    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 08-05-2015, 08:12 PM   #14896
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by Fasttrak View Post
I am doing some upgrades with ceramic bearings, Schelle slipper and MIP pucks. I had grabbed the Schelle captured ceramic thrust balls and washers and was curious if I can use this along with the MIP puck setup? Rather ask than find out later I damaged or ruined some expensive parts.
use the "hat" thrust from the pucks kit with the schelle thrust and 1 of the washers
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-05-2015, 09:26 PM   #14897
Originally Posted by STLNLST View Post
Yes you can
Thanks to both for your replies.
Everything went together nicely except I believe the hat on my right dog-bone was milled slightly off center. It has a wobble to it and I fear running it would ruin the brand new ceramic bearing. I didn't notice it when I finished it up and installed both in the car, spin it up and it is pretty obvious that it has about a quarter millimeter wobble. I pulled that one apart and inspected the reused pin and leg that goes through the hub and I can not see anything that looks off. The stock setup did not have any noticeable wobble so it has to be the milled portion of the steel head of the dog-bone. Has anyone seen this before with one of the puck top-hats?
Fasttrak is offline   Reply With Quote
Old 08-06-2015, 12:44 AM   #14898
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
Originally Posted by kuruption View Post
thanks!
RC*PHREAK is offline   Reply With Quote
Old 08-06-2015, 08:39 AM   #14899
k1ller rc's Avatar
Trader Rating: 306 (100%+)
Originally Posted by k1ller rc View Post
Does anyone know the stock weight of a Factory lite without any gear in it? Just a bone stock roller, no tires or wheels?
So far, no one knows?? Comon, Someone has to be as meticulous as me..
Im hoping to get an answer, the AE Website says it "Varies"
k1ller rc is offline   Reply With Quote
Old 08-06-2015, 08:42 AM   #14900
What are you trying to do? compare to other brands?
Old 08-06-2015, 08:55 AM   #14901
k1ller rc's Avatar
Yes. That is one reason, but my main goal it to figure out as much with weight and transfer before i get the kit so I can order parts/upgrades. I have some parts weights differences already.
Old 08-06-2015, 09:08 AM   #14902
A naked car wont be much help. If you want it light, but have a certain balance. buy the "light" stuff and add lead where you need it. Tires, wheels and so many other facts go into it. IMO your planning is a bit premature. I would also not buy an ESC strictly for its weight. If you want a LP servo, they are a little less durable, but it is light and you can add lead as far forward or rearward as you like. Use lower gauge wire, shorten your leads, get Ti screws and pucks. That add weight where you need it. And comparing a naked tlr to a naked b5m, is apples and oranges. even at the same weight they dont drive the same.
Old 08-06-2015, 01:05 PM   #14903
Trader Rating: 48 (100%+)
Anyone run the VRP pistons?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 08-06-2015, 01:15 PM   #14904
nah, those pistons are for scrubs
Old 08-06-2015, 04:13 PM   #14905
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
I'm relatively consistent - most laps are usually within .4/sec of each other. These pistons by themselves gave me another .1 to .2/sec per lap. They are the best upgrade I've found for this car as well as my D413 wheeler. If you're a solid driver, you will not find the amazing improvement that they claim on their website. However, you will notice a difference in handling and it will be for the better.
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 08-06-2015, 04:47 PM   #14906
All Illinois drivers say this ... Just saying....
Old 08-06-2015, 05:09 PM   #14907
PLAY NICE LEIGH,
jslider is offline   Reply With Quote
Old 08-06-2015, 05:09 PM   #14908
Currently in my stock car I'm running 2x 1.6 front and rear Pistons, if I go to 2x1.7 In the rear How will that effect the car?
My Credit Card
Old 08-06-2015, 06:24 PM   #14909
Originally Posted by jslider View Post
PLAY NICE LEIGH,
Well it is true. I think VRP is out of Illinois or Ohio and all the locals say the same thing, like it is a script
Old 08-06-2015, 06:25 PM   #14910
softer rear, more weight transfer to the rear. maybe less on power steering
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
