    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-18-2015, 01:47 PM   #13801
Tmc1's Avatar
Thumbs up
Originally Posted by Socket View Post
I'm sure if you called AE customer service, or asked Sean Cochran here, they would be delighted to tell you.
Rear bodies are still oos, should be back in stock soon I was told
Ill give them a call, thanks Socket.
Tmc1 is offline   Reply With Quote
Old 05-18-2015, 01:49 PM   #13802
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
My guess would be not for a while. Since they dont make the cheapy pistons yet for the new shafts, they would need to include machines pistons. And for tuning purposes, that might be hard. Unless they packaged in all of the machined pistons. Which would be costly. So, I am going to go on a limb and say long ways out.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-18-2015, 02:09 PM   #13803
Tmc1's Avatar
I think you could be right. Hopefully they introduce a set with cheapy pistons sooner rather than later.
Old 05-18-2015, 02:43 PM   #13804
Tmc1's Avatar
Spoke with a rep, no plan to offer the new shock body/shafts in a kit. Bummer
Old 05-18-2015, 06:12 PM   #13805
Cool
So, it was with trepidation I hit the local SDRC track with my freshly built RC10B5M with the usual smattering of hop ups. Having not raced for 20 years I expected a learning curve on both the clay and 2wd compared to indoor/outdoor 4wd in the old Nimh brushed days.
Safe to say I was all over the place, car didnít handle great from out of the box configuration at least. I left after a few practice sessions a little despondent and scratching my head. Maybe I should have stayed in the 4wd category where the balance is more predictable and controllable.
Anyway, Iím the sort of person to never give up and prefer to debrief myself and break down all the issues I had to take another stab at it again in a couple of weeks time. Here is what I broke down and what I have attempted to do to solve this and make the car more drivable and predictable.
What I experienced;
  • Car was very tail happy in the corners making for difficult line ups for jumps.
  • Car was skittish under acceleration meaning I was trying to control a snaking car down the straights.
  • Off track the car had lots of clay in the tread and it was barely visible.
What I interpret;
  • The tire tread full of clay is likely a result of too much power through the tires making it wheel spin under acceleration and filling tread with clay.
  • The tail happy in corners was likely a result of the now slick tires based on loss of grip and when accelerating around a corner this spinning the car around. Same for skittish in a straight line with each wheel getting different levels of grip.
Setup changes I made;
  • Loosened the Nova Slipper clutch to release the tires from wheel spinning as much.
  • Double checking Differential settings after initial runs.
  • Altered the Orion ESC to;
  • Reduce the turbo acceleration from 7 to 4, again lessening the rapid acceleration to ensure grip was more likely in early range.
  • Implement drag force braking at 10%. Means in neutral the car would naturally slow itself rather than using the more forceful brake action of transmitter.
  • Altered the transmitter to;
  • Increase acceleration range to full movement of trigger instead of full range in 75%. Allows for smoother acceleration.
  • Add a throttle profile to deliver smoother acceleration over 80% of the range and deliver the final 40% in the last 20% of movement. Means that the tires get that little more help to grip before putting the power down.
  • Introduced a throttle curve profile rather than linear.
Things to still do;
  • Get some tire sauce, heavy to medium grade to improve direct grip.
After making the changes and testing outside on concrete I noticed a huge improvement to drivability. Iím not normally a fan of a large number of changes in one go but I needed drastic action.
Any thoughts? Totally wrong approach? I should hang up my transmitter and go kite flying instead?
Happy for any more helpful tips you guys might have.
On a positive note, my gearing was good and all temperatures were low after runs.
Thanks.
bizarrefish is offline   Reply With Quote
Old 05-18-2015, 06:15 PM   #13806
Suspended
Trader Rating: 61 (100%+)
What I experienced;
What I interpret;
Things to still do;
Thanks.
Wow.
Wow.
Take ALL boost out of the ESC. If you haven't raced in 20 years, boost is the least of your worries.
NO tire sauce allowed at SDRC
If you have the regular B5M kit, get the rear motor rear arms, and shorten the wheel base all of the way. This will provide more forward bite.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 05-18-2015, 06:17 PM   #13807
What I experienced;
What I interpret;
Things to still do;
Thanks.
tires are wrong and probably too much power. you are boosting, so there is one issue for a new driver.
