    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 06-09-2015, 03:14 PM   #14146
Suspended
Originally Posted by raulio View Post
Ok thank you very much for the reply, I have the b5m and improving the trapezoids front and rear turret front b5. some improvement but that the b5m ground work better with low grip?
Huh?
Mantis Toboggan is offline   Reply With Quote
Old 06-09-2015, 03:30 PM   #14147
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by bilster44 View Post
Studies have shown that racing with one battery all day everyday kills the pack faster than high amp charging...and please, I am NOT here to get involved in ANY battery debates at ALL. I am just passing along info.
I have heard that using the same pack over and over kills it faster. But I track the IR on my packs, and they maintain their numbers for a good about of time... not years... But I believe it was said is that running it over and over back to back was bad. But having 1-2 hours between rounds should be plenty of time to rest. now if you practice for 20 minutes, then 40 amp charge, then immediately run another 20 minutes and keep repeating that, I can see it being more of an issue. Also, it depends on the class. Stock buggy does not build up much battery heat. in an ebuggy, sc 4x4 or even a 4wd buggy with a hot motor, I can see that being much more of an issue.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-09-2015, 03:31 PM   #14148
I am not trying to be mean, but that is an epic response. It almost resembles something google talk would write, lol.
Old 06-09-2015, 03:40 PM   #14149
Super Moderator
Interesting. Do you have any links or sources for the studies you could share?
Dave H is offline   Reply With Quote
Old 06-09-2015, 04:22 PM   #14150
bilster44's Avatar
I got this off of Facebook, and the article was from Ernie Provetti from Trinity...it was an article about lipos that puff and such.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 06-09-2015, 04:28 PM   #14151
lbckevin's Avatar
Trader Rating: 89 (99%+)
It is Ernie's disclaimer so he does not have to warranty any lipo. Its a suggestion.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 06-09-2015, 04:44 PM   #14152
bilster44's Avatar
He does warranty them...provided everything is just right lol, and you have the original receipt...it's part of the article.
Old 06-09-2015, 05:28 PM   #14153
TravisS27's Avatar
Trader Rating: 25 (100%+)
What length flat sensor wire are you guys using in your B5M Lites? Just curious before I order one....my LHS doesn't stock the flat ones. I bought a 100mm round one hoping it'd work but it's too short. I found Reedy sensor wires, just wondering what length you guys suggest. I'm assuming 150mm
AKA Tires
BOOMrc Graphics
Exotek Racing
RickyRacer Lidz
Jake's RC Topeka KS
TravisS27 is offline   Reply With Quote
Old 06-09-2015, 06:20 PM   #14154
Thomas PA's Avatar
Depends how you mount your electronics. Run a string from the motors sensor port to the esc's and measure it
Thomas PA is offline   Reply With Quote
Old 06-09-2015, 06:26 PM   #14155
Jmuck69's Avatar
Flat 175mm is needed
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 06-09-2015, 06:26 PM   #14156
Stock is 175mm
Kinda_Quick is offline   Reply With Quote
Old 06-09-2015, 07:08 PM   #14157
TravisS27's Avatar
Originally Posted by Kinda_Quick View Post
Stock is 175mm
Okay thanks guys.
Old 06-09-2015, 11:35 PM   #14158
1mrdad's Avatar
Trader Rating: 44 (100%+)
Talking
I just finished rebuilding my B5M. I bought it pre-owned. This is my first MM car. I've always raced (stock blinky) RM AE buggies since the first RC10 came out in 1984. I used most of the stock settings except for trailing arm which I have set at 2, and added CSI blue pistons. I tried it for the first time Sunday at practice. The car handles extremely well. Initially it pushed on corner exit, so added flex and a little front toe in. Now it turns very tight and has good entry and exit power-on steering. It's very easy to drive. (On an indoor clay 125x65 med - high bite track) I have a little too much pack so I'm going to soften the springs and drop a 1/2 weight on shock oil. All-in-all very pleased with my first MM car. I let my son drive it, and he wished his 22 cornered as well.
1mrdad
old and slow
1mrdad is offline   Reply With Quote
Old 06-10-2015, 08:39 AM   #14159
bilster44's Avatar
175mm flats are a great fit
Old 06-10-2015, 08:34 PM   #14160
Vigilante212's Avatar
Is there a special bearing size I need to run the mip topshaft, the one I had in my B5 doesn't fit for some reason. The bearing is seated properly.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
