    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 07-22-2015, 01:02 PM   #14656
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
Originally Posted by QDRHRSE View Post
I'll have to disagree. I have 2 cars that are almost identical other than pucks in one and the fox shocks and no pucks in the other and they feel almost exactly the same. I run the same motor, esc, and servo in both....the set ups are the same, both have SLRC chassis etc etc. The only big difference that I can feel is that the pucks car spools up a hair faster and the throttle is hair lighter. We run outdoors on high grip bluegroove. If there's a discernible difference in cornering maybe its more pronounced on clay.
I've never heard anyone claim any difference other than this.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 07-22-2015, 01:16 PM   #14657
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Perimeruna View Post
Is there a difference with those red X-rings (Part #: 91055) and these white/clear ones (Part #: 91493)?
Yes. The red ones are wrong and not designed for use in the B5m/T5m. The clear x-rings #91493 are the correct rings for the AE 12mm V2 shocks.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-22-2015, 02:20 PM   #14658
Thanks for correcting that. The red are 13mm.
Looks like my next car will be the lite for the winter months.
For mod are there any must have parts?
Was thinking JConcepts 4 Ball Stud Mount
RC8B3 for the summer.
Thank You guys.
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Old 07-22-2015, 04:53 PM   #14659
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
the car also rotates better with less weight in the rear...at least on high bite indoor clay. 25g out of the rear is noticeable.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-22-2015, 04:58 PM   #14660
that was my observation. I left my setup alone and just put the stock diff and bones in. same tires, same everything. Car pushed like a dump truck. I moved the battery forward a little and played with weight and it is better. I also went from a shorty servo with the pucks to a full servo with the steel diff, which helped. basically, I needed to move some weight forward. I have noticed this a few times when going back and forth. It has been my observation. Did it effect my lap times? No. I just adjusted my driving and car to make it better. again, it was something I noticed over the last year when switching back and forth.
Old 07-22-2015, 05:57 PM   #14661
I ended up picking up my B5M Factory Lite today so now I just need to decide on the electronics. I simply do some backyard and club racing so I'm not to worried about regulations. Here is what I'm thinking:
Motor/Esc - Hobbywing Justock 8.5T possibly 10.5 combo
Servo - Savox 1257TG .07 speed/138oz torque
Lipo - 2s SMC 5800mah Square Pack
Tire - Rear Proline bowties or Jconcepts Goosebumps (Loose outdoor track)
Front Not sure
Pinion - Not sure for gearing with the Hobbywing and stock spur of the B5M I guess it will depend on motor as well.
Does this seem okay? This is my first 2wd buggy and I know it can get a bit cramped inside for the electronics. Is there anything at all I need to consider on top of what I listed? Will be ordering online.
Fanatic01 is offline   Reply With Quote
Old 07-22-2015, 09:49 PM   #14662
mjbtaco's Avatar
Was bulding my lite today and had a problem with one of the rear hexes. the threads for the set screw stripped out so I have to go buy a new set tomorrow. pretty disappointing. Other than that the build has gone smoothly. gonna finish the shocks tomorrow.
mjbtaco is offline   Reply With Quote
Old 07-22-2015, 09:59 PM   #14663
carcrazy699's Avatar
Trader Rating: 48 (100%+)
Looks sweet man! I see your super close to me! I will probably be seeing you at peg!
Another note I was looking on MIP website and saw there is 2 different puck systems for the b5m. Which one would be the right one?
This one
http://miponline.com/store/mip14230.html
Or this?
http://miponline.com/store/mip14190.html
Losi Ten-T
Losi M8T/Hobbywing/Turnigy/Savox
A.E B5M Lite/Tekin/Trinity
carcrazy699 is offline   Reply With Quote
Old 07-22-2015, 10:10 PM   #14664
3srcracing's Avatar
Trader Rating: 25 (100%+)
Top one (Regular) is for stock buggy.
Bi-metal is made for 17.5 and faster motors.
3srcracing is offline   Reply With Quote
Old 07-22-2015, 10:12 PM   #14665
3n90t's Avatar
Same here. Both set screws snapped. They are only 1.6mm screws. Emailed AE...no response for 4days. Not like AE
3n90t is offline   Reply With Quote
Old 07-22-2015, 10:16 PM   #14666
Thanks a lot! I will be seeing if my LHS has it in stock if not I will order them and have them brought in.
I talked to the shop about the clear x-rings and he said they don't make that big of a difference. I also asked about the "fox" shock bodies and he said the same about them to. What are your guys opinions that are running them? I just want this car setup from the start. I know I should run it stock but I can never leave anything stock!
Losi Ten-T
Old 07-22-2015, 10:21 PM   #14667
mjbtaco's Avatar
Yeah i had an old set of aluminum hexes from my b5m and they dont fit. tried the set screws from them and those are too big. I dont understand why they would make the screws smaller. Makes no sense.
Old 07-22-2015, 10:29 PM   #14668
3n90t's Avatar
I have spare axles and hexs from my B5 RM. They've never failed my in 12months. I'll only be running stock so no need for the new HD axles.
Funny...HD axles with piss weak hex set screws
Old 07-22-2015, 10:46 PM   #14669
mjbtaco's Avatar
seems like a winning combination...
Barrios Paints
Old 07-22-2015, 11:14 PM   #14670
mjbtaco's Avatar
Thanks! I can't really race at Peg. I work Tuesday nights so don't have a chance to make it out there. Which sucks since i live like 3 miles from there lol
Barrios Paints
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Gary78, RodRC