Old 05-18-2015, 06:23 PM   #13808
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Wow.
Wow.
Sauce is now allowed at SDRC this month as long as the tires are dry when they go on the track and you're not using diesel fuel or liquid wrench. They're testing it out to make racers :cough:whiners:cough: happier.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 05-18-2015, 06:28 PM   #13809
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
and what is in liquid wrench that is so much worse than the proprietary concoction of solvents in the much more expensive "RC tire sauces"?
RC*PHREAK is offline   Reply With Quote
Old 05-18-2015, 06:54 PM   #13810
Nat Maniac's Avatar
What I experienced;
What I interpret;
Things to still do;
Thanks.
Unless there is something terribly wrong with your core car set up a quality driver could take your car and punish most people after a few practice laps.
1.Dial everything down. As others have said definitely No Boost no Turbo etc
2.Dial your radio steering speed down.
3.Dial your radio acceleration speed down.
4. Ask one of your local A-Main drivers to take a look at your car to make sure there is something obviously wrong and if everything seems in order my recommendation is that you shouldn't keep making changes to your set up until your punching out consistent lap times.
5. Apart from that the most important thing is to practice, practice, practice!
All the best with your come back after 20 years away!
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 05-18-2015, 06:56 PM   #13811
Suspended
Why can I not use LW or Diesel fuel?
I can easily change the smell of either, and you'd never know the difference. How are they testing to see what you have?
Old 05-18-2015, 07:13 PM   #13812
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
We don't want to get started on a sauce discussion. The subject is far too volatile and not necessarily related directly to the B5M. I've lived with sauce controversy for 2 years now at my local tracks so I'd rather us not be discussing it here.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 05-18-2015, 07:24 PM   #13813
Trader Rating: 83 (100%+)
My first race day (track day as well) with the B5M Factory Lite was a good experience. I built the car per the manual, (with the one change of running the "middle" setting on the rear hub carriers) and a set of Electrons that had seen 2-3 race days on my B4.2.
I had not been to a clay track to race for about a year, so I ran the old 4.2 for two batteries to get the feel of the track (IERC, new layout, quite fun). I was running about 26-27 second laps. Brought out the B5M-Factory Lite and on the first battery I was .5 seconds a lap faster (on average). By the end of the night on laps that I ran 'clean' I was in the low 24's (the hot shot class guys were in the 22's, maybe 21's).
Now it is time for some practice laps and some tuning adjustments, but the new car was better than one second a lap faster than the old one, not to bad (the last time I remember a car being so much faster on day one was when I bought my B2 in the lateish 90's to replace my rc10 team car (or maybe my XrayT2 vs. the TC3)
TimF is offline   Reply With Quote
Old 05-18-2015, 07:59 PM   #13814
What I experienced;
What I interpret;
Things to still do;
Thanks.
Next time at the track, ask someone at the front desk to point out several regulars who can check your set up. Stock out of the box should run fine with the correct tires. My guess is that tires are causing your problems. I race on Wed nites and get to the track shortly after opening. Feel free to swing by and introduce yourself and I will check out your setup.
Good luck,
Fred Murray
Micah123 is offline   Reply With Quote
Old 05-18-2015, 08:04 PM   #13815
Wow.
Wow.
I know, lengthy post but thought I would post it raw for the benefit of others who might learn.
Noted on the boost. I chose to go out of the box on everything and dial it back, in hindsight I should have dialled right back in the first place .
Good idea on the adds, will consider just that.
The tires are actually JConcepts barcodes, green/golds so I think they should be okay, definitely power and boosting which I did already touch on but can scale further back for sure.
Good points on the steering too, missed reducing that speed too. As I build the local track relationships up I'll be sure to grab an A-Main driver, if they will even give me the time of day
Its great to be back after the absence and trying to enjoy the love I had for the hobby again!
Thanks for all the feedback peeps, it helps greatly, I exposed myself with the long post but you need to take the criticism and the feedback constructively :-).
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
