Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
And ya the Electrons are awesome! I would get some 2.2 clays as well they also work well when the track is dusty but its good to have both M4's and MC's.
Hello,
I've just joined the forum and im looking for some advise about "inline battery set up" for the b5m. What advantages would I gain and what would the disadvantages be handling wise?
I only race on astroturf tracks in the UK and this setup isn't that popular so there is very little information about it on the UK forums so any help/advise would be great.
Thanks Alex
Thanks Alex
Hello,
Thanks Alex
Thanks Alex
In regards to the slipper, I was trying to back it off in order to allow a softer "on throttle" power curve, to keep the rear wheels under the car and keep the rear from coming around. No matter where I set it, tight or loose, didn't seem to make a difference. Early in the day when the track is tacky, I will run it on the tight side. As far as the B5R arms, that I have not yet tried, although I did shorten the wheel base by moving both rear washers to the back of the blocks... it may have helped a little in forward bite once the car was straight, but didn't seem to help the "throttle loose" condition off the corner. I am not hammering the throttle either, more of a progressive pull... still seems to unhook fairly east though. I ordered the M4 Electrons, and we'll see how that works next week. Don't want to try too many things at once.
Half way done with the build, so far very impressed with how easy the build is.
Hi everyone just have one question what are good tires for the B5 front?? I hear a lot of ppl running 3 o 4 ribs tires but is that the best tires for the front of a 2wd buggy. The track I run is hard pack and blue groove..
THanks
THanks
you have to ask the locals that. we really cant answer that
Hey, so I am curious....
I just got a fresh JGoPaintz body for my B5 and I really don't want to cut a hole in it for the antenna.
Two reasons actually....
I don't want to cut a hole in the beautiful paint, and the antenna tube is bent anyways so it looks like crap.
So I was wondering if there is any way to route the antenna to where it will still get adequate signal and be contained inside the body?
I was thinking about running it to the rear through the top center hole in the shock tower and route it right above the transmission.
wing hold down mod
Here is a nifty way to hold down your wing. I used the proline body hold down kit. I cut the nubs off the plastic wing mount and drilled it out. Then threaded th. Threaded post in put the wing on then oring then thumb screws.
The stock Plastic mounts help it flex to keep it from trashing your wing.
I actually did this on my mid motor b5 which I still have. I have sold my rear motor tho. Will work fine on the rear motor too tho.
Oh the reason i did this was it was a pain in the ass getting the body clips on with certain wings.
I know the opinions are gonna be biased here. But I can't decide between this or a 22 2.0. what do you guy think?
What pinion are u using with the stock 81t spur? I have a 17.5 kill shot going in.
Ok...thanks.
This thing is coming together like butter...Can't wait to see how these little guys hold up.
