    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-07-2015, 12:26 PM   #14941
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Originally Posted by Razathorn View Post
Everybody calls it droop man
Just be clear when you indicate what you're measuring, like "20.5mm exposed shaft."
Wayne
Maybe he wasn't talking about his shock... but some other shaft.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 08-07-2015, 12:45 PM   #14942
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
How effective will sharing setups be if everybody is using a different term for something? Without defined terms, communication becomes difficult. "droop", "shock length", and "stroke" are all very different things.
Now you got it. "exposed shaft" is what we call the "stroke".
Perhaps I didn't articulated it well enough.. maybe these guys do it better.
http://www.rccaraction.com/blog/2011...al-with-droop/
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-07-2015, 02:04 PM   #14943
RCW
Trader Rating: 16 (100%+)
Originally Posted by Cpt.America View Post
That's not droop, that's stroke length. If you want to measure shock stroke, you measure the length of the exposed shock shaft when it's pulled all the way out. (See picture from post above mine here)
Droop is difference in ride height between static sitting ride height, and how high the chassis is at the point the tires begin leave the ground.
If everything stays the same except ride height, won't the chassis be at the same height when the wheels come off the ground?
My point is that in a TC droop is not effected by ride height. It is how far the suspension travels down below a set point.
RCW is offline   Reply With Quote
Old 08-07-2015, 02:13 PM   #14944
Super Moderator
My point is that in a TC droop is not effected by ride height. It how far the suspension travels down below a set point.
Yes, but that isn't droop either. Droop isn't how high the chassis is when the wheels lift... its the difference between static ride height and how high the chassis is when the wheels lift off the ground. And yes.. TC droop IS affected by ride height, just the same. Chassis type doesn't matter. Don't confused droop, with downstops. Read the link I put up.
- RCSpecialties -
Old 08-07-2015, 04:32 PM   #14945
I LIKE THIS EXPLANATION MAKES SENSE
jslider is offline   Reply With Quote
Old 08-07-2015, 06:39 PM   #14946
Originally Posted by carcrazy699 View Post
Thanks for the advice I didn't even think of those things. They slipped my mind. I will have to look at all of that and see what its all set at. I do just screw the shock ends on and not even think that it can cause issues also. As for tires I am running what I was told is the best for the track but I am going to try proline hole shots for the from instead of the ribs that I was told to use. I also honestly have no idea how to measure droop. I am getting a ride height gauge soon to help get that set proper.
Here is a trick that works extremely well and will earn you plenty of answered questions from the guys at your local track.
On your next practice day or race day pick out one of the better drivers at your track, one that runs a car like your own. Try and pit real close to this person. Get all setup in your pit and make a call to the best local pizzeria that delivers, make it a large or extra large with the works. Once pizza arrives, you will have numerous folks drooling from most orifices, just offer a slice to any and all for some tech support on setting up and understanding your car. You will have plenty of folks offering their help
Fasttrak is offline   Reply With Quote
Old 08-07-2015, 10:22 PM   #14947
When you build the shocks you have to insert a shock pivot ball 91448 in the bottom in the shock eyelet.
Are they supposed to be tight?
Mine were tight. Tight enough that once the shocks were mounted I could disconnect the top mount and the bottom mount would hold the shock up straight.
How can I loosen up the lower eyelet and pivot ball?
tekin112000 is offline   Reply With Quote
Old 08-07-2015, 10:37 PM   #14948
Super Moderator
They can be snug, but will losen up over a couple runs. Also, the screw that goes into the arm needs to be just barely snug too... don't over tighten.
- RCSpecialties -
Old 08-07-2015, 10:47 PM   #14949
snaketaco's Avatar
Would a b5m lite work good in mod on a high traction track?
My apologies for any errors in grammar, and spelling. It's a forum not a term paper! STADIUM TRUCK FOREVER!!!
Some day I want to be one of the guys with the cool T shirts and fancy stickers. I bet they get all the girls!
snaketaco is offline   Reply With Quote
Old 08-07-2015, 11:23 PM   #14950
Super Moderator
Most of the mod guys at my track are running the lite kit.
- RCSpecialties -
Old 08-07-2015, 11:35 PM   #14951
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
umm, Spensor, Tommy and pretty much everyone else fast is running the Lite at SRS this weekend. People need to stop thinking it is for stock....
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-08-2015, 07:44 AM   #14952
snaketaco's Avatar
Cool thank you guys.
Old 08-08-2015, 08:12 AM   #14953
Well there are two kits available the standard and the light and the light is advertised to the stock racers so it is a pretty honest question I had the same one before I got mine, they should just drop the regular b5m the light is a much better value and it would eliminate any confusion. you would only have the best option available a B5M light.
Old 08-08-2015, 09:00 AM   #14954
snaketaco's Avatar
Thank you. So is a lite kit with out the pucks is the way to go for mod? I started my rc break just as the b5m was taking off so not sure what everyone has been running...
Old 08-08-2015, 09:09 AM   #14955
Thomas PA's Avatar
Talking
Its ready to go out of the box. If your tractions really low, you may want a 4 gear. If your tractions really high, you may want a low rider. I'm a fan of carbon chassis as well. Less weight, better flex, never tweaks. But ultimately, its great out of the box
-Thomas Kauffman
KDRC Carbon Fiber Upgrades
Bumps & Jumps RC, Pit Stop Hobbies
X6^3: Tekin, Fantom, Sav÷x
B5M: KDRC, Fantom, hobbywing, Sav÷x, Schelle, AC RC
Thomas PA is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Joosh M
