    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 05-22-2015, 09:12 PM   #13891
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
Originally Posted by Mantis Toboggan View Post
Hypothetical situation for you. Your car ends up close to a wall or track barrier at an angle where if you have full steering throw you can just turn away from it without getting stuck, but if you limited steering throw by lowering your EPA you can't turn tight enough to avoid the wall and now you have to wait for a marshal. Now how smart is it to have anything less than full steering throw? By all means use dual rate and exponential to adjust the feeling of the steering, but I would never want to limit the actual amount of steering throw my car has to anything less than the physical limit allowed by the design of the car.
what do you think the dual rate adjustment does?
RC*PHREAK is offline   Reply With Quote
Old 05-23-2015, 07:13 AM   #13892
Originally Posted by MasiisaM View Post
Not really sure how else to explain the throttle curve. You could draw a vertical line in the center and see where the curve crosses. Maybe that would help you see it.
I understood what you were doing with the minimum throttle and what it would do when launching the car. Didn't know it was so common to use it that way though. Pretty interesting.
-Chris
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 05-23-2015, 10:56 AM   #13893
gooba's Avatar
Does anybody Know when the titanium hinge pins are due? AE has a part number but no price and they are listed as out of stock
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 05-23-2015, 02:30 PM   #13894
Jmuck69's Avatar
I think they're titanium nitride coated and not solid titanium. They have been listed forever and nothing. Might be low on the list of things to develope I guess.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-23-2015, 08:29 PM   #13895
Suspended
Trader Rating: 61 (100%+)
If you're serious about a set, pm me. A forewarning, they aren't cheap.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 05-23-2015, 11:53 PM   #13896
Mizchief's Avatar
Instead of paying the extra money on the Ti coating, I just use some Flitz and the buffer wheel on a dremel and get a really good polish on the hinge pins and shafts.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 05-24-2015, 07:35 AM   #13897
Cridd's Avatar
Trader Rating: 16 (100%+)
With the shocks getting a little treamentt maybe a batch of hinge pins will go in for a little bath.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-24-2015, 08:00 AM   #13898
gooba's Avatar
I was more hoping they were going to be stronger them stock. I've polished my stock ones but have bent a couple and on my other cars with titanium hingepins ive never bent one
Old 05-24-2015, 12:07 PM   #13899
BassFan's Avatar
Less dual rate talk and more shock talk plz
BassFan is offline   Reply With Quote
Old 05-24-2015, 07:28 PM   #13900
i recently converted from b5rm to b5m and i had a pretty good setup for rear motor (after a lot of struggle). with some tweaking to base setup i feel like i've got something to build on. i'm glad i made the switch to mid. i ran a 21 6:15 in my first race with the mid. i started with a 18 lap in round one, 19 laps in round two and 21 in round three. i finished 2nd in the b main, missing the bump. indoor clay medium traction. looking for a little smoother steering
mel_russ615 is offline   Reply With Quote
Old 05-24-2015, 08:13 PM   #13901
vito's Avatar
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 05-25-2015, 12:48 PM   #13902
Mason's Avatar
Describe your current steering that you do not like. Is it wanting to dump over on the front and hook around?
Mason is offline   Reply With Quote
Old 05-25-2015, 12:59 PM   #13903
it feels like it wants to loop around entering the infield i have to back off the throttle to let it settle
Old 05-25-2015, 02:56 PM   #13904
Suspended
What front arms are you using? How much Akerman are you running?
Old 05-25-2015, 03:03 PM   #13905
b5 rear motor flat arms and 3* trailing inserts
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
