whatever's convenient to grab. Lots of control over it and very neat.
shannow is offline
Old 03-30-2015, 06:42 PM
  #19752
Just use your hands.
Beaver9332 is offline
Old 03-30-2015, 06:43 PM
  #19753
technically, since it's the only way you can actually measure the roll center, he is correct.
Racerbucky is offline
Old 03-30-2015, 06:58 PM
  #19754
Man hands hey? ...
Thanks for the nut driver idea Socket, I'll give that a shot next time.
Old 03-30-2015, 07:18 PM
  #19755
Mizchief's Avatar
+1 I use channel locks or sometimes a big C clamp. Anything that can give you pressure on it straight down vs. at an angle like needle-nose
Mizchief is offline
