    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-23-2015, 06:15 PM   #14701
Try switching the rear hubs.
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Old 07-23-2015, 06:33 PM   #14702
That looks like what I have here. I'm so confused. Haha.
slashed is offline   Reply With Quote
Old 07-23-2015, 06:36 PM   #14703
Look closer!!! Swap the hubs left to right, right to left
Sean B. is offline   Reply With Quote
Old 07-23-2015, 07:12 PM   #14704
celt's Avatar
No...that's not at all what the last post showed - they are backwards.
Simply switch the hubs and you're good to go.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-23-2015, 07:36 PM   #14705
Figured it out. Sorry for the dumb questions. Thanks everyone for the help! I took the rear end apart no less than five times trying to switch things around and get it to work.
Old 07-23-2015, 08:13 PM   #14706
celt's Avatar
No worries, we've all done it - those who haven't are lying.
Stan Garvin
Old 07-24-2015, 12:11 AM   #14707
Cridd's Avatar
Trader Rating: 16 (100%+)
Default Diff
Built a new diff, all parts from the B5m lite manual, upgraded rings, mip thrust nut, avid ceramic thrust, usual stuff I build them with. For some reason I can't get it tight, when I spin the wheel it goes around 2 times. I took apart checked it, tightened so tight broke thrust bolt, took apart again, looked an manual, feel I am missing something. Put together re broke it on, still feels too free to me. Does not feel like all my other 3 gears, which spin 1 time and kind of come to an abrupt stop. Rebuilt a new diff for back up but usually when I tighten the thrust the outdrives get tight to where I have to back off a 1/4 or 1/2 again this one feels loose and can't tighten anymore.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 07-24-2015, 04:57 AM   #14708
Thomas PA's Avatar
The avid thrust bearing is thinner than a normal thrust bearing. Don't know if that could be part of your issue or not. Since you said you usually use them
Thomas PA is offline   Reply With Quote
Old 07-24-2015, 06:10 AM   #14709
Trader Rating: 68 (100%+)
The rear arms look backwards to.
On the lite kits, the "R" arm goes on the left and the "L" on the right side.
They are actually the regular B5R arms. Little confusing to say the least.
Swapping those will kick the hubs more forward away from the shocks. Check the RC car action pic Chris above.
Pinebox is offline   Reply With Quote
Old 07-24-2015, 06:18 AM   #14710
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I run the avid thrust in my stock diff and my pucks. I do not have this issue.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-24-2015, 07:16 AM   #14711
Trader Rating: 483 (100%+)
You can't always go by feel until the diff has been used a bit. Since you broke it in I'd put it in the car, check it under load, and give it a battery pack. Unless there's a part [or parts] that are poorly machined I don't see how the diff could not be right if its assembled correctly. I guess its possible that you didn't pre-collapse the spring in the diff with pliers or maybe you put the diff nut in backwards....but I doubt it. I know that you've built a few diffs.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 07-24-2015, 08:03 AM   #14712
Trader Rating: 26 (100%+)
Put one of the old thrust wahers on first then the avid. Avid is thinner and the screw runs out of thread.
eddie10 is offline   Reply With Quote
Old 07-24-2015, 08:10 AM   #14713
take 2 wrenches drop them in the slots of the outdrives. hold together in one hand. get a towel and grab the diff gear and try to slip it. if it slips tighten diff 1/8th turn. repeat above.
get it so it slips just slightly then tighten it. And then try slipping it with the towel again. If it doesnt slip its ready to go in the car.
Bear in mind you have to use alot of force with your hand to get the diff to slip. But I guarantee it will be close
Bubonic-X is offline   Reply With Quote
Old 07-24-2015, 08:43 AM   #14714
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
The arms are not on wrong. No matter what arms you use if they're on the wrong side, it moves the shock mount to the front of the arm. Which will be a VERY noticeable problem. If we really want to get picky the pic from RC Car Action is of a B5m, not a B5m lite. The location of the screw holding in the hinge pin tells you so.
It's all a moot point. He already said he figured it out.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 07-24-2015, 09:00 AM   #14715
mjbtaco's Avatar
Got the replacement hex and finished up the build. Gonna go run it today at OCRC.
RTR weight
and the fleet ready to go
Barrios Paints
mjbtaco is offline   Reply With Quote
