    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 06-12-2015, 06:55 AM   #14176
Originally Posted by Aaron33 View Post
Do aluminum rear hubs make a difference on the b5m?Besides making the car heavier. Is it worth the $40?
They look dope
BrandonBreh is offline   Reply With Quote
Old 06-12-2015, 07:11 AM   #14177
dbowen's Avatar
Yes I absolutely think they do and I have ran the plastic back to back with the aluminum and my car felt worlds better with the aluminum hubs. I think just like in 1/8th scale the weight right on the wheels is what really makes the difference and then you can fine tune your roll center better. Also if I was you I would get the Schelle aluminum hubs I think those also made my car even better than the AE aluminum. You can fine tune the length of your camber links more and if you strip it or break a ballstud you just have to replace the cap instead of the whole hub.
Here is a link to the Schelle Hubs.
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 06-12-2015, 08:01 AM   #14178
Trader Rating: 29 (100%+)
Also less wear on the bearings...
DustinEich is offline   Reply With Quote
Old 06-12-2015, 08:05 AM   #14179
I like the added weight of the aluminum hubs as well as the simplicity of them.
Yokomo YZ-2
Yokomo YZ-4
Fantom | Lunsford | MurfDogg | Pro-Line | R1 | Racing Performer | Sanwa | Schelle | Tekin | TLR
rbk1115 is offline   Reply With Quote
Old 06-12-2015, 10:15 AM   #14180
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
I added the Aluminum hubs this weekend after my plastic hubs failed. The plastic spacer at the top collapsed and caused the aluminum bit with the ball stud attached to fall through the hub and add a ton of slop mid race. Once adding the aluminum hubs the car had better rear grip. Plus I like the adjustment options. I would have gone with Schelle if they were in stock at the track
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 06-12-2015, 10:18 AM   #14181
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Good to know. I am trying to get rid of rear grip, so I will stick with my plastic one . But yeah, I can see more weight over the rear wheels adding some grip. How much more does each hub weight? Just curious.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-12-2015, 11:01 AM   #14182
Vigilante212's Avatar
Originally Posted by Sean Cochran View Post
If you bought a conversion and you need the other style gearbox call AE customer service and they will send you the correct one.
I needed it for tonight, so I just purchased the updated aluminum shaft and bearings not a big deal just annoying.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 06-12-2015, 11:20 AM   #14183
VegasHB's Avatar
It's un-sprung weight. I like the stock hubs and if you install them using the updated T5M installation method using a washer, longer ball stud and locknut then you don't have any issues with crushed spacers or them coming loose. (manual for t5m shows this)
Annnnnd if you break a ball your not out 40 bucks, plus you can change the toe inserts around as things get loose.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 06-12-2015, 03:09 PM   #14184
Super Moderator
Originally Posted by bilster44 View Post
I got this off of Facebook, and the article was from Ernie Provetti from Trinity...it was an article about lipos that puff and such.
Seems to raise a lot of questions, conflicts with the experience of many. Although I could see how some might be misusing the high power chargers and experiencing issues. But this isn't the thread to get into it.
I do appreciate the reply and information though.
Dave H is offline   Reply With Quote
Old 06-12-2015, 05:39 PM   #14185
I had a new Revtech puff on me and he did me right. I did have to take a picture of the receipt, but he got back to me right away and did the right thing. I appreciated it.
Pipe Killer is offline   Reply With Quote
Old 06-12-2015, 08:36 PM   #14186
mtbboy's Avatar
Whos tried the kashima bodies?
They are hella sexy but is there an appreciable difference?
mtbboy is offline   Reply With Quote
Old 06-13-2015, 12:00 AM   #14187
Default Diff shims
I forgot to put diff shims on b5m lite . Are they important? If they are I'll go back and put them on. Or is it not necessary
Aaron33 is offline   Reply With Quote
Old 06-13-2015, 01:22 PM   #14188
Trader Rating: 478 (100%+)
Anybody know how to get an SLRC chassis? I'd like to get a spare B5m chassis and a T5M chassis too. I can't seem to find their website or facebook page...whatever they use.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 06-13-2015, 01:42 PM   #14189
fb is the only way
https://www.facebook.com/stiky.rc?fref=ts
Old 06-13-2015, 05:14 PM   #14190
buckeye dan's Avatar
Sigh another saturday race washed out!! have had new B5M lite since May 1 and have had one complete race day outside SUCKS
Buckeye Dan
buckeye dan is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Eddie_E, RodRC
