    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 06-07-2015, 09:21 PM   #14116
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
That's what most of the track here are like also. Some worse then that. That's why I ended up getting the rear motor.
Blitzrockey is offline   Reply With Quote
Old 06-07-2015, 09:44 PM   #14117
Originally Posted by Wildcat1971 View Post
ummmmm... yeah... How many of those were MM. And honestly, most of those cars looks terrible. I could just be that blown out dusty track. I feel like I am watching 80s racing, lo..
Top 5 finishers were all mm of various makes. It was definitley a loose track. If you got on the throttle too hard even in the slightest you were loose regardless in rm or mm. I don't have the quals on video track was half as loose. In the end it was just to show what type of conditions we ran in and the end of the straight was like trying to stop in a sandbox
We were forced to run right after the 4wd sct main. It was the loosest it had been all day.
To me thats real off road although the mains were to the extreme of that window this track had no sugar or mag applied previously. I'd take a surface like that over heavily sugared every day. At my home track we use magnesium. Holds together nicely but doesn't destroy tires like sugar yet still gives about 75-85 percent of the grip sugar does.
robbie_gtc is offline   Reply With Quote
Old 06-07-2015, 09:49 PM   #14118
Originally Posted by KAWIDAD View Post
Are you recommending this with the switch of front arms or just in general for steering?
Just in general, doesn't matter which arms you are using it applies but if you are changing arms make that change first then try it before trying another change and so on otherwise you will never know what effect each change had...
less frt droop will give more on power steering. It was advice given by Ray Munday. He actually made reference that he builds his frt shocks with one more limiter then he may expect to need. That way if he has too much he can just unscrew the eyelets back out some to accomodate the added spacer.
Since then I have applied the same theory and have found it work as he said it would.
Old 06-08-2015, 01:39 AM   #14119
Default Motor too hot
Built the b5m factory lite running a trinity d4 short stack 17.5 motor. Im currently geared at 69spur and 32 pinion. Temps on motor are coming off close to 180. Not sure what to do. Can is set at timing 50. Dont want to go down a tooth cause i dont like the feel of the car. Suggestions? And is there a way to place a fan on the motor. Seems like the center brace would be in the way for a fan
Matrixrc10 is offline   Reply With Quote
Old 06-08-2015, 05:36 AM   #14120
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Jake S View Post
tlr didnt send any drivers for the warmup race... but jconcepts page shows maifield arriving.
He did not attend the warm up race but is attending the open practice session that is occurring after the warm up. TLR felt that is was more beneficial / more track time this way.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 06-08-2015, 07:17 AM   #14121
Originally Posted by crazy nick View Post
For those of you not on b5nation fb page ��
Anyone have any information about this body. I looked all over B5 Nation Facebook can't find anything
tekin112000 is offline   Reply With Quote
Old 06-08-2015, 07:21 AM   #14122
Suspended
Trader Rating: 61 (100%+)
32/69 is tall gearing for that motor.
With a weaker short stack, I'd stay at 29/69 or 30/72 with timing cranked to 60. Yes, run a fan...there was a layout at srs that loved taller gearing, and had two large straight aways and a big sweeper connecting them. I could run 33/69 there and run very cool.
The R1 wurks 8.4v fan is the best out there.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 06-08-2015, 09:32 AM   #14123
thecman26's Avatar
Trader Rating: 98 (100%+)
Why is that? On my Fantom Team Works edition V5 (basically a certified standard stack D4) and I run 69/32 pretty much everywhere I race at, hardly gets warmed up, and It's still crzy fast!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 06-08-2015, 10:55 AM   #14124
What Motor fan setup is everyone liking and running? Seems like a lot of the info on here was about talking about which ones were available but what have people decided that they like?
Also 5.3-5.5 FDR the ticket for the Fantom IonV5 17.5 short stack?
Jade67 is offline   Reply With Quote
Old 06-08-2015, 11:22 AM   #14125
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
the short stack is high rev'er and likes shorter gearing with lots of timing. i'm currently running mine at 31/72 with 60 degrees of timing and it feels great.
RC*PHREAK is offline   Reply With Quote
Old 06-08-2015, 11:48 AM   #14126
AE-Reedy
Searching for more on power steering myself(w/lite). Just threw on the gullwing arms and tower,hoping that will help. Should be able to make some laps with it wed.
First/easiest thing to try is moving the battery forward.
Sean Cochran is offline   Reply With Quote
Old 06-08-2015, 12:21 PM   #14127
+1
Yokomo YZ-2
Yokomo YZ-4
Fantom | Lunsford | MurfDogg | Pro-Line | R1 | Racing Performer | Sanwa | Schelle | Tekin | TLR
rbk1115 is offline   Reply With Quote
Old 06-08-2015, 01:17 PM   #14128
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Wildcat.. I don't think I would be making comments on how bad somebody elses driving looks, if I were you. Lay off a bit.
On that track, RM cars will rule. I would never run a MM car on such a loose track.
Back to the B5M.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-08-2015, 01:24 PM   #14129
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Back to the B5M.
I was referring to the cars and the track. I said nothing about driving skill. I dont assault other drivers skills.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-08-2015, 03:51 PM   #14130
crazy nick's Avatar
Trader Rating: 20 (100%+)
Pm sent bud
Rcjuice.com
Hobbystar
"I use the tears of the people I hack to sauce my tires!"
- Chris Kline
crazy nick is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
jl34
