    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 07-24-2015, 09:01 AM   #14716
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by eddie10 View Post
Put one of the old thrust wahers on first then the avid. Avid is thinner and the screw runs out of thread.
THIS^
The avid thrust is a good millimeter thinner overall than the stock one, so the bolt runs out of threads. However, Right where the bolt maxes out, is right where I like to run my diff
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-24-2015, 09:11 AM   #14717
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
They designed it that way
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-24-2015, 09:21 AM   #14718
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
THIS^
I used the Avid ceramic thrust in both of my cars (one now sold) and never had this issue. I don't use the "flick" method for setting my diffs though either. I simply hold the spur and turn one wheel by hand and "feel" how tight it is. Maybe I got lucky, or I simply like my diffs more free than others? Obviously without slipping.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 07-24-2015, 09:42 AM   #14719
Super Moderator
oh, I am also running the MIP bolt, as I find the AE ones to be garbage. Maybe the thread count is SLIGHTLY different? I'm not sure.
- RCSpecialties -
Old 07-24-2015, 10:27 AM   #14720
Trader Rating: 68 (100%+)
Originally Posted by racer1812 View Post
The arms are not on wrong. No matter what arms you use if they're on the wrong side, it moves the shock mount to the front of the arm. Which will be a VERY noticeable problem. If we really want to get picky the pic from RC Car Action is of a B5m, not a B5m lite. The location of the screw holding in the hinge pin tells you so.
It's all a moot point. He already said he figured it out.
True.
For some reason I was thinking the shock mount holes were on both sides.
-Dave
Race: B64D / B6D / B6
Coming Soon: Tekno EB410?
Pinebox is offline   Reply With Quote
Old 07-24-2015, 10:59 AM   #14721
Super Moderator
racer1812's Avatar
Originally Posted by Pinebox View Post
True.
It's all good
Old 07-24-2015, 11:05 AM   #14722
Super Moderator
racer1812's Avatar
Hmm..I'm on the stock AE bolt without issue..Maybe one of those "is what it is" situations?
Old 07-24-2015, 12:09 PM   #14723
The rear arms look backwards to.
On the lite kits, the "R" arm goes on the left and the "L" on the right side.
They are actually the regular B5R arms. Little confusing to say the least.
Swapping those will kick the hubs more forward away from the shocks. Check the RC car action pic Chris above.
This! Gave me so much trouble. Lol.I was trying to figure out why they looked correct on the wrong side. That was half the battle.
slashed is offline   Reply With Quote
Old 07-24-2015, 03:10 PM   #14724
Super Moderator
I'm sure. All I know is on my original diff bolt snapped like a toothpick.
Maybe a month or so after I bought my B5m,.. after an afternoon of racing, a fellow racer wanted to take my car for a spin on the track to see how my car drove compared to his. He was curious as to how I typically had my car setup to drive. I said "SURE... but let me tighten my diff just a tiny bit first... it feels a little on the loose side". My intent was to give it a 1/16th turn.
I put the car on the bench, inserted my 2mm wrench in the outdrive, and started to turn the bolt. The moment the very first NANO-ounce of pressure was applied (or whatever you would call the smallest amount of measurable force).. the bolt snapped in half. It wasn't already tight, and it wasn't bound up, nothing like that. I make small adjustments to my diff all the time, THOUSANDS of times, in countless cars.
Let me stress.. this bolt felt like it had maybe 1/100th the strength of a toothpick. I later found out that there were 2 or 3 other guys that had their diff bolt snap in similar ways, earlier.
Anyway... I went to the MIP bolt right away and never looked back. I am sure my bolt had a defect, it was an anomaly, and there are probably a pile of AE diff bolts out there that are as good as my MIP... but it seems to happen to some percentage of the stock AE diff bolts.
- RCSpecialties -
Old 07-24-2015, 03:18 PM   #14725
bilster44's Avatar
Originally Posted by Wildcat1971 View Post
I run the avid thrust in my stock diff and my pucks. I do not have this issue.
Same here Leigh...what the heck?
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 07-24-2015, 07:11 PM   #14726
Cridd's Avatar
Trader Rating: 16 (100%+)
I run the mip bolt too, son broke an AE and just switched. Only broke an MIP when I WWf that thing the other night.
I have to get off the flick method. Went to hold the tire and spur and see if it will slip and adjust as needed. No slippage so it is good, flick method feels loose.
You guys ever set a slipper on a 13.5, ihear the squeal, tighten more littledifferent pitch then tighten again and it pops up....good to go. This time I was setting it on my 13.5 and got the squeal but after that instead of pop up, a little shutter like it had a 25.5 in it . Backed off squeal but never could get to pop up. Diff is good on this car, slipper looks good, car is fast but weird.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 07-25-2015, 05:00 PM   #14727
klaymon's Avatar
Trader Rating: 71 (100%+)
I just received the brass rear suspension mounts with inserts. Which inserts will go in that to put the rear toe/anti-squat at the same settings as the original plastic mounts?
Thanks.
klaymon is offline   Reply With Quote
Old 07-25-2015, 07:11 PM   #14728
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Thanks.
Use the same C inserts as you were using for the plastic c holder. Look for the numbers on the side of the grey inserts. For the D block arrows point in.
HBRob is offline   Reply With Quote
Old 07-26-2015, 12:05 AM   #14729
carcrazy699's Avatar
Trader Rating: 48 (100%+)
So tonight I finally got my car all setup and ready for the track. I figured I would weigh it just to see what it would be at. It sits right at 1526g. I am running a D4 maxzilla 1s short stack, tekin rsx, full size airtronics servo, thunder power 3800mah shorty and stock body.
I am guessing this is a good weight to be at. I am wondering what can I do to help to get less drag in the drivetrain. My car is new and I know it will need to "break in" but what else could be done? I have looked into the puck system and also considering the shelle racing slipper. Not sure what else I could do besides tear out all bearings and clean the grease out of them and put my avid bearing oil in.
Losi Ten-T
Losi M8T/Hobbywing/Turnigy/Savox
A.E B5M Lite/Tekin/Trinity
carcrazy699 is offline   Reply With Quote
Old 07-26-2015, 04:15 AM   #14730
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
Cut gears(17.5) and ceramic bearings
"The successful warrior is the average man, with laser like focus"-Bruce Lee
"A lot of people are afraid of heights. Not me, im afraid of widths"
KAWIDAD is offline   Reply With Quote
