    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 07-20-2015, 11:43 PM   #14626
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Jvcaniggia View Post
Have a SCT and new to buggy. Just bought my first since an 89 losi jrx2. . Have a savox 1258 in a basher. Is that a good servo for the b5m? need to work on driving before getting too notch gear. Thanks!
Any standard size servo will work just fine.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-21-2015, 05:54 AM   #14627
mjbtaco's Avatar
Gonna be building a lite kit this week. Are most people ditching the aluminum axels for titanium ones? I had the exotek front axels on my last b5m but they went with it when i sold the roller.
mjbtaco is offline   Reply With Quote
Old 07-21-2015, 06:57 AM   #14628
JeepnMike's Avatar
I haven't heard of anybody replacing the aluminum axles for titanium, at least here or at the track I visit anyway. I will say I am impressed with how strong they actually are. I was a little nervous about the durability of them too. With me being a novice driver, I crash probably more often than you do and they have held up great - to the point that I don't even carry a spare and I am a spare parts hoarder.
TRF801x - DB01RR - B5m Lite - TB03 - Variety Of Vintage Tamiya
JeepnMike is offline   Reply With Quote
Old 07-21-2015, 08:19 AM   #14629
Trader Rating: 478 (100%+)
I just broke an aluminum axle on Friday. It was my fault. I think they are ok. The Ti ones are better and that's what I'm replacing the aluminum with. That being said, I'd keep the stock Lite axles until its time to replace them. They've proven to be durable enough.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 07-21-2015, 08:34 AM   #14630
ordered my B5M light last night anything I should look at for the kit build many I have talked to say to build the kit as is but figured I would ask for opinion here
jslider is offline   Reply With Quote
Old 07-21-2015, 08:44 AM   #14631
Thomas PA's Avatar
The kit is fine as is, but, consider the surface you're running on. You may want to add a brass bulkhead if you're on carpet, or brass rear arm mounts if you run low traction, or cut the cradle to accept inline setup before you screw it on. But nothing is needed off the bat
Thomas PA is offline   Reply With Quote
Old 07-21-2015, 08:51 AM   #14632
Super Moderator
Originally Posted by KAWIDAD View Post
Now that the "fox" shocks have been out for a min,I am curious, to what people that have tried them think about them. Getting ready to pull the trigger on them and just can't make mind up on what shafts to get. From what I understand the chrome shock shafts will be smoother while the tin will last longer. Anybody tried both?
Originally Posted by QDRHRSE View Post
They're smoother than the stockers and I run the TiN shafts. They're similar in feel to a Kyosho shock.
I concur 100%.
- RCSpecialties -
Old 07-21-2015, 09:00 AM   #14633
I run on high bite clay at SRS in phoenix mostly, so may just build it out of the box and upgrade parts as needed, just wanted to make sure I wasn't going to have to tear it down again to put in a minor part the day after I build it, of course I have done that many times also
Old 07-21-2015, 10:59 AM   #14634
triplesix's Avatar
the only item I found worth replacing was the slipper unit. the schelle/avid clutch works amazingly consistent.
triplesix is offline   Reply With Quote
Old 07-21-2015, 11:05 AM   #14635
Slider I run at SRS too and the stock setup will be fine for now. Just make you use slicks for your tires. I use Primes
Jake
Bubonic-X is offline   Reply With Quote
Old 07-21-2015, 11:21 AM   #14636
PRIMES for everything at SRS for sure LOL
Old 07-21-2015, 02:24 PM   #14637
awidz's Avatar
anyone used primes on carpet track, wondering how they work
awidz is offline   Reply With Quote
Old 07-21-2015, 03:50 PM   #14638
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
Any specific reason you went with the TiN shafts?
"The successful warrior is the average man, with laser like focus"-Bruce Lee
"A lot of people are afraid of heights. Not me, im afraid of widths"
KAWIDAD is offline   Reply With Quote
Old 07-21-2015, 04:11 PM   #14639
onefast8's Avatar
Trader Rating: 41 (100%+)
Rumor is they last longer....TBD
Jake R.
onefast8 is offline   Reply With Quote
Old 07-21-2015, 05:58 PM   #14640
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
if you dont want to tear it apart after building, build with xrings. You can get by with the kit pistons. And you already have some spring kits. just watch the video on the ball cups. and build it with pucks if you plant to go 17.5, or leave it if you plan to run mod with me
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
